When trying to sync users to team, 2 of the extensions won’t sync.
The error it shows is blank:
Hi Ales,
What version of VitalPBX and Recordings are you using?
Latest.
PBX Carrier Plus 3.2.2-1
Asterisk 18.10.0-1
DAHDI 2.11.1-7
Recordings: Version: 3.0.2-1
I have to add that there are more extensions that cannot be synced.
Maybe is a database issue with your language characters. What’s your native language? or the language you are using in the name of your extensions?
Language is Slovenian, code page 852/1250/8859.
I tested and if extension has š and ž character then all is fine.
Error arises with č, ć and đ character:
What about empty error message?
