Bluetooth Headset - VitXi
+1
which device (headset) one is best ?
which action you can ?
i tested Blackwire 323.1
it can answer, mute, unmute, control volume
is it possible hangup, hold. it depend on device ?
we’re looking for best WebHID Headset device for Vitxi.
thanks
Just an update, since updating VitXi to the last version (4.0.0-7) it’s giving the error below.
Despiste that, it still has the symptoms describe above.
Thanks in advance for the help.
João Valente
Hello, sir.
Thank you for reporting this problem,
We will fix it as soon as possible,
We are also working on improvements to this feature,
Regards!
Do you have any update regarding this issue?
Thanks in advance,
João valente
Regarding the situation in title.
In our company, we use VitalPBX, your Softphone VitXi and we have two situatons regarding bluetooth headsets:
We are using the Poly Voyager 5200 UC and we are able to answer /mute throw the headset but we are not able to end the call.
The other situation, we are testing the Handset Gigaset ION and VitXi recognize as an HID equipment but if I press the answer button it drops the call.
Gigaset has this SDK information.
FAQ ION - USB HID commands - Gigaset PRO - Public Wiki - Confluence.
If you could help to see to see why this happen.
Thnaks in advance,
João Valente
Hello Maynor,
Regarding the handset Gigaset ION. Do you think the link help’s solving the situation?
João Valente
Sorry sir, we have been prioritizing new features and other reports sent to us by our customers.
We will review the documentation you have sent us.
Is there any headset (bluetooth or wired) make/model that is known to have both answer and hangup functionallity that is fully operational and tested?
This has become a huge issue with a customer.
We will be conducting internal tests related to this feature (hangup) to confirm its functionality.
The hangup action has been implemented, please update to the latest version of VitXi:
The latest version of VitXi is now available! Check out the details in the post below: VitXi 4.6.0 – Major Release: Inboxes, WhatsApp/SMS, High-Performance Mode & More!
Tested Headsets: HID Headset Integration with VitXi WebRTC
Interesting discussion! I’ve also noticed that some Bluetooth headsets can behave inconsistently with PBX systems, especially when handling multiple simultaneous calls. Sometimes a firmware update or adjusting audio profiles can improve stability. Curious to hear if others found a reliable setup.
Bluetooth headsets can be tricky with PBX setups, especially when audio routing and device states aren’t reported consistently. I’ve seen similar issues where everything looks connected, but the actual status doesn’t update reliably. In other systems that rely on tracking states in real time, having clear device feedback makes a big difference. Curious if anyone found a stable combination of firmware and settings that works well here.
Hello, do you have plans to test an wireless earhook headset? In our company we use the Poly Voyager 5200 UC Series, but it’s not supported and creates some issues with Vitxi. Could you test the Yealink BH71?
Hello Sir,
We are in the process of obtaining the Yealink BH71 in order to perform the necessary testing and implementation.
Hello Maynor,
Do you have any updates regarding the testing of Yealink BH71 to be use with VitXi?
Best Regards,
João Valente
Hello Sir,
Apologies for the delayed response.
We are still in the process of obtaining the headsets. I will keep you informed and let you know as soon as the integration becomes available.
