Visual PBX Configuration Diagram Generator (Auto-Mapping of Extensions, IVRs, Routes, etc.)
Hello VitalPBX Team and Community,
We would like to suggest a feature that would be highly useful for system integrators, technical support staff, and consultants: a built-in tool to automatically generate a visual diagram of the current PBX configuration.
Context:
Recently, while onboarding a new client, their previous provider shared a complete visual diagram exported directly from their PBX system, showing the structure and flow of calls, including IVRs, extensions, ring groups, inbound and outbound routes, and more. This made the transition process significantly easier and helped both our technical team and the client understand the full call flow at a glance.
In VitalPBX, we currently create these diagrams manually using tools like Excel or Draw.io, which is time-consuming and difficult to maintain when configurations change frequently.
Feature Proposal:
We request a new feature (or module) that would allow users to:
Automatically generate a visual diagram of the PBX configuration, including:
Extensions and their destinations
IVRs and menu options
Ring groups
Queues
Inbound and outbound routes
Trunks
Time conditions / schedules
Call routing logic and destinations
Export options, such as:
Integrated graphical view inside the web GUI
Export to Draw.io-compatible XML (.drawio), Lucidchart, PDF
Export to structured JSON, PlantUML or MermaidJS for external rendering
Automatic updates:
Option to regenerate the diagram dynamically after configuration changes
Version control or change tracking of configuration diagrams
Benefits:
Saves significant time during onboarding, auditing, and documentation
Helps communicate call flow and PBX architecture to clients visually
Reduces human errors and manual work
Greatly improves clarity for support teams working on existing deployments
This feature would be an incredible addition to VitalPBX and would help standardize and accelerate implementation processes.
Thank you in advance for considering this suggestion.
This would be absolutely fantastic! We would also love something like this.
Since Vitalpbx changed from Apache to Nginx we need to find some time to make it work on VitalPBX 4.5.
It’s working on V3 and up to V4.2.
On the Frog logo variant, they have a module called dialplan visualizer. Can talk with the Dev to see if he can port it VitalPBX
Let me know if I can help with this. In moving clients over from other providers most of them have some type of visual editor and it really helps to prevent errors and discuss call flow tweaks with clients.
I like the look of this, however the documentation mentions a license, but the link to get/check cost of the license doesn’t work, ca you please advise
Updated link here in the forums so anybody that runs across this can see. Google TTS in recordings management - #9 by mo10.
Greetings, how can I contact you to obtain that service?
I think a Mermaid.ai plugin would be great (Mermaid Chart). We have been going the affordable, yet very time consuming route of manually drawing our call flows using Google Drawings app. It is easy to use and insert into a shareable Google Doc, and I can completely customize it to show useful things like IVR greeting scripts, so that clients and techs alike can easily see what their phone system does all in one view without hovering or clicking on an object. I’m not sure yet if Mermaid allows for that level of detail, but I like the diagram generating aspect.
Callflowstudio also seems to be working with VitalPBX
Yes Other Asterisk platform that is Free has a DialPlan Visualiser. It is really useful. The same would be great for VitalPBX. Built on the same platform it should be possible
I don’t wanna get everyone too excited but I have been working on something. Built in Python Django and working with nginx. Works with vitalpbx 4.5.3.
Its a featureful dialplan call flow visualizer. Its definitely not perfect but seems to get the job done with some bells and whistles. I will want to publicly release it once I feel good about it working well if vitalpbx is okay with it. I don’t believe I will be trying to make money off of it but unsure and undecided right now. :melting_face:
Screenshots:
Honestly Callflow Studio does more than enough and Adam has been super responsive on the few things I’ve raised so far
Would still like something native but CFS has all the major stuff needed and easy enough to set up
