Hi VitalPBX
- Can you check why, queue value empty ?
I create queue 200 and queue member 201, when i call to queue 200 and receive by ext 201, value queue on crm popup is empty.
Array ( [call_type] => incoming [caller_name] => agent03 [caller_number] => 203 [callee_name] => agent02 [callee_number] => 202 [queue] => )
Please see screenshoot on below
Can you add a DID variable to CRM URL? Example : Our call center has 2 DID numbers from Trunk, I want to know from which DID source call.
How to add other variables, for example: when a customer makes a call to our call center and enters the ivr, then the customer is asked to enter the “booking id” number. I want to send the variable to vitxy CRM URL
Can you add a {UNIQID} variable or a {LINKEDID} call as a variable?
Can you add an “Automatic Popup” option? The current state of the “user” must click the CRM icon.
If “Automatic Popup” there is another option “when call ringing” or answer. -
When a user makes an outgoing call, can you add a “call_id” variable or a linkedID/UniqID variable?
