Busy Ringtone Not Working
Hi All & Vitalpbx,
Please confirm whether this experiment is compatible with the issue “Ringback tone while called party is on the phone”
I have 2 extensions 101 & 102
Ext 102 makes a call to the customer’s cellphone and talks.
When 102 spoke to the customer, ext 101 made a call to 102, but what happened was the ext 101 agent didn’t hear anything and immediately hangup / fast busy
The following attachments are settings in vitalpbx & logs in asterisk when 101 calls 102
Check your extension settings. The call waiting should be enabled on your extensions and call limit must be grater than one.
Hi @miguel
After update config ext 101 & 102, but 101 still not hear busy tone, 101 only hear tone ringing tone / progress tone.
asterisk log
[2022-10-27 23:10:46] VERBOSE[1606] res_rtp_asterisk.c: DTLS ECDH initialized (automatic), faster PFS enabled
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [081287264002@cos-all:1] NoOp("PJSIP/102-00000006", "More than on digit pattern") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [081287264002@cos-all:2] Gosub("PJSIP/102-00000006", "s,1(081287264002)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:1] Set("PJSIP/102-00000006", "EXTENSION=081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:2] NoOp("PJSIP/102-00000006", "Dialing 081287264002 from 102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:3] Gosub("PJSIP/102-00000006", "sub-set-global-vars,s,1(421915deea377c0d,081287264002,parking-1)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-global-vars:1] NoOp("PJSIP/102-00000006", "Setting Global Vars") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-global-vars:2] Set("PJSIP/102-00000006", "TENANT_PATH=421915deea377c0d") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-global-vars:3] Set("PJSIP/102-00000006", "PREFIX=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-global-vars:4] Set("PJSIP/102-00000006", "__PICKUPMARK=081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-global-vars:5] Set("PJSIP/102-00000006", "__PARKINGLOT=parking-1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-global-vars:6] Set("PJSIP/102-00000006", "__DYNAMIC_FEATURES=custom-features") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-global-vars:7] Set("PJSIP/102-00000006", "ICALL=no") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-global-vars:8] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:4] Gosub("PJSIP/102-00000006", "sub-set-call-vars,s,1(421915deea377c0d,081287264002,1,cos-all,ARS-all)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:1] NoOp("PJSIP/102-00000006", "Setting Call Vars") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:2] Set("PJSIP/102-00000006", "_TENANT=421915deea377c0d") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:3] Set("PJSIP/102-00000006", "_CALL_DESTINATION=081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:4] Set("PJSIP/102-00000006", "_COS_ID=1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:5] Set("PJSIP/102-00000006", "_COS_NAME=cos-all") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:6] Set("PJSIP/102-00000006", "__TRANSFER_CONTEXT=cos-all") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:7] Set("PJSIP/102-00000006", "_ARS=ARS-all") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:8] Set("PJSIP/102-00000006", "CDR(tenant)=vitalpbx") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:9] Set("PJSIP/102-00000006", "CDR(destination)=081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:10] Set("PJSIP/102-00000006", "CDR(trunk)=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:11] Set("PJSIP/102-00000006", "CDR(did)=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:12] Set("PJSIP/102-00000006", "__CALLID=1666887046.10") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:13] ExecIf("PJSIP/102-00000006", "0?Set(CHANNEL(language)=)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:14] ExecIf("PJSIP/102-00000006", "0?Set(CHANNEL(language)=)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-set-call-vars:15] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:5] Gosub("PJSIP/102-00000006", "sub-construct-cid,s,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:1] NoOp("PJSIP/102-00000006", "Building CID") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:2] Set("PJSIP/102-00000006", "_CALL_SOURCE=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:3] Set("PJSIP/102-00000006", "_CS=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:4] GotoIf("PJSIP/102-00000006", "0?return") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:5] Gosub("PJSIP/102-00000006", "sub-get-device-tree,s,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:1] NoOp("PJSIP/102-00000006", "Configuring Device Tree") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:2] Set("PJSIP/102-00000006", "DEV_TECHNOLOGY=PJSIP") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:3] GosubIf("PJSIP/102-00000006", "0?s-local,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:4] GotoIf("PJSIP/102-00000006", "0?return") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:5] GotoIf("PJSIP/102-00000006", "1?pjsip") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-get-device-tree,s,9)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:9] NoOp("PJSIP/102-00000006", "A PJSIP") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:10] Set("PJSIP/102-00000006", "DEV_USER=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:11] Goto("PJSIP/102-00000006", "build_interface") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-get-device-tree,s,13)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:13] Set("PJSIP/102-00000006", "_INTERFACE=PJSIP/102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:14] Set("PJSIP/102-00000006", "DEV_TREE=devices/PJSIP/102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-get-device-tree:15] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:6] GotoIf("PJSIP/102-00000006", "0?return") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:7] Set("PJSIP/102-00000006", "_CALL_SOURCE=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:8] Set("PJSIP/102-00000006", "_CS=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:9] ExecIf("PJSIP/102-00000006", "1?Set(CALLERID(all)="102" <102>)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:10] Set("PJSIP/102-00000006", "_CID_CONSTRUCTED=yes") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:11] NoOp("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:12] Set("PJSIP/102-00000006", "CDR(source)=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-construct-cid:13] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:6] Gosub("PJSIP/102-00000006", "set-global-tenant-vars,s,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@set-global-tenant-vars:1] NoOp("PJSIP/102-00000006", "Setting Global Vars for vitalpbx Tenant") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@set-global-tenant-vars:2] Set("PJSIP/102-00000006", "__TENANT_PATH=421915deea377c0d") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@set-global-tenant-vars:3] Set("PJSIP/102-00000006", "__TENANT_PREFIX=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@set-global-tenant-vars:4] Set("PJSIP/102-00000006", "__QUEUE_AGENTS_CONTEXT=queue-call-to-agents") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@set-global-tenant-vars:5] Set("PJSIP/102-00000006", "__FOLLOWME_CONTEXT=ext-followme") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@set-global-tenant-vars:6] Set("PJSIP/102-00000006", "__HINTS_CONTEXT=extension-hints") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@set-global-tenant-vars:7] Set("PJSIP/102-00000006", "__DEFAULT_COS=cos-all") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@set-global-tenant-vars:8] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:7] GotoIf("PJSIP/102-00000006", "0?local-dialing") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:8] NoOp("PJSIP/102-00000006", "Check if is an Emergency Call") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:9] GotoIf("PJSIP/102-00000006", "0?emergency-calls,081287264002,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:10] Gosub("PJSIP/102-00000006", "sub-lockphone-check,s,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-lockphone-check:1] NoOp("PJSIP/102-00000006", "SUB: LOCK PHONE CHECK") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-lockphone-check:2] GotoIf("PJSIP/102-00000006", "0?unlock") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-lockphone-check:3] GotoIf("PJSIP/102-00000006", "0?unlock") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-lockphone-check:4] GotoIf("PJSIP/102-00000006", "0?unlock") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-lockphone-check:5] GotoIf("PJSIP/102-00000006", "0?unlock") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-lockphone-check:6] GotoIf("PJSIP/102-00000006", "0?:unlock") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-lockphone-check,s,12)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-lockphone-check:12] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:11] Gosub("PJSIP/102-00000006", "sub-local-dialing,s,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-local-dialing:1] NoOp("PJSIP/102-00000006", "Trying to determine if is a local extension") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-local-dialing:2] GotoIf("PJSIP/102-00000006", "0?:return") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-local-dialing,s,5)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-local-dialing:5] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:12] GotoIf("PJSIP/102-00000006", "0?end-call") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@cos-all:13] Goto("PJSIP/102-00000006", "cos-all-post,081287264002,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (cos-all-post,081287264002,1)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [081287264002@cos-all-post:1] NoOp("PJSIP/102-00000006", "Outbound Route: OCDEMO") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [081287264002@cos-all-post:2] Gosub("PJSIP/102-00000006", "sub-setup-call-type,s,1(outgoing)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-setup-call-type:1] NoOp("PJSIP/102-00000006", "Determinating Call Type") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-setup-call-type:2] GotoIf("PJSIP/102-00000006", "0?return") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("PJSIP/102-00000006", "s-outgoing,1()") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-outgoing@sub-setup-call-type:1] NoOp("PJSIP/102-00000006", "Outgoing Call") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-outgoing@sub-setup-call-type:2] Set("PJSIP/102-00000006", "__CALL_TYPE=3") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-outgoing@sub-setup-call-type:3] Set("PJSIP/102-00000006", "__CALL_TYPE_LABEL=OUT") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-outgoing@sub-setup-call-type:4] GosubIf("PJSIP/102-00000006", "0?s-transit,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-outgoing@sub-setup-call-type:5] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-setup-call-type:4] Set("PJSIP/102-00000006", "__CALL_TYPE_CONFIGURED=yes") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-setup-call-type:5] Set("PJSIP/102-00000006", "CDR(calltype)=3") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-setup-call-type:6] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [081287264002@cos-all-post:3] Set("PJSIP/102-00000006", "DNID=2203081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [081287264002@cos-all-post:4] NoOp("PJSIP/102-00000006", "Start to Dial Trunks") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [081287264002@cos-all-post:5] Goto("PJSIP/102-00000006", "s-1,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (cos-all-post,s-1,1)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-1@cos-all-post:1] Set("PJSIP/102-00000006", "__CONFIGURED_BY_TENANT=yes") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-1@cos-all-post:2] Gosub("PJSIP/102-00000006", "sub-construct-cid,s-external,1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:1] NoOp("PJSIP/102-00000006", "Setting External CID") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:2] Set("PJSIP/102-00000006", "EXTENSION_NUMBER=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:3] GotoIf("PJSIP/102-00000006", "0?return") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:4] GotoIf("PJSIP/102-00000006", "0?return") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:5] Set("PJSIP/102-00000006", "EMERGENCY_CALL=no") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:6] Set("PJSIP/102-00000006", "EXTENSION_EMERGENCY_CID=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:7] Set("PJSIP/102-00000006", "DYNAMIC_EXTERNAL_CID=no") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:8] ExecIf("PJSIP/102-00000006", "1?Set(EXTENSION_EMERGENCY_CID=)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:9] ExecIf("PJSIP/102-00000006", "1?Set(DYNAMIC_EXTERNAL_CID=no)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:10] GotoIf("PJSIP/102-00000006", "0?check-emergency") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:11] Set("PJSIP/102-00000006", "EXTENSION_EXTERNAL_CID=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:12] ExecIf("PJSIP/102-00000006", "1?Set(CALLERID(all)=)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:13] GotoIf("PJSIP/102-00000006", "1?:check-emergency") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:14] Set("PJSIP/102-00000006", "TENANT_DEFAULT_EXTERNAL_CID=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:15] ExecIf("PJSIP/102-00000006", "0?Set(CALLERID(all)=)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:16] GotoIf("PJSIP/102-00000006", "0?:info") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-construct-cid,s-external,30)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:30] NoOp("PJSIP/102-00000006", "CID Name: , CID Number: ") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:31] Set("PJSIP/102-00000006", "SEND_CID=yes") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:32] ExecIf("PJSIP/102-00000006", "0?Set(CALLERID(name-pres)=prohib_passed_screen)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:33] ExecIf("PJSIP/102-00000006", "0?Set(CALLERID(num-pres)=prohib_passed_screen)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:34] Set("PJSIP/102-00000006", "__EXT_CID_CONSTRUCTED=yes") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:35] Set("PJSIP/102-00000006", "CDR(source)=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-external@sub-construct-cid:36] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s-1@cos-all-post:3] Gosub("PJSIP/102-00000006", "trk-1,2203081287264002,1(from-trk-grp)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1:1] Set("PJSIP/102-00000006", "_NTD=2203081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1:2] Gosub("PJSIP/102-00000006", "trk-1-dial,2203081287264002,1(from-trk-grp)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:1] NoOp("PJSIP/102-00000006", "Trunk: DEMO") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:2] NoOp("PJSIP/102-00000006", "Dialing: 2203081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:3] Set("PJSIP/102-00000006", "CDR(trunk)=1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:4] Set("PJSIP/102-00000006", "SKIP_HANGUP_AUDIOS=no") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:5] Gosub("PJSIP/102-00000006", "sub-setup-call-type,s,1(outgoing,no)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("PJSIP/102-00000006", "s-outgoing,1(no)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:6] ExecIf("PJSIP/102-00000006", "0?Set(CALLERID(all)=):") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:7] GotoIf("PJSIP/102-00000006", "1?:after-val-sim-calls") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:8] Set("PJSIP/102-00000006", "MAX_TENANT_CALLS=0") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:9] Set("PJSIP/102-00000006", "TENANT_NAME=vitalpbx") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:10] GotoIf("PJSIP/102-00000006", "0?:after-val-sim-calls") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (trk-1-dial,2203081287264002,18)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:18] NoOp("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:19] Set("PJSIP/102-00000006", "MAX_CALLS=2") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:20] NoOp("PJSIP/102-00000006", "Allowed Outgoing Simultaneous Calls: 2") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:21] Set("PJSIP/102-00000006", "GROUP()=trk-1") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:22] GotoIf("PJSIP/102-00000006", "0?:trk-conf") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (trk-1-dial,2203081287264002,26)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:26] NoOp("PJSIP/102-00000006", "Configuring Trunk Parameters") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:27] ExecIf("PJSIP/102-00000006", "1?Set(CHANNEL(musicclass)=default):") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:28] Set("PJSIP/102-00000006", "__TRUNK_MOH_SET=yes") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:29] Set("PJSIP/102-00000006", "DIAL_PREFIX=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:30] Set("PJSIP/102-00000006", "__TRKDIALOPTIONS=kKt") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:31] Set("PJSIP/102-00000006", "ORIGINATOR=102") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:32] Set("PJSIP/102-00000006", "RING_TIME=90") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:33] Set("PJSIP/102-00000006", "CALLED=2203081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:34] Set("PJSIP/102-00000006", "TRUNK_ENDPOINT=DEMO") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:35] NoOp("PJSIP/102-00000006", "Force Recording by Trunk") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:36] Set("PJSIP/102-00000006", "APP_RECORDING=yes") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:37] Set("PJSIP/102-00000006", "__CIDNUM=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:38] Set("PJSIP/102-00000006", "__CIDNAME=") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:39] Set("PJSIP/102-00000006", "FORCE_RECORDING=yes") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:40] Set("PJSIP/102-00000006", "FILTERED_NUMBER=2203081287264002") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:41] GotoIf("PJSIP/102-00000006", "0?:post-fax") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (trk-1-dial,2203081287264002,44)
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:44] NoOp("PJSIP/102-00000006", "End Fax Section") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] pbx.c: Executing [2203081287264002@trk-1-dial:45] Dial("PJSIP/102-00000006", "PJSIP/2203081287264002@DEMO,90,kKtU(sub-before-bridging-call^421915deea377c0d^102^2203081287264002^yes)") in new stack
[2022-10-27 23:10:46] VERBOSE[2646][C-00000004] app_dial.c: Called PJSIP/2203081287264002@DEMO
[2022-10-27 23:10:48] VERBOSE[2646][C-00000004] app_dial.c: PJSIP/DEMO-00000007 is making progress passing it to PJSIP/102-00000006
[2022-10-27 23:10:48] VERBOSE[2646][C-00000004] app_dial.c: PJSIP/102-00000006 requested media update control 26, passing it to PJSIP/DEMO-00000007
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] app_dial.c: PJSIP/DEMO-00000007 answered PJSIP/102-00000006
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] app_stack.c: PJSIP/DEMO-00000007 Internal Gosub(sub-before-bridging-call,s,1(421915deea377c0d,102,2203081287264002,yes)) start
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:1] NoOp("PJSIP/DEMO-00000007", "Executing sub-routine before connecting to the calling channel") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:2] Set("PJSIP/DEMO-00000007", "TENANT=421915deea377c0d") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:3] Set("PJSIP/DEMO-00000007", "CALLER=102") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:4] Set("PJSIP/DEMO-00000007", "CALLEE=2203081287264002") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:5] Set("PJSIP/DEMO-00000007", "FORCE_CALL_RECORDING=yes") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:6] NoOp("PJSIP/DEMO-00000007", "Check if the follow-me confirmation sub-routine needs to be executed") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:7] GotoIf("PJSIP/DEMO-00000007", "1?call-recording") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-before-bridging-call,s,9)
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:9] NoOp("PJSIP/DEMO-00000007", "Executing the call-recording sub-routine") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:10] Gosub("PJSIP/DEMO-00000007", "sub-call-recording,s,1(421915deea377c0d,102,2203081287264002,yes)") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:1] NoOp("PJSIP/DEMO-00000007", "Check if call will be recorded on tenant 421915deea377c0d") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:2] NoOp("PJSIP/DEMO-00000007", "Call Type: 3 ") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:3] Set("PJSIP/DEMO-00000007", "TENANT=421915deea377c0d") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:4] Set("PJSIP/DEMO-00000007", "CALLER=102") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:5] Set("PJSIP/DEMO-00000007", "CALLEE=2203081287264002") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:6] Set("PJSIP/DEMO-00000007", "APP_FORCE=yes") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:7] GotoIf("PJSIP/DEMO-00000007", "1?:rec_no_available") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:8] GotoIf("PJSIP/DEMO-00000007", "1?perform-recording") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-call-recording,s,14)
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:14] Gosub("PJSIP/DEMO-00000007", "sub-perform-recording,s,1") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:1] NoOp("PJSIP/DEMO-00000007", "Perform Call Recording") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:2] Set("PJSIP/DEMO-00000007", "RECORDING_ID=1666887046.11") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:3] Set("PJSIP/DEMO-00000007", "APP_TYPE=NONE") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:4] Set("PJSIP/DEMO-00000007", "AUDIO_FILE=231053-OUT-NONE-102-081287264002-1666887046.11") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:5] Set("PJSIP/DEMO-00000007", "RECORDING_FORMAT=wav") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:6] Set("PJSIP/DEMO-00000007", "__REC_FILENAME=/var/spool/asterisk/monitor/2022/10/27/231053-OUT-NONE-102-081287264002-1666887046.11.wav") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:7] GotoIf("PJSIP/DEMO-00000007", "0?:set_rec_file") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-perform-recording,s,10)
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:10] Set("PJSIP/DEMO-00000007", "CDR(recfile)=/var/spool/asterisk/monitor/2022/10/27/231053-OUT-NONE-102-081287264002-1666887046.11.wav") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:11] MixMonitor("PJSIP/DEMO-00000007", "/var/spool/asterisk/monitor/2022/10/27/231053-OUT-NONE-102-081287264002-1666887046.11.wav,b,") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-perform-recording:12] Return("PJSIP/DEMO-00000007", "") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:15] Goto("PJSIP/DEMO-00000007", "return") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (sub-call-recording,s,17)
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-call-recording:17] Return("PJSIP/DEMO-00000007", "") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:11] NoOp("PJSIP/DEMO-00000007", "Check if there's a custom sub-routine defined for executing it") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:12] GosubIf("PJSIP/DEMO-00000007", "0?before-bridging-call-hook,s,1") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] pbx.c: Executing [s@sub-before-bridging-call:13] Return("PJSIP/DEMO-00000007", "") in new stack
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] app_stack.c: Spawn extension (trk-1-in, , 1) exited non-zero on 'PJSIP/DEMO-00000007'
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] app_stack.c: PJSIP/DEMO-00000007 Internal Gosub(sub-before-bridging-call,s,1(421915deea377c0d,102,2203081287264002,yes)) complete GOSUB_RETVAL=
[2022-10-27 23:10:53] VERBOSE[2655][C-00000004] bridge_channel.c: Channel PJSIP/DEMO-00000007 joined 'simple_bridge' basic-bridge <9b0f5c9f-8cdd-4be4-9faa-4c1ff1698a80>
[2022-10-27 23:10:53] VERBOSE[2646][C-00000004] bridge_channel.c: Channel PJSIP/102-00000006 joined 'simple_bridge' basic-bridge <9b0f5c9f-8cdd-4be4-9faa-4c1ff1698a80>
[2022-10-27 23:10:53] VERBOSE[2654][C-00000004] app_mixmonitor.c: Begin MixMonitor Recording PJSIP/DEMO-00000007
[2022-10-27 23:11:41] VERBOSE[1606] res_rtp_asterisk.c: DTLS ECDH initialized (automatic), faster PFS enabled
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@cos-all:1] NoOp("PJSIP/101-00000008", "More than on digit pattern") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@cos-all:2] Gosub("PJSIP/101-00000008", "s,1(102)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:1] Set("PJSIP/101-00000008", "EXTENSION=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:2] NoOp("PJSIP/101-00000008", "Dialing 102 from 101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:3] Gosub("PJSIP/101-00000008", "sub-set-global-vars,s,1(421915deea377c0d,102,parking-1)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-global-vars:1] NoOp("PJSIP/101-00000008", "Setting Global Vars") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-global-vars:2] Set("PJSIP/101-00000008", "TENANT_PATH=421915deea377c0d") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-global-vars:3] Set("PJSIP/101-00000008", "PREFIX=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-global-vars:4] Set("PJSIP/101-00000008", "__PICKUPMARK=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-global-vars:5] Set("PJSIP/101-00000008", "__PARKINGLOT=parking-1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-global-vars:6] Set("PJSIP/101-00000008", "__DYNAMIC_FEATURES=custom-features") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-global-vars:7] Set("PJSIP/101-00000008", "ICALL=no") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-global-vars:8] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:4] Gosub("PJSIP/101-00000008", "sub-set-call-vars,s,1(421915deea377c0d,102,1,cos-all,ARS-all)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:1] NoOp("PJSIP/101-00000008", "Setting Call Vars") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:2] Set("PJSIP/101-00000008", "_TENANT=421915deea377c0d") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:3] Set("PJSIP/101-00000008", "_CALL_DESTINATION=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:4] Set("PJSIP/101-00000008", "_COS_ID=1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:5] Set("PJSIP/101-00000008", "_COS_NAME=cos-all") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:6] Set("PJSIP/101-00000008", "__TRANSFER_CONTEXT=cos-all") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:7] Set("PJSIP/101-00000008", "_ARS=ARS-all") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:8] Set("PJSIP/101-00000008", "CDR(tenant)=vitalpbx") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:9] Set("PJSIP/101-00000008", "CDR(destination)=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:10] Set("PJSIP/101-00000008", "CDR(trunk)=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:11] Set("PJSIP/101-00000008", "CDR(did)=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:12] Set("PJSIP/101-00000008", "__CALLID=1666887101.12") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:13] ExecIf("PJSIP/101-00000008", "0?Set(CHANNEL(language)=)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:14] ExecIf("PJSIP/101-00000008", "0?Set(CHANNEL(language)=)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-set-call-vars:15] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:5] Gosub("PJSIP/101-00000008", "sub-construct-cid,s,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:1] NoOp("PJSIP/101-00000008", "Building CID") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:2] Set("PJSIP/101-00000008", "_CALL_SOURCE=101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:3] Set("PJSIP/101-00000008", "_CS=101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:4] GotoIf("PJSIP/101-00000008", "0?return") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:5] Gosub("PJSIP/101-00000008", "sub-get-device-tree,s,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:1] NoOp("PJSIP/101-00000008", "Configuring Device Tree") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:2] Set("PJSIP/101-00000008", "DEV_TECHNOLOGY=PJSIP") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:3] GosubIf("PJSIP/101-00000008", "0?s-local,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:4] GotoIf("PJSIP/101-00000008", "0?return") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:5] GotoIf("PJSIP/101-00000008", "1?pjsip") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-get-device-tree,s,9)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:9] NoOp("PJSIP/101-00000008", "A PJSIP") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:10] Set("PJSIP/101-00000008", "DEV_USER=101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:11] Goto("PJSIP/101-00000008", "build_interface") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-get-device-tree,s,13)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:13] Set("PJSIP/101-00000008", "_INTERFACE=PJSIP/101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:14] Set("PJSIP/101-00000008", "DEV_TREE=devices/PJSIP/101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-get-device-tree:15] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:6] GotoIf("PJSIP/101-00000008", "0?return") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:7] Set("PJSIP/101-00000008", "_CALL_SOURCE=101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:8] Set("PJSIP/101-00000008", "_CS=101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:9] ExecIf("PJSIP/101-00000008", "1?Set(CALLERID(all)="101" <101>)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:10] Set("PJSIP/101-00000008", "_CID_CONSTRUCTED=yes") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:11] NoOp("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:12] Set("PJSIP/101-00000008", "CDR(source)=101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-construct-cid:13] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:6] Gosub("PJSIP/101-00000008", "set-global-tenant-vars,s,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@set-global-tenant-vars:1] NoOp("PJSIP/101-00000008", "Setting Global Vars for vitalpbx Tenant") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@set-global-tenant-vars:2] Set("PJSIP/101-00000008", "__TENANT_PATH=421915deea377c0d") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@set-global-tenant-vars:3] Set("PJSIP/101-00000008", "__TENANT_PREFIX=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@set-global-tenant-vars:4] Set("PJSIP/101-00000008", "__QUEUE_AGENTS_CONTEXT=queue-call-to-agents") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@set-global-tenant-vars:5] Set("PJSIP/101-00000008", "__FOLLOWME_CONTEXT=ext-followme") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@set-global-tenant-vars:6] Set("PJSIP/101-00000008", "__HINTS_CONTEXT=extension-hints") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@set-global-tenant-vars:7] Set("PJSIP/101-00000008", "__DEFAULT_COS=cos-all") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@set-global-tenant-vars:8] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:7] GotoIf("PJSIP/101-00000008", "0?local-dialing") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:8] NoOp("PJSIP/101-00000008", "Check if is an Emergency Call") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:9] GotoIf("PJSIP/101-00000008", "0?emergency-calls,102,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:10] Gosub("PJSIP/101-00000008", "sub-lockphone-check,s,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-lockphone-check:1] NoOp("PJSIP/101-00000008", "SUB: LOCK PHONE CHECK") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-lockphone-check:2] GotoIf("PJSIP/101-00000008", "0?unlock") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-lockphone-check:3] GotoIf("PJSIP/101-00000008", "0?unlock") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-lockphone-check:4] GotoIf("PJSIP/101-00000008", "0?unlock") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-lockphone-check:5] GotoIf("PJSIP/101-00000008", "0?unlock") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-lockphone-check:6] GotoIf("PJSIP/101-00000008", "0?:unlock") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-lockphone-check,s,12)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-lockphone-check:12] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@cos-all:11] Gosub("PJSIP/101-00000008", "sub-local-dialing,s,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-local-dialing:1] NoOp("PJSIP/101-00000008", "Trying to determine if is a local extension") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-local-dialing:2] GotoIf("PJSIP/101-00000008", "1?:return") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-local-dialing:3] Set("PJSIP/101-00000008", "EXTENSION_TO_DIAL=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-local-dialing:4] Goto("PJSIP/101-00000008", "102,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-local-dialing,102,1)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:1] NoOp("PJSIP/101-00000008", "Dialing Local Extension") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:2] ExecIf("PJSIP/101-00000008", "0?NoCDR()") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:3] Gosub("PJSIP/101-00000008", "sub-setup-call-type,s,1(internal)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-setup-call-type:1] NoOp("PJSIP/101-00000008", "Determinating Call Type") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-setup-call-type:2] GotoIf("PJSIP/101-00000008", "0?return") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("PJSIP/101-00000008", "s-internal,1()") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-internal@sub-setup-call-type:1] NoOp("PJSIP/101-00000008", "Internal Call") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-internal@sub-setup-call-type:2] Set("PJSIP/101-00000008", "__CALL_TYPE=1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-internal@sub-setup-call-type:3] Set("PJSIP/101-00000008", "__CALL_TYPE_LABEL=LOCAL") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-internal@sub-setup-call-type:4] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-setup-call-type:4] Set("PJSIP/101-00000008", "__CALL_TYPE_CONFIGURED=yes") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-setup-call-type:5] Set("PJSIP/101-00000008", "CDR(calltype)=1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-setup-call-type:6] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:4] Set("PJSIP/101-00000008", "_DESTINATION_STATE=INUSE") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:5] Set("PJSIP/101-00000008", "_DESTINATION_NUMBER=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:6] Set("PJSIP/101-00000008", "_DESTINATION_COS_NAME=cos-all") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:7] Gosub("PJSIP/101-00000008", "sub-check-cos-privacy,s,1(cos-all,1,cos-all)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:1] NoOp("PJSIP/101-00000008", "Checking Privacy of CoS: cos-all") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:2] GotoIf("PJSIP/101-00000008", "1?:no_local") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:3] Set("PJSIP/101-00000008", "CALLER_COS_ID=1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:4] Set("PJSIP/101-00000008", "CALLER_COS_NAME=cos-all") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:5] Set("PJSIP/101-00000008", "CALLED_COS_ID=1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:6] GotoIf("PJSIP/101-00000008", "1?same_cos") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-check-cos-privacy,s,17)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:17] NoOp("PJSIP/101-00000008", "The caller CoS and Callee CoS are the same") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:18] Goto("PJSIP/101-00000008", "return") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-check-cos-privacy,s,22)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-cos-privacy:22] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:8] Set("PJSIP/101-00000008", "DIAL_STRING=PJSIP/102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:9] Set("PJSIP/101-00000008", "DB(421915deea377c0d/LASTCALLER/102)=101") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:10] Set("PJSIP/101-00000008", "IGNORE_DIVERSIONS=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:11] Set("PJSIP/101-00000008", "QUEUE_CALL=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:12] GosubIf("PJSIP/101-00000008", "0?sub-queue-members,s,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:13] GosubIf("PJSIP/101-00000008", "0?:sub-check-diversions,s,1(predialing)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:1] NoOp("PJSIP/101-00000008", "Checking diversions for extension 102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:2] Set("PJSIP/101-00000008", "OLD_CALLER_ID="101" <101>") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:3] GosubIf("PJSIP/101-00000008", "0?:return") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:9] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:4] ExecIf("PJSIP/101-00000008", "0?Set(CALLERID(all)="102" <102>)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:5] Set("PJSIP/101-00000008", "__CALL_ORIGIN=diversions") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:6] Set("PJSIP/101-00000008", "__DIVERSION_ORIGIN=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:7] Gosub("PJSIP/101-00000008", "s-predialing,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-predialing@sub-check-diversions:1] NoOp("PJSIP/101-00000008", "Diversions on pre-dialing") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-predialing@sub-check-diversions:2] GosubIf("PJSIP/101-00000008", "0?:diversion-testing,1(Do not Disturb,DND,,,dnd)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [diversion-testing@sub-check-diversions:1] NoOp("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [diversion-testing@sub-check-diversions:2] Set("PJSIP/101-00000008", "FROM_NUMBER=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [diversion-testing@sub-check-diversions:3] GotoIf("PJSIP/101-00000008", "0?:next-diversion") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-check-diversions,diversion-testing,36)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [diversion-testing@sub-check-diversions:36] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-predialing@sub-check-diversions:3] Gosub("PJSIP/101-00000008", "diversion-testing,1(Call Forward Immeditely,CFI,,,toggle_cfi)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-predialing@sub-check-diversions:4] GosubIf("PJSIP/101-00000008", "0?:diversion-testing,1(Boss Secretray,BOSS,,,boss_secretary)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-predialing@sub-check-diversions:5] GosubIf("PJSIP/101-00000008", "0?:diversion-testing,1(Personal Assistant,PEA,sub-personal-assistant,s,1)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s-predialing@sub-check-diversions:6] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:8] Set("PJSIP/101-00000008", "CALLERID(all)="101" <101>") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:14] GotoIf("PJSIP/101-00000008", "0?post-dial") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:15] Gosub("PJSIP/101-00000008", "parse-dial-string,s,1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:1] NoOp("PJSIP/101-00000008", "Parsing dial string: PJSIP/102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:2] Set("PJSIP/101-00000008", "NEW_DIAL_STRING=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:3] Set("PJSIP/101-00000008", "COUNTER=1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:4] Set("PJSIP/101-00000008", "CURRENT_DEVICE=PJSIP/102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:5] While("PJSIP/101-00000008", "1") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:6] Set("PJSIP/101-00000008", "TECHNOLOGY=PJSIP") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:7] Set("PJSIP/101-00000008", "USER=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:8] GotoIf("PJSIP/101-00000008", "1?:regular") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:9] Goto("PJSIP/101-00000008", "regular-pjsip") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (parse-dial-string,s,12)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:12] Set("PJSIP/101-00000008", "PARSED_DEV=PJSIP/102/sip:139.192.45.67:64037;transport=ws") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:13] ExecIf("PJSIP/101-00000008", "0?Set(PARSED_DEV=PJSIP/102)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:14] Goto("PJSIP/101-00000008", "append") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (parse-dial-string,s,16)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:16] GotoIf("PJSIP/101-00000008", "1?:concatenate") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:17] Set("PJSIP/101-00000008", "NEW_DIAL_STRING=PJSIP/102/sip:139.192.45.67:64037;transport=ws") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:18] Goto("PJSIP/101-00000008", "next") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (parse-dial-string,s,21)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:21] Set("PJSIP/101-00000008", "COUNTER=2") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:22] Set("PJSIP/101-00000008", "CURRENT_DEVICE=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:23] EndWhile("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:5] While("PJSIP/101-00000008", "0") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:24] NoOp("PJSIP/101-00000008", "New dialstring: PJSIP/102/sip:139.192.45.67:64037;transport=ws") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:25] Set("PJSIP/101-00000008", "DIAL_STRING=PJSIP/102/sip:139.192.45.67:64037;transport=ws") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@parse-dial-string:26] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:16] NoOp("PJSIP/101-00000008", "Configuring Dial Settings") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:17] Set("PJSIP/101-00000008", "RING_TIME=30") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:18] Set("PJSIP/101-00000008", "RING_TIME=30") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:19] Set("PJSIP/101-00000008", "RING_TIME=30") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:20] Set("PJSIP/101-00000008", "DIAL_OPTIONS=kKt") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:21] Set("PJSIP/101-00000008", "DIAL_OPTIONS=kKt") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:22] GotoIf("PJSIP/101-00000008", "0?:answermode") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-local-dialing,102,26)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:26] Set("PJSIP/101-00000008", "ANSWER_MODE=disable") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:27] Set("PJSIP/101-00000008", "ANSWER_MODE=disable") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:28] GotoIf("PJSIP/101-00000008", "0?check-hd") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:29] ExecIf("PJSIP/101-00000008", "0?Set(EXEC_AA=yes)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:30] ExecIf("PJSIP/101-00000008", "0?Set(EXEC_AA=yes)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:31] Set("PJSIP/101-00000008", "IS_HOT_DESK=no") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:32] Set("PJSIP/101-00000008", "MOH_CLASS=default") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:33] GosubIf("PJSIP/101-00000008", "0?sub-set-moh,s,1(default)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:34] GotoIf("PJSIP/101-00000008", "0?busy-here") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:35] Set("PJSIP/101-00000008", "FORCE_RECORDING=no") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:36] Set("PJSIP/101-00000008", "DIAL_OPTIONS=kKtb(sub-before-connecting-call^s^1(421915deea377c0d^101^102^^))") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:37] Set("PJSIP/101-00000008", "DIAL_OPTIONS=kKtb(sub-before-connecting-call^s^1(421915deea377c0d^101^102^^))U(sub-before-bridging-call^421915deea377c0d^101^102^no)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:38] Set("PJSIP/101-00000008", "DIAL_OPTIONS=kKtb(sub-befor(callwaiting)e-connecting-call^s^1(421915deea377c0d^101^102^^))U(sub-before-bridging-call^421915deea377c0d^101^102^no)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:39] Set("PJSIP/101-00000008", "__TRANSFERED_CALL=TRUE") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:40] NoOp("PJSIP/101-00000008", "Enable Follow-Me Ring Time If needed") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:41] GotoIf("PJSIP/101-00000008", "0?:check-rt") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-local-dialing,102,48)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:48] GotoIf("PJSIP/101-00000008", "0?post-dial") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:49] GotoIf("PJSIP/101-00000008", "0?end_call") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:50] Gosub("PJSIP/101-00000008", "sub-udpate-virtual-dev-state,s,1(102,BUSY)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:1] NoOp("PJSIP/101-00000008", "Update Virtual Devices State") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:2] Set("PJSIP/101-00000008", "EXT_NUM=102") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:3] Set("PJSIP/101-00000008", "NEW_STATUS=BUSY") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:4] Set("PJSIP/101-00000008", "EXTENSION_ID=2") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:5] Set("PJSIP/101-00000008", "ODBC_ID=") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:6] GotoIf("PJSIP/101-00000008", "1?no_rows") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-udpate-virtual-dev-state,s,14)
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:14] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:51] Dial("PJSIP/101-00000008", "PJSIP/102/sip:139.192.45.67:64037;transport=ws,30,kKtb(sub-befor(callwaiting)e-connecting-call^s^1(421915deea377c0d^101^102^^))U(sub-before-bridging-call^421915deea377c0d^101^102^no)") in new stack
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] app_stack.c: PJSIP/102-00000009 Internal Gosub(sub-local-dialing,102,sub-befor(callwaiting)e-connecting-call,s,1(421915deea377c0d,101,102,,)) start
[2022-10-27 23:11:41] NOTICE[2738][C-00000005] pbx.c: No such label 'sub-befor' in extension '102' in context 'sub-local-dialing'
[2022-10-27 23:11:41] WARNING[2738][C-00000005] pbx.c: Priority 'sub-befor' must be a number > 0, or valid label
[2022-10-27 23:11:41] ERROR[2738][C-00000005] app_stack.c: Gosub address is invalid: 'sub-local-dialing,102,sub-befor(callwaiting)e-connecting-call,s,1(421915deea377c0d,101,102,,)'
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] app_dial.c: Called PJSIP/102/sip:139.192.45.67:64037;transport=ws
[2022-10-27 23:11:41] VERBOSE[2738][C-00000005] app_dial.c: PJSIP/102-00000009 is ringing
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] app_dial.c: Nobody picked up in 30000 ms
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:52] Set("PJSIP/101-00000008", "_CALL_STATUS=NOANSWER") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:53] Set("PJSIP/101-00000008", "_CALL_STATUS=BUSY") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:54] Gosub("PJSIP/101-00000008", "sub-udpate-virtual-dev-state,s,1(102,NOT_INUSE)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:1] NoOp("PJSIP/101-00000008", "Update Virtual Devices State") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:2] Set("PJSIP/101-00000008", "EXT_NUM=102") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:3] Set("PJSIP/101-00000008", "NEW_STATUS=NOT_INUSE") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:4] Set("PJSIP/101-00000008", "EXTENSION_ID=2") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:5] Set("PJSIP/101-00000008", "ODBC_ID=") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:6] GotoIf("PJSIP/101-00000008", "1?no_rows") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-udpate-virtual-dev-state,s,14)
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-udpate-virtual-dev-state:14] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:55] Goto("PJSIP/101-00000008", "check-post-diversions") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-local-dialing,102,57)
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:57] GosubIf("PJSIP/101-00000008", "0?:sub-check-diversions,s,1(postdialing)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:1] NoOp("PJSIP/101-00000008", "Checking diversions for extension 102") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:2] Set("PJSIP/101-00000008", "OLD_CALLER_ID="101" <101>") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:3] GosubIf("PJSIP/101-00000008", "0?:return") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:9] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:4] ExecIf("PJSIP/101-00000008", "0?Set(CALLERID(all)="102" <102>)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:5] Set("PJSIP/101-00000008", "__CALL_ORIGIN=diversions") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:6] Set("PJSIP/101-00000008", "__DIVERSION_ORIGIN=102") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:7] Gosub("PJSIP/101-00000008", "s-postdialing,1") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s-postdialing@sub-check-diversions:1] NoOp("PJSIP/101-00000008", "Diversions on post-dialing") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s-postdialing@sub-check-diversions:2] Gosub("PJSIP/101-00000008", "diversion-testing,1(Follow Me,FWM,ext-followme,FW102,follow_me)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [diversion-testing@sub-check-diversions:1] NoOp("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [diversion-testing@sub-check-diversions:2] Set("PJSIP/101-00000008", "FROM_NUMBER=102") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [diversion-testing@sub-check-diversions:3] GotoIf("PJSIP/101-00000008", "0?:next-diversion") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-check-diversions,diversion-testing,36)
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [diversion-testing@sub-check-diversions:36] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s-postdialing@sub-check-diversions:3] GosubIf("PJSIP/101-00000008", "0?call-forward,1(CFU,toggle_cfu)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s-postdialing@sub-check-diversions:4] GosubIf("PJSIP/101-00000008", "0?call-forward,1(CFU,toggle_cfu)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s-postdialing@sub-check-diversions:5] GosubIf("PJSIP/101-00000008", "1?call-forward,1(CFB,toggle_cfb)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [call-forward@sub-check-diversions:1] NoOp("PJSIP/101-00000008", "CALL FOWARDING") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [call-forward@sub-check-diversions:2] Set("PJSIP/101-00000008", "FROM_NUMBER=102") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [call-forward@sub-check-diversions:3] GotoIf("PJSIP/101-00000008", "0?:return") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-check-diversions,call-forward,14)
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [call-forward@sub-check-diversions:14] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s-postdialing@sub-check-diversions:6] GosubIf("PJSIP/101-00000008", "0?call-forward,1(CFN,toggle_cfn)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s-postdialing@sub-check-diversions:7] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-check-diversions:8] Set("PJSIP/101-00000008", "CALLERID(all)="101" <101>") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:58] GotoIf("PJSIP/101-00000008", "0?end_call") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:59] GotoIf("PJSIP/101-00000008", "0?end_call") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:60] GotoIf("PJSIP/101-00000008", "0?end_call") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:61] Gosub("PJSIP/101-00000008", "sub-leave-vm,s,1") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-leave-vm:1] NoOp("PJSIP/101-00000008", "Leave Voicemail") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-leave-vm:2] Set("PJSIP/101-00000008", "VM_OPTIONS=b") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-leave-vm:3] Set("PJSIP/101-00000008", "VM_OPTIONS=b") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-leave-vm:4] GotoIf("PJSIP/101-00000008", "0?:vm_disabled") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-leave-vm,s,8)
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-leave-vm:8] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:62] GosubIf("PJSIP/101-00000008", "1?sub-request-cc,s,1") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-request-cc:1] NoOp("PJSIP/101-00000008", "Trying to request call completion") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-request-cc:2] GotoIf("PJSIP/101-00000008", "1?:return") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-request-cc:3] GotoIf("PJSIP/101-00000008", "0?:return") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-request-cc,s,11)
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-request-cc:11] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [102@sub-local-dialing:63] ExecIf("PJSIP/101-00000008", "1?Busy(5)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Spawn extension (sub-local-dialing, 102, 63) exited non-zero on 'PJSIP/101-00000008'
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:1] NoOp("PJSIP/101-00000008", "Finishing the call") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:2] Gosub("PJSIP/101-00000008", "sub-udpate-virtual-dev-state,s,1(102,NOT_INUSE)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:3] GosubIf("PJSIP/101-00000008", "0?dynamic-routing-connected,s,1(NOANSWER,101)") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:4] GotoIf("PJSIP/101-00000008", "0?call_ended") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:5] GosubIf("PJSIP/101-00000008", "0?wake-up-no-answered,s,1") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:6] Gosub("PJSIP/101-00000008", "sub-call-completion-check,s,1") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-call-completion-check:1] NoOp("PJSIP/101-00000008", "FEATURE: CALL COMPLETION CHECK") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-call-completion-check:2] Set("PJSIP/101-00000008", "CC_MODE=none") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-call-completion-check:3] Set("PJSIP/101-00000008", "CC_MODE=none") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-call-completion-check:4] Set("PJSIP/101-00000008", "CC_MODE=none") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-call-completion-check:5] GotoIf("PJSIP/101-00000008", "1?end") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (sub-call-completion-check,s,17)
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@sub-call-completion-check:17] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:7] NoOp("PJSIP/101-00000008", "Call ended") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:8] Gosub("PJSIP/101-00000008", "notify-call-hangup,s,1") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@notify-call-hangup:1] Verbose("PJSIP/101-00000008", "0, Extension Hangup") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] app_verbose.c:  Extension Hangup
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@notify-call-hangup:2] GotoIf("PJSIP/101-00000008", "1?:incoming") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@notify-call-hangup:3] UserEvent("PJSIP/101-00000008", ""EXTENSIONS_SUMMARY","Data: EXT_TO_EXT,PJSIP/101-0000001v,,LOCAL"") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@notify-call-hangup:4] Goto("PJSIP/101-00000008", "end") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx_builtins.c: Goto (notify-call-hangup,s,7)
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [s@notify-call-hangup:7] Return("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Executing [h@sub-local-dialing:9] Hangup("PJSIP/101-00000008", "") in new stack
[2022-10-27 23:12:11] VERBOSE[2738][C-00000005] pbx.c: Spawn extension (sub-local-dialing, h, 9) exited non-zero on 'PJSIP/101-00000008'
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] bridge_channel.c: Channel PJSIP/102-00000006 left 'simple_bridge' basic-bridge <9b0f5c9f-8cdd-4be4-9faa-4c1ff1698a80>
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Spawn extension (trk-1-dial, 2203081287264002, 45) exited non-zero on 'PJSIP/102-00000006'
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [h@trk-1-dial:1] GosubIf("PJSIP/102-00000006", "0?sub-outbound-queue-call,s,1") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [h@trk-1-dial:2] Gosub("PJSIP/102-00000006", "dynamic-routing-out,s,1(102,2203081287264002,ANSWER,1)") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:1] NoOp("PJSIP/102-00000006", "Test if save on dynamic routing list") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:2] Set("PJSIP/102-00000006", "CALLER=102") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:3] Set("PJSIP/102-00000006", "CALLED=2203081287264002") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:4] Set("PJSIP/102-00000006", "STATUS=ANSWER") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:5] Set("PJSIP/102-00000006", "TRKID=1") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:6] Set("PJSIP/102-00000006", "ALLOW_DR=no") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:7] Set("PJSIP/102-00000006", "DYNROUTING_OMC=yes") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:8] GotoIf("PJSIP/102-00000006", "0?:comeback") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx_builtins.c: Goto (dynamic-routing-out,s,10)
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@dynamic-routing-out:10] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [h@trk-1-dial:3] Gosub("PJSIP/102-00000006", "notify-trunk-hangup,s,1") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@notify-trunk-hangup:1] Verbose("PJSIP/102-00000006", "0, Trunk Hangup") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] app_verbose.c:  Trunk Hangup
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@notify-trunk-hangup:2] Set("PJSIP/102-00000006", "CALLER=PJSIP/102") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@notify-trunk-hangup:3] UserEvent("PJSIP/102-00000006", ""EXTENSIONS_SUMMARY","Data: OUTBOUND,PJSIP/102,081287264002,OUT"") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [s@notify-trunk-hangup:4] Return("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Executing [h@trk-1-dial:4] Hangup("PJSIP/102-00000006", "") in new stack
[2022-10-27 23:12:24] VERBOSE[2646][C-00000004] pbx.c: Spawn extension (trk-1-dial, h, 4) exited non-zero on 'PJSIP/102-00000006'
[2022-10-27 23:12:24] VERBOSE[2655][C-00000004] bridge_channel.c: Channel PJSIP/DEMO-00000007 left 'simple_bridge' basic-bridge <9b0f5c9f-8cdd-4be4-9faa-4c1ff1698a80>
[2022-10-27 23:12:24] VERBOSE[2654][C-00000004] app_mixmonitor.c: MixMonitor close filestream (mixed)
[2022-10-27 23:12:24] VERBOSE[2654][C-00000004] app_mixmonitor.c: End MixMonitor Recording PJSIP/DEMO-00000007
Enable the “Ringing Tone” option in your Dial Profile!
Is this disabled by default or did he disable it some time?
It comes enabled by default. I imagine he disabled the option for some reason!
There is a negative impact if the “Ringing Tone” option is set to “Yes” when making calls to external numbers or to customers.
The experiment I did with the flow call is as follows
  • Agent Call (103) to Customer (6266888888)
  • Ringing on Customer
  • Customer Reject Call
  1. Ringing Tone → Yes, call from ext : 103 to 6266888888 (customer phone number)
Agents can’t listen to notifications from the telco site. agent only listen to fake ringing until call timeout / terminated
  1. Ringing Tone → No, call from ext : 103 to 6266888888 (customer phone number)
Agents can listen to notifications from the telco side. agent listen nofication “The number you are calling is busy, please try a few minutes”
I attach the sngrep of the above experiment
I’ve done what you asked, actually the experiment I did was right or not?
ext 101 call out to customer number → agent talking with customer . While they are talking ext 102 call ext 101.
Can you give an explanation under normal conditions what it should be like?
Did you know that you can create multiple dial profiles? So, you can assign or leave the default for your extensions, a create a new one for your trunks.
On the other hand, the “r” flag ( Ringing Tone) is required to produce the tones according to the tone zone configured on your PJSIP Settings.
OK @miguel
sorry i just understand custom dial profile. :sob:
If the busy ringtone is not working on your business phone system, there are several potential reasons for this issue. Here are some troubleshooting steps you can try:
  1. Check the phone’s settings: Make sure the busy ringtone is enabled in the phone’s settings. Depending on the type of phone and system you are using, the location of this setting may vary.
  2. Check the call forwarding settings: If you have call forwarding enabled, it may be overriding the busy ringtone. Check your call forwarding settings to ensure that they are not interfering with the busy signal.
  3. Test with another phone: If possible, try testing the busy signal with another phone to see if the issue is isolated to a single device or if it is a system-wide problem.
  4. Contact your phone system provider: If none of the above steps resolve the issue, contact your phone system provider for assistance. They may need to troubleshoot the system or perform a software update to resolve the issue.
Overall, the best approach to resolving this issue will depend on the specifics of your phone system and the nature of the problem. However, the steps outlined above should help you get started in diagnosing the problem and finding a solution.
