VitXi Issue after Upgrade
Dear team,
After upgrading to VitalPBX 4.5, switchboard wasn’t starting and dashboard not populating. Modified /usr/share/vitalpbx/monitor/config.ini twice just to be sure. Now vitxi call history dissapearing and stats is not populating agents when creating queues. Please help
I had some issues afte the upgrade and it is now solved, You can try the following:
sed -i 's|include /etc/nginx/pbx-addons/\*;|include /etc/nginx/pbx-addons/*.conf;|' /etc/nginx/sites-enabled/vitalpbx
Then:
dpkg --configure -a
apt-get --reinstall install logger-core -y
systemctl restart nginx
For VitXi, update the System API add-on from the Add-ons module on VitalPBX.
Please update the “System API” add-on to the latest version in the VitalPBX Addons module. Make sure to click Check Online to retrieve the most recent release.
Also, the latest version of VitXi is now available, you may proceed with the update: VitXi 4.6.0 – Major Release: Inboxes, WhatsApp/SMS, High-Performance Mode & More!
