Automation Script: Upgrading Debian 11 to 12 and VitalPBX 4 to 4.5
This script automates the process of upgrading a Debian 11 system to Debian 12 and includes a seamless migration from VitalPBX 4 to VitalPBX 4.5, along with cleanup tasks to optimize the environment.
Before upgrading your system, it is strongly recommended that you make a full backup, or at least back up any data or configuration information you can’t afford to lose. The upgrade tools and process are quite reliable, but a hardware failure in the middle of an upgrade could result in a severely damaged system.
Please read the Debian Release Notes to be clear about the risks
Please read carefully before proceeding.
:white_check_mark: Best Practices Before Running the Migration Script
1. Backup Everything
  • Take a full system backup (snapshot preferred if using a hypervisor).
  • Export the VitalPBX configuration and database manually or using the backup module on VitalPBX.
  • Backup any custom configuration files under /etc/apache2/, /etc/nginx/, /etc/firewalld/, and /etc/php/.
2. Test in a Lab Environment First
  • If possible, clone the production server and perform the migration in a test environment first.
3. Check for System Customizations
  • Review whether Apache2 has custom modules or third-party integrations.
  • Verify if any services are bound to Apache ports (80, 443).
  • Audit the firewall configuration to ensure no manual rules will be lost.
4. Prepare for Web Server Changes
  • Understand that after migration, NGINX will replace Apache2.
  • If there are manually created Apache virtual hosts, plan to migrate them to NGINX manually.
5. Clear and Update APT Sources Manually (Optional)
  • Ensure /etc/apt/sources.list and files in /etc/apt/sources.list.d/ are clean and only contain valid Debian and VitalPBX repositories.
6. Allocate Maintenance Window
  • Plan for potential downtime of at least 1-2 hours.
  • Notify users that the system will reboot after migration.
7. Monitor Migration Carefully
  • Be ready to respond manually if the script stalls or prompts for input.
  • Monitor log outputs during the script execution.
:warning: Potential Points of Failure
1. Custom Packages or Manual Changes
  • Systems with non-standard software may encounter upgrade failures.
  • Manual changes in Apache or PHP settings may not translate cleanly to NGINX.
2. Package Dependency Conflicts
  • Debian 12 introduces newer versions of libraries.
  • Some dependencies may break during or after the upgrade.
3. Apache Dependency
  • Applications still dependent on Apache2 will fail after removal.
  • VitalPBX config files (such as custom extensions) might rely on Apache if customized manually.
4. Firewall and Fail2Ban Reset
  • The script rebuilds the firewall and fail2ban configurations, which might wipe custom IP lists or rules.
5. Database Integrity Risks
  • Although the DB migration is not direct, if MariaDB upgrades encounter issues, the database may become inaccessible.
6. Human Error During Script Execution
  • If the script prompts for input and wrong choices are made, migration could fail.
7. Automatic Reboot After Migration
  • If critical errors occur during upgrade but go unnoticed, the server may reboot into an unstable system.
:rocket: How to Use
  1. Download the script file.
wget https://raw.githubusercontent.com/VitalPBX/VPBX4toVPBX45SS/refs/heads/main/vpbx4tovpbx45.sh
  1. Make the script executable:
chmod +x vpbx4tovpbx45.sh
  1. Execute the script:
./vpbx4tovpbx45.sh
  1. Configuration Prompts During Script Execution
    When running the script, you may encounter prompts like the following:
*** mpm_event.conf (Y/I/N/O/D/Z) [default=N] ? <press Enter>
*** firewalld.conf (Y/I/N/O/D/Z) [default=N] ? <press Enter>
  1. Optional: Remove All Unused Kernels from Version 5.x
dpkg --list | grep 'linux-image-5' | awk '{print $2}' | grep -v "$(uname -r)" | xargs sudo apt remove -y
:bar_chart: Post-Migration Checks
After the reboot, verify:
  • VitalPBX web interface functionality.
  • SIP registrations and call routing.
  • NGINX service status.
  • Firewall and Fail2Ban are active and correctly configured.
  • MariaDB is running and accessible.
:light_bulb: Final Advice
Do not attempt this migration directly on critical production systems without testing or snapshots.
When in doubt, plan for a clean installation of Debian 12 and migrate the VitalPBX using the backup and restore module as described in this link.
“Preparation is the difference between a successful migration and an emergency recovery!”
