Yealink Headset Intergration WebRTC
I have a Yealink WH62 Headset and when I use it with WebRTC it works fine, however, when I enable the HID Headset Intergration , it works fine for incoming calls, I can hit the button on the side of the headset and it picks up and you can have a conversation, however, when I call out from the WebRTC with the HID Headset Intergration enabled, it will ring but disconnect calls immediately upon the other party answering. As soon as I turn the HID Headset Intergration off it works again as normal.
Please fix or provide what we are doing wrong.
The latest version of VitXi is now available! Check out the details in the post below: VitXi 4.6.0 – Major Release: Inboxes, WhatsApp/SMS, High-Performance Mode & More!
Tested Headsets: HID Headset Integration with VitXi WebRTC
