I am currently running FusionPBX with voiptalk.org as our SIP trunk provider.
I am looking to migrate to VitalPBX but i don’t seem to be able to get things up and running. Does anyone have a guide or something that may help with setting up with voiptalk.org?
If you are using the latest version of VitalPBX, keep in mind that by default, PJSIP UDP runs over port 5060, and SIP UDP runs over port 5062. So, if you have created a SIP Trunk, and your provider is sending the call over port 5060, it will never reach the trunk because, as I mentioned, SIP runs over port 5062.
Now, you have two options:
Create the trunk using PJSIP instead of SIP (recommended).
If your provider allows you, you can modify the origination SIP URI to something like “sip:YOUR_PBX_IP:5062.”
thanks for your suggestion, i setup a PJSIP trunk, and can make outgoing calls, but when making a call from an external number ( which i expect to come to my inbound route ), it does not hit my PBX at all.
Not sure what i have done wrong, when calling the number i get the auto responder from my provider saying no user available. Seems it is aware it can not send to my PBX so auto responds on my behalf.
Heh @PitzKey I checked sngrep, i can see my outbound calls showing ( which works ) but absolutely nothing showing when making an inbound call from an external number ( landline or mobile ).
Check the PBX firewall if there’s a banned IP. Also, if your PBX is behind NAT make sure that the NAT router isn’t blocking the traffic. Finally, make sure that the config on the carrier side is correct.
Yeah, checked IP Tables, nothing there, nothing fail2ban has banned. External firewall is not blocking anything related to this. the config carrier side, is as it has been for years, nothing has changed.
Like i say it works with FusionPBX just fine. But i really really wanted to make the switch.
