Hi VitalPbx Team,
We try use dialer and check report call on sonata report → outgoing Calls
Why destination “s” ?
while on dialer report no issue
The information is retrieved from different sources. The Sonata Stats uses the CDR table, and the Dialer uses the Queue Logs table.
Hi @miguel
On this topics Date Time Sonata Stats VS Date time Sonata Dialer not Match
Destination not “s”, on Sonata stats.
Hi Sir,
Can you fixed issue Destination field value on sotata stats on menu Outgoing Call Detail?
I tried to do a manual call from vitxi webrtc from extension 201 to dest number 08444769212
value “Destination” on sonata stats “s”
I try compare report CDR on vitalpbx it normal.
I will show screenshot and log asterisk
asterisk log
[2022-11-18 16:44:57] VERBOSE[21543] res_rtp_asterisk.c: DTLS ECDH initialized (automatic), faster PFS enabled
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@cos-all:1] NoOp("PJSIP/201-000002de", "More than on digit pattern") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@cos-all:2] Gosub("PJSIP/201-000002de", "s,1(08444769212)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:1] Set("PJSIP/201-000002de", "EXTENSION=08444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:2] NoOp("PJSIP/201-000002de", "Dialing 08444769212 from 201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:3] Gosub("PJSIP/201-000002de", "sub-set-global-vars,s,1(db494559b6584de5,08444769212,parking-1)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-global-vars:1] NoOp("PJSIP/201-000002de", "Setting Global Vars") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-global-vars:2] Set("PJSIP/201-000002de", "TENANT_PATH=db494559b6584de5") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-global-vars:3] Set("PJSIP/201-000002de", "PREFIX=") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-global-vars:4] Set("PJSIP/201-000002de", "__PICKUPMARK=08444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-global-vars:5] Set("PJSIP/201-000002de", "__PARKINGLOT=parking-1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-global-vars:6] Set("PJSIP/201-000002de", "__DYNAMIC_FEATURES=custom-features") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-global-vars:7] Set("PJSIP/201-000002de", "ICALL=no") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-global-vars:8] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:4] Gosub("PJSIP/201-000002de", "sub-set-call-vars,s,1(db494559b6584de5,08444769212,1,cos-all,ARS-all)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:1] NoOp("PJSIP/201-000002de", "Setting Call Vars") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:2] Set("PJSIP/201-000002de", "_TENANT=db494559b6584de5") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:3] Set("PJSIP/201-000002de", "_CALL_DESTINATION=08444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:4] Set("PJSIP/201-000002de", "_COS_ID=1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:5] Set("PJSIP/201-000002de", "_COS_NAME=cos-all") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:6] Set("PJSIP/201-000002de", "__TRANSFER_CONTEXT=cos-all") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:7] Set("PJSIP/201-000002de", "_ARS=ARS-all") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:8] Set("PJSIP/201-000002de", "CDR(tenant)=vitalpbx") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:9] Set("PJSIP/201-000002de", "CDR(destination)=08444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:10] Set("PJSIP/201-000002de", "CDR(trunk)=") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:11] Set("PJSIP/201-000002de", "CDR(did)=") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:12] Set("PJSIP/201-000002de", "__CALLID=1668764697.3059") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:13] ExecIf("PJSIP/201-000002de", "0?Set(CHANNEL(language)=)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:14] ExecIf("PJSIP/201-000002de", "0?Set(CHANNEL(language)=)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-set-call-vars:15] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:5] Gosub("PJSIP/201-000002de", "sub-construct-cid,s,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:1] NoOp("PJSIP/201-000002de", "Building CID") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:2] Set("PJSIP/201-000002de", "_CALL_SOURCE=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:3] Set("PJSIP/201-000002de", "_CS=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:4] GotoIf("PJSIP/201-000002de", "0?return") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:5] Gosub("PJSIP/201-000002de", "sub-get-device-tree,s,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:1] NoOp("PJSIP/201-000002de", "Configuring Device Tree") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:2] Set("PJSIP/201-000002de", "DEV_TECHNOLOGY=PJSIP") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:3] GosubIf("PJSIP/201-000002de", "0?s-local,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:4] GotoIf("PJSIP/201-000002de", "0?return") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:5] GotoIf("PJSIP/201-000002de", "1?pjsip") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (sub-get-device-tree,s,9)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:9] NoOp("PJSIP/201-000002de", "A PJSIP") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:10] Set("PJSIP/201-000002de", "DEV_USER=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:11] Goto("PJSIP/201-000002de", "build_interface") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (sub-get-device-tree,s,13)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:13] Set("PJSIP/201-000002de", "_INTERFACE=PJSIP/201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:14] Set("PJSIP/201-000002de", "DEV_TREE=devices/PJSIP/201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-get-device-tree:15] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:6] GotoIf("PJSIP/201-000002de", "0?return") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:7] Set("PJSIP/201-000002de", "_CALL_SOURCE=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:8] Set("PJSIP/201-000002de", "_CS=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:9] ExecIf("PJSIP/201-000002de", "1?Set(CALLERID(all)="agent1" <201>)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:10] Set("PJSIP/201-000002de", "_CID_CONSTRUCTED=yes") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:11] NoOp("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:12] Set("PJSIP/201-000002de", "CDR(source)=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-construct-cid:13] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:6] Gosub("PJSIP/201-000002de", "set-global-tenant-vars,s,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@set-global-tenant-vars:1] NoOp("PJSIP/201-000002de", "Setting Global Vars for vitalpbx Tenant") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@set-global-tenant-vars:2] Set("PJSIP/201-000002de", "__TENANT_PATH=db494559b6584de5") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@set-global-tenant-vars:3] Set("PJSIP/201-000002de", "__TENANT_PREFIX=") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@set-global-tenant-vars:4] Set("PJSIP/201-000002de", "__QUEUE_AGENTS_CONTEXT=queue-call-to-agents") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@set-global-tenant-vars:5] Set("PJSIP/201-000002de", "__FOLLOWME_CONTEXT=ext-followme") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@set-global-tenant-vars:6] Set("PJSIP/201-000002de", "__HINTS_CONTEXT=extension-hints") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@set-global-tenant-vars:7] Set("PJSIP/201-000002de", "__DEFAULT_COS=cos-all") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@set-global-tenant-vars:8] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:7] GotoIf("PJSIP/201-000002de", "0?local-dialing") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:8] NoOp("PJSIP/201-000002de", "Check if is an Emergency Call") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:9] GotoIf("PJSIP/201-000002de", "0?emergency-calls,08444769212,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:10] Gosub("PJSIP/201-000002de", "sub-lockphone-check,s,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-lockphone-check:1] NoOp("PJSIP/201-000002de", "SUB: LOCK PHONE CHECK") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-lockphone-check:2] GotoIf("PJSIP/201-000002de", "0?unlock") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-lockphone-check:3] GotoIf("PJSIP/201-000002de", "0?unlock") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-lockphone-check:4] GotoIf("PJSIP/201-000002de", "0?unlock") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-lockphone-check:5] GotoIf("PJSIP/201-000002de", "0?unlock") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-lockphone-check:6] GotoIf("PJSIP/201-000002de", "0?:unlock") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (sub-lockphone-check,s,12)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-lockphone-check:12] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:11] Gosub("PJSIP/201-000002de", "sub-local-dialing,s,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-local-dialing:1] NoOp("PJSIP/201-000002de", "Trying to determine if is a local extension") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-local-dialing:2] GotoIf("PJSIP/201-000002de", "0?:return") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (sub-local-dialing,s,5)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-local-dialing:5] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:12] GotoIf("PJSIP/201-000002de", "0?end-call") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@cos-all:13] Goto("PJSIP/201-000002de", "cos-all-post,08444769212,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (cos-all-post,08444769212,1)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@cos-all-post:1] NoOp("PJSIP/201-000002de", "Outbound Route: OCDEMO") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@cos-all-post:2] Gosub("PJSIP/201-000002de", "sub-setup-call-type,s,1(outgoing)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-setup-call-type:1] NoOp("PJSIP/201-000002de", "Determinating Call Type") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-setup-call-type:2] GotoIf("PJSIP/201-000002de", "0?return") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("PJSIP/201-000002de", "s-outgoing,1()") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-outgoing@sub-setup-call-type:1] NoOp("PJSIP/201-000002de", "Outgoing Call") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-outgoing@sub-setup-call-type:2] Set("PJSIP/201-000002de", "__CALL_TYPE=3") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-outgoing@sub-setup-call-type:3] Set("PJSIP/201-000002de", "__CALL_TYPE_LABEL=OUT") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-outgoing@sub-setup-call-type:4] GosubIf("PJSIP/201-000002de", "0?s-transit,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-outgoing@sub-setup-call-type:5] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-setup-call-type:4] Set("PJSIP/201-000002de", "__CALL_TYPE_CONFIGURED=yes") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-setup-call-type:5] Set("PJSIP/201-000002de", "CDR(calltype)=3") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-setup-call-type:6] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@cos-all-post:3] Set("PJSIP/201-000002de", "DNID=08444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@cos-all-post:4] NoOp("PJSIP/201-000002de", "Start to Dial Trunks") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@cos-all-post:5] Goto("PJSIP/201-000002de", "s-1,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (cos-all-post,s-1,1)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-1@cos-all-post:1] Set("PJSIP/201-000002de", "__CONFIGURED_BY_TENANT=yes") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-1@cos-all-post:2] Gosub("PJSIP/201-000002de", "sub-construct-cid,s-external,1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:1] NoOp("PJSIP/201-000002de", "Setting External CID") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:2] Set("PJSIP/201-000002de", "EXTENSION_NUMBER=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:3] GotoIf("PJSIP/201-000002de", "0?return") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:4] GotoIf("PJSIP/201-000002de", "0?return") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:5] Set("PJSIP/201-000002de", "EMERGENCY_CALL=no") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:6] Set("PJSIP/201-000002de", "EXTENSION_EMERGENCY_CID=") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:7] Set("PJSIP/201-000002de", "DYNAMIC_EXTERNAL_CID=no") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:8] ExecIf("PJSIP/201-000002de", "1?Set(EXTENSION_EMERGENCY_CID=)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:9] ExecIf("PJSIP/201-000002de", "1?Set(DYNAMIC_EXTERNAL_CID=no)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:10] GotoIf("PJSIP/201-000002de", "0?check-emergency") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:11] Set("PJSIP/201-000002de", "EXTENSION_EXTERNAL_CID="agent1" <201>") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:12] ExecIf("PJSIP/201-000002de", "1?Set(CALLERID(all)="agent1" <201>)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:13] GotoIf("PJSIP/201-000002de", "1?:check-emergency") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:14] Set("PJSIP/201-000002de", "TENANT_DEFAULT_EXTERNAL_CID=") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:15] ExecIf("PJSIP/201-000002de", "0?Set(CALLERID(all)=)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:16] GotoIf("PJSIP/201-000002de", "0?:info") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (sub-construct-cid,s-external,30)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:30] NoOp("PJSIP/201-000002de", "CID Name: agent1, CID Number: 201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:31] Set("PJSIP/201-000002de", "SEND_CID=yes") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:32] ExecIf("PJSIP/201-000002de", "0?Set(CALLERID(name-pres)=prohib_passed_screen)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:33] ExecIf("PJSIP/201-000002de", "0?Set(CALLERID(num-pres)=prohib_passed_screen)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:34] Set("PJSIP/201-000002de", "__EXT_CID_CONSTRUCTED=yes") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:35] Set("PJSIP/201-000002de", "CDR(source)=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-external@sub-construct-cid:36] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s-1@cos-all-post:3] Gosub("PJSIP/201-000002de", "trk-1,08444769212,1(from-trk-grp)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1:1] Set("PJSIP/201-000002de", "_NTD=08444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1:2] Gosub("PJSIP/201-000002de", "trk-1-dial,08444769212,1(from-trk-grp)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:1] NoOp("PJSIP/201-000002de", "Trunk: DEMO") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:2] NoOp("PJSIP/201-000002de", "Dialing: 08444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:3] Set("PJSIP/201-000002de", "CDR(trunk)=1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:4] Set("PJSIP/201-000002de", "SKIP_HANGUP_AUDIOS=no") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:5] Gosub("PJSIP/201-000002de", "sub-setup-call-type,s,1(outgoing,no)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("PJSIP/201-000002de", "s-outgoing,1(no)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:6] ExecIf("PJSIP/201-000002de", "0?Set(CALLERID(all)=):") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:7] GotoIf("PJSIP/201-000002de", "1?:after-val-sim-calls") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:8] Set("PJSIP/201-000002de", "MAX_TENANT_CALLS=0") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:9] Set("PJSIP/201-000002de", "TENANT_NAME=vitalpbx") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:10] GotoIf("PJSIP/201-000002de", "0?:after-val-sim-calls") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (trk-1-dial,08444769212,18)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:18] NoOp("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:19] NoOp("PJSIP/201-000002de", "Configuring Trunk Parameters") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:20] ExecIf("PJSIP/201-000002de", "1?Set(CHANNEL(musicclass)=default):") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:21] Set("PJSIP/201-000002de", "__TRUNK_MOH_SET=yes") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:22] Set("PJSIP/201-000002de", "DIAL_PREFIX=2203") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:23] Set("PJSIP/201-000002de", "__TRKDIALOPTIONS=kt") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:24] Set("PJSIP/201-000002de", "ORIGINATOR=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:25] Set("PJSIP/201-000002de", "RING_TIME=90") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:26] Set("PJSIP/201-000002de", "CALLED=08444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:27] Set("PJSIP/201-000002de", "TRUNK_ENDPOINT=DEMO") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:28] NoOp("PJSIP/201-000002de", "Force Recording by Trunk") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:29] Set("PJSIP/201-000002de", "APP_RECORDING=yes") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:30] Set("PJSIP/201-000002de", "__CIDNUM=201") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:31] Set("PJSIP/201-000002de", "__CIDNAME=agent1") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:32] Set("PJSIP/201-000002de", "FORCE_RECORDING=yes") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:33] Set("PJSIP/201-000002de", "FILTERED_NUMBER=220308444769212") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:34] GotoIf("PJSIP/201-000002de", "0?:post-fax") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (trk-1-dial,08444769212,37)
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:37] NoOp("PJSIP/201-000002de", "End Fax Section") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] pbx.c: Executing [08444769212@trk-1-dial:38] Dial("PJSIP/201-000002de", "PJSIP/220308444769212@DEMO,90,ktU(sub-before-bridging-call^db494559b6584de5^201^220308444769212^yes)") in new stack
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] app_dial.c: Called PJSIP/220308444769212@DEMO
[2022-11-18 16:44:57] VERBOSE[7771][C-00000357] app_dial.c: PJSIP/DEMO-000002df is making progress passing it to PJSIP/201-000002de
[2022-11-18 16:44:58] VERBOSE[7771][C-00000357] app_dial.c: PJSIP/DEMO-000002df is making progress passing it to PJSIP/201-000002de
[2022-11-18 16:44:58] VERBOSE[7771][C-00000357] app_dial.c: PJSIP/201-000002de requested media update control 26, passing it to PJSIP/DEMO-000002df
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Spawn extension (trk-1-dial, 08444769212, 38) exited non-zero on 'PJSIP/201-000002de'
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [h@trk-1-dial:1] GosubIf("PJSIP/201-000002de", "0?sub-outbound-queue-call,s,1") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [h@trk-1-dial:2] Gosub("PJSIP/201-000002de", "dynamic-routing-out,s,1(201,08444769212,CANCEL,1)") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:1] NoOp("PJSIP/201-000002de", "Test if save on dynamic routing list") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:2] Set("PJSIP/201-000002de", "CALLER=201") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:3] Set("PJSIP/201-000002de", "CALLED=08444769212") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:4] Set("PJSIP/201-000002de", "STATUS=CANCEL") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:5] Set("PJSIP/201-000002de", "TRKID=1") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:6] Set("PJSIP/201-000002de", "ALLOW_DR=no") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:7] Set("PJSIP/201-000002de", "DYNROUTING_OMC=yes") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:8] GotoIf("PJSIP/201-000002de", "0?:comeback") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx_builtins.c: Goto (dynamic-routing-out,s,10)
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@dynamic-routing-out:10] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [h@trk-1-dial:3] Gosub("PJSIP/201-000002de", "notify-trunk-hangup,s,1") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@notify-trunk-hangup:1] Verbose("PJSIP/201-000002de", "0, Trunk Hangup") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] app_verbose.c: Trunk Hangup
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@notify-trunk-hangup:2] Set("PJSIP/201-000002de", "CALLER=PJSIP/201") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@notify-trunk-hangup:3] UserEvent("PJSIP/201-000002de", ""EXTENSIONS_SUMMARY","Data: OUTBOUND,PJSIP/201,08444769212,OUT"") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [s@notify-trunk-hangup:4] Return("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Executing [h@trk-1-dial:4] Hangup("PJSIP/201-000002de", "") in new stack
[2022-11-18 16:45:05] VERBOSE[7771][C-00000357] pbx.c: Spawn extension (trk-1-dial, h, 4) exited non-zero on 'PJSIP/201-000002de'
Sonata Stats version “1.0.7-6”
Hi Vitalpbx Team,
Any update?
following message for similar issue
