Hi All
I think a great feature would be missed call email for ring groups
So if I department misses a call it should send an email
Hi All
If you have a license, like starter license, this is already possible.
I have a license
Which settings should I set if a call is missed on a ring group ?
I don’t see it in ring group settings
You can only enable missed call notification for extensions, there is a request under Wish List to add more options.
Custom Context would also be possible if you set it as final destination.
This way you can send email on missed call on Ring group.
