We are running several MVNOs throughout Europe and the US.
we have been looking at, and testing your system, and see it is a potential replacement for our current platform.
However, since we a MVNO, we need mobile calls (GSM) to run through the platform.
Basically the callflow would be
Today, on our current solution, also Asterisk basedm we have solved it via using “custom extension” that is connected/attached to the user like anyother IP phone.
I see it work with a extra function under “Devices” - where you can add the mobile number of the user and what route/operator it should be routed by.
The routing is controlled under “external” with a menu point, called “mobile”, here you can add the different operators with name,IP, prefix (is needed)
E.g. T-mobile & AT&T
So you choose new device:
Choose mobile
Input mobile number
choose operator
and save
How can you help us, solved this ?
As more and more mobile networks, are using GSM → SIP (instead of e.g. SS7 etc.), we would ofcourse be happy to pay for such feature.
When it was made on our current platform, it took apx. 5 hours to implement,
NB: This is not possible to solved using a “softphone” etc. on the mobile. It must be as desribed above
I have a bit of trouble understanding your setup and request.
Is it that you want to have a device with a custom dial string? So when you have an incoming call the PBX calls that device’s custom IP:Port? And assumingly you want the same the opposite, that when IP:Port calls, it should show up as an extension placing a call on the PBX?
Can you please prove an example of the following?
Let’s say 8880001234 is a mobile phone.
What would be the call flow/route/steps that would happen is 8880001234 tries to call a landline 7776660000?
And also, what would happen on the opposite, a landline 7776660000 calls 8880001234 ?
Can you show us how such an endpoint looks on your current system?
Is it possible to use something like Kamailio that will do the registration to VitalPBX and setup the route to the mobile based on whatever identifier you have on your current SBC.
If you can implement Kamailio, then perhaps you can use Kamailio to replace the need of a B2BUA.
@Mads_Mortensen It could implement what you need. However, we need your support to obtain more information in this regard, starting with what @PitzKey asked you in point 1.
Basically all mobile calls originated from a mobile, is routed via our SBC to the pbx.
The pbx regonizes what extension/user the mobile is a part of, based on the mobile number.
And routing is done accordingly.
If call originates from a other party the call it routed to the pbx, and then extension the did is routed to.
If the extension have, let’s say 1 iPphone and one mobile ,the call is sent to the IP phone, and the mobile call is routed to the mobile sbc
