In addition to what is mentioned here; We would like to be able to:
- Forward a voicemail to another mailbox.
- Being able to add a note to the voicemail (like you can do now in the Sonata Recording) - It is very helpful to be able to go back and read, as well as when forwarding the message, the note should be forwarded as well.
- Enable/Disable a temp vacation greeting
