Voicemail message waiting indicator (MWI)
How can we get multiple phones to subscribe to a single voicemail box for mwi?
Say for instances were a group of extensions and monitoring voicemails coming into one vm box.
I know on freeswitch you simply set the extension to subscribe to mwi at [email protected]
Thanks for you’re advise on this.
Fernando
Hi, check here and tell us what you think.
We can make all extensions go to the same voicemail box by editing the no answer and busy settings though, that’s not going to give all extensions the message waiting indicator.
We just turn off voicemail for each extension and modify the follow me settings to send to extension X on busy and no answer. Still, we need a way to give each extension subscription to the message waiting indicator.
Thanks,
Fernando
Instead of the MWI Button there is a solution with BLF: VM_200 (voicemail extension 200 as an example). This would make a BLF-Key red if there is a new message and you can listen to it.
That is the only alternative at this point.
