How to upgrade to VitalPBX 4.5
I’m using Vital 4.2.0-1 version, when I try to update, we’ve received on screen:
root@attimo-poc-01:~# apt update
Hit:1 http://repo.huaweicloud.com/debian bullseye InRelease
Hit:2 http://repo.huaweicloud.com/debian bullseye-updates InRelease
Hit:3 http://repo.huaweicloud.com/debian bullseye-proposed-updates InRelease
Hit:4 http://repo.huaweicloud.com/debian bullseye-backports InRelease
Hit:5 http://repo.huaweicloud.com/debian-security bullseye-security/updates InRelease
Hit:6 Index of /vitalpbx/v4/apt/audios stable InRelease
Hit:7 Index of /vitalpbx/v4/apt/base stable InRelease
Hit:8 Index of /vitalpbx/v4/apt/core stable InRelease
Hit:10 Index of /vitalpbx/v4/apt/extras stable InRelease
Hit:11 Index of /pub/repos/apt/ bullseye-pgdg InRelease
Hit:9 https://packagecloud.io/qxip/sipcapture/debian bullseye InRelease
Hit:12 https://packagecloud.io/qxip/sipcapture/any any InRelease
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
1 package can be upgraded. Run ‘apt list --upgradable’ to see it.
root@attimo-poc-01:~# sudo apt upgrade -y
Calculating upgrade… Done
The following packages have been kept back:
base-files
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
base-files
And Vital isn’t update to latest 4.5 version.
How can I update to latest version from 4.2.0-1 version ?
Version 4.5 uses Debian v12, while 4.2.0-1 is using Debian 11 so currently no direct upgrade path exists yet.
Currently on the site they are only showing an ISO available for version 4.5 so setting up a new vm with the ISO is the only way right now to get 4.5. The VPS install script is not yet upgraded either to install version 4.5, but I would guess they will work to get the script upgraded.
Not sure if they will provide the script to do the inplace upgrade from Debian 11 to Debian 12 and then setup the new 4.5 version so until they say something else, most likely backup and restore to Debian 12 server
Email says:
Upgrading to VitalPBX 4.5 is easy and will immediately enhance your VoIP experience. Visit our website for detailed upgrade instructions and full release notes.
So I hope it will be as easy as promised and instructions are released soon.
I downloaded the iso from the link (VitalPBX 4.5), and ran it on another vm, it only installed 4.2, and not 4.5.
Do you have a working link to download the 4.5 ISO? I’m surprised they announced the release 4 days ago but still have the giant download button that says “VitalPBX 4.5” which links to 4.0.
As a test I tried doing the base upgrade to Debian 12, then updated the vitalpbx.list file from “v4” to “v4.5” after doing a little research and finding that apt repo out there. However, I might have chosen the wrong option or something else went wrong because now I get an Apache Forbidden page. I’ll just restore from my snapshot.
I’m thinking the method to build from the new ISO and then restore the backup file is the best approach to upgrade just like when we went from v3 to v4.
No, I assumed the link they had was already the 4.5 one as that is what it says in the webpage. I guess they are still working on getting the proper links in the site.
From the release notes, they have swapped over to nginx for the webserver so if you were getting apache errors it must not have been properly removed.
I guess for now the best thing is to wait until the vital devs properly publish the 4.5 stuff properly.
Install Debian 12 minimal and use the VPS install
https://repo.vitalpbx.com/vitalpbx/v4.5/pbx_installer.sh
Done a fresh install (Debian 12) and then restored the back-up (from Debian 11, PBX Version 4.2.0-1) and things seem to be working fine.
Debian 12, PBX version 4.5 installation:
wget https://repo.vitalpbx.com/vitalpbx/v4.5/pbx_installer.sh
chmod +x pbx_installer.sh
./pbx_installer.sh
Hemant J.
Warning
  • Do this at your own risk, I tested this on a lab PBX not in production.
  • Take a checkpoint/snapshot beforehand, in case you need to roll back
  • Not all add-ons are available in v4.5 yet (i.e. Hotel Management)
You can update v4 to v4.5 but you’ll need to do a full os upgrade.
Update apt sources
sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list
sed -i 's/v4/v4.5/g' /etc/apt/sources.list.d/vitalpbx.list
Stop and disable apache2 service
systemctl stop apache2.service
systemctl disable apache2.service
Do a full upgrade
apt update
apt full-upgrade
Note: You might see some nginx errors while upgrading, you can ignore those for now.
Stop and disable apache2 service again (it probably restarted during the upgrade)
Remove old packages
apt autoremove
apt remove apache2
Check nginx config nginx -t, if it gives you an error about a duplicate server, simply remove the default server config rm /etc/nginx/sites-enabled/default and restart nginx nginx -s reload
The above steps should be straightforward as there is a upgrade path from Debian 11 to 12. (Unlike from V3 to V4 where Centos > Debian)
However, @admin posted a new FAQ outlining that they recommended setting up a new machine and doing a backup restore:
I strongly encourage the VitalPBX team to reconsider this, and please work towards releasing an automated upgrade script.
Migrating from v3 to v4 was a long painful process and as a admin of multiple VitalPBX servers, I’d rather not go through that pain again…
Next, for those who wish to perform the update on the same server, we create the following Script:
I installed using the script under a fresh debian 12 installation and restored our backup. No issues so far. The ISO still downloads v4.0 as of this morning
wget https://repo.vitalpbx.com/vitalpbx/v4.5/pbx_installer.sh 5
Hello Mr Cuadra,
Thank you for the script. I have used it and currently have an information display error.
It is not displayed under System Usage (CPU/Memory), Server Uptime, Firewall and under PJSIP Endpoints/Trunks (Contacts/Match). I have attached a picture, do you have any idea how I can reactivate the displays?
Thank you very much in advance.
Have you tried clearing cache, opening in a different browser etc?
What do you see in the browser console?
What’s the output of the command below?
asterisk -rx"manager show users"
Hello, the following appears with the command.
Hello, yes, I have emptied everything and have also used different browsers and also different PCs, all the same.
Edit the file /usr/share/vitalpbx/monitor/config.ini and change the value localhost to 127.0.0.1 in the [asterisk] section. Finally, restart the vpbx-monitor service.
systemctl restart vpbx-monitor
Thanks you @miguel, this works. Will this be fixed in the script?
I agree 100%, I don’t know how other companies work but we can’t be taking production servers down for complete rebuilds every year. Between extra hardware needs to run 2 simultaneous systems to minimize down time and the overtime costs to have senior techs working late at night during down hours greatly increases the cost of ownership of VitalPBX and will cause users to start looking for alternatives.
VitalPBX needs to come up with a smoother upgrade process then continual reinstalls.
