WebRTC with Yealink Headset Compatibility
Couple of things on this.
  1. Can we get Vitxi added as a Authorised softphone with Yealink?
  2. When we use a WH62 Headset with the HID Headset Intergration enabled in Vitxi, the button works, inbound calls are fine, but outbound calls are disconnected immediately. Disable HID Headset Intergration and outbound calls are fine again.
  3. When using the WH62 headset, whether the HID Headset Integration is enabled or disabled, the call does not ring through the little speaker on the Headset base so it can be heard if not wearing the headset. We have downloaded Yealink USB Connect and configured the base to ring, however, it does not. Tests ok with Teams but not with Vitxi. I am wondering if not being a Authorised softphone in the Yealink USB Connect and not being able to choose it as the softphone has anything to do with that?
Are you using Debian 11 or 12? What version of VitXi?
Hi Miguel. Debian 12 and just updated to VitXi 4.5.0-6
Hi!
We haven’t tested that model yet, but we’ll coordinate with our internal team. However, the WebHID integration should work with most headset models. We’re planning to run internal tests specifically with outgoing calls.
Also, have you checked if the desired speaker was selected in the user settings or in the options available during the call layout?
Best regards!
Hi Maynor. Yes, please test. The HID Intergration in Vitxi disconnects outbound calls immediately when enabled with WH62. It is fine with UH36 which is no surprise as that is the one that you mention you tested with.
And yes, all settings are correct. We have been working with Yealink to try to rectify. However, Yealink have advised that this is likely due to VitXi not being an official/compatible softphone. The softphone needs to send the signal to the headset base station that there is an incoming call. We have all settings correct in Yealinks USB Connect program.
With Yealink being one of the biggest player in the phone and headset game, we need to be compatible and fully functional.
You can visit here to see the extensive list of compatiable softphones. https://support.yealink.com/en/portal/compatible
@maynor how did your team go with testing the WH62? We have two customers now using this and they are not happy and missing calls as they cannot hear inbound calls if they do not have the headset on.
We need the integration working without disconnecting outbound calls and we need inbound calls ringing through the base station.
@maynor please provide an update on this.
Our team is working on getting the headset and then starting to work on compatibility with VitXi.
@maynor just wondering how this is going? We have Yealink looking at this too and they were going to be reaching out to yourself and Joseph. Are you able to provide an update?
@maynor Yealink has confirmed that they have sent an email and form but not got a response. Yealink headset compatibility requirements and information collection Please provide us an update ASAP
We have confirmed with the entire team and have not received any email from Yealink. Also, although the standard WebHID API exists, some headsets handle certain actions differently. Therefore, having official documentation from the specific headset provider is important.
Our team is still working on acquiring the necessary equipment to proceed with the integration.
I’ve already shared the form URL with the team in charge so they can proceed with the process.
@maynor are you able to provide an update on this? Has work commenced with Yealink and how did you go with testing the WH62?
Sorry for the delayed response.
We recently received the Yealink headsets to start the integration process. Please keep in mind that this type of integration takes time to implement and test properly.
Please stay tuned to our communication channels for updates.
Hi team. How is this going? We have another customer who is unable to use his WH62 pick up and hang up button on the headset with his T54 handsets on Vital PBX. Will this issue for this headset working with VitXi also resolve with Vital on a Yealink handset?
Hello Sir,
We recently acquired the Yealink WH62 and have been working on its integration with VitXi. However, due to the unique behavior of this headset, the events it sends differ from those of other headsets we have previously integrated. Because of this, our team will reach out to Yealink’s technical team to request developer-level documentation and support to help us with the integration.
In the meantime, in the upcoming VitXi update (to be released soon), we’ve implemented compatibility for the Jabra PRO 9470 headset. Compatibility with the Yealink WH62 will remain pending until we have the necessary information to properly support it using web technologies.
Hi @maynor any update on this? We have a customer desperate to get this function working. Confirm that the outreach to Yealink has happened and the integration has begun?
Did you read the previous post?
We have already reached out to Yealink by filling the form to their integration process. We continue to test out the devices, and hope to have the integration fully done as soon as we possibly can.
Hi team, a couple of months have passed now. How is this going?
