I’m trying to use the provisionig for the AAstra IP Phones, but able to do so. Does anyone know if it’s possible or id there ir a how to?
What model are you trying to provision?
HI,
I have AAstra 6731i, 6755i, 9143i.
we have a video tutorial Configure your Phones directly from VitalPBX - Provisioning Module - YouTube, the steps are the same for the aastra models
Thanks for the video. I did auto provision a couple of model for the brand yealink with no problems. Then I saw that video in case a missing someting. Then try for those model I mention for thre brand Aastra but nothing happend. If I go the aastra gui under Configuration Server Settings - > HTTP Server/Path/Port it show the right info.
Have you tried to factory reset before provisioning?
Yes… I did factory reset on the 3 models 6731i, 6755i, 9143i. I was thinking to upgrade the firmware.
I did try with yealink phone and the provisioning works just fine, no problems, but if I do the same steps for the aastra phone it does not get configured. I did check out the link of the video and I did the same steps.
All the aastra model have been updated to the latest firmware available.
After I prepare que phone provisioning after I reboot the phone if I go the GUI and check the configuration server settings HTTP Server and HTTP Path it show the provisioning url that I was given on vitalpbx which I set on the dhcp option 66.
We’ll investigate if there’s a missing parameter on the provision file
I appreciated the help. The customer has a lot of these phones and that’s why we bought these module.
Please try adding this content on the template’s custom tab and try again to provision
@foreach ($dssKeys as $key)
topsoftkey{{ $loop->iteration }} label: {{ $key[‘label’] ?? null }}
topsoftkey{{ $loop->iteration }} line: {{ $key[‘line’] ?? null }}
topsoftkey{{ $loop->iteration }} type: {{ $key[‘type’] ?? null }}
topsoftkey{{ $loop->iteration }} value: {{ $key[‘value’] ?? null }}
@endforeach
Like this
#Date / Time Settings
time zone name: {{ $timezone }}
date format: {{ $timeFormat ?? 0 }}
time format: {{ $dateFormat ?? 0 }}
#Language
language 1: lang_{{ $language }}.txt
language: {{ $language == ‘en’ ? 0 : 1 }}
#SIP Settings
sip transport protocol: {{ $settings[‘sip_transport’] ?? ‘1’ }}
#Accounts
@foreach ($accounts as $account)
sip line{{ $loop->iteration }} screen name: {{ $account[‘description’] ?? null }}
sip line{{ $loop->iteration }} display name: {{ $account[‘description’] ?? null }}
sip line{{ $loop->iteration }} auth name: {{ $account[‘device_name’] ?? null }}
sip line{{ $loop->iteration }} password: {{ $account[‘secret’] ?? null }}
sip line{{ $loop->iteration }} mode: 0
sip line{{ $loop->iteration }} registrar ip: {{ $account[‘sip_domain’] ?? ‘0.0.0.0’ }}
sip line{{ $loop->iteration }} registrar port: {{ $account[‘sip_port’] ?? ‘0’ }}
sip line{{ $loop->iteration }} proxy ip: {{ $account[‘sip_proxy’] ?? ‘0.0.0.0’ }}
sip line{{ $loop->iteration }} proxy port: {{ $account[‘sip_proxy_port’] ?? ‘0’ }}
@endforeach
#Programmable keys
prgkey{{ $loop->iteration }} label: {{ $key[‘label’] ?? null }}
prgkey{{ $loop->iteration }} line: {{ $key[‘line’] ?? null }}
prgkey{{ $loop->iteration }} type: {{ $key[‘type’] ?? null }}
prgkey{{ $loop->iteration }} value: {{ $key[‘value’] ?? null }}
@endforeach
@endforeach
#Firmware
firmware_server: {{ $connectionSettings[‘firmware_path’] ?? null }}
download protocol: HTTP
#Admin password
admin password: {{ $adminPassword }}
This is the message that I get after adding those lines on the customer for the tempalte for 6755i. I already have a phone device using that template.
That charater that I’m showing it was different. I change it to ’ and I did not get the error. I reboot the phone but same result it did not get configured.
Can you export a valid configuration file from your phone?
Well, I have the config file from provisioni test I did from a XORCOM Pbx in which the phone got configured without problem.
admin password: 22222
audio mode: 0
auto resync mode: 3
call forward disabled: 1
date format: 0
directed call pickup: 1
directed call pickup prefix: **
dynamic sip: 1
http path: /
http port: 80
sip accept out of order requests: 1
sip blf subscription period: 600
sip contact matching: 2
sip customized codec: payload=9;ptime=20;silsupp=on,payload=0;ptime=20;silsupp=on,payload=8;ptime=20;silsupp=on
sip dial plan: “x+#|xx+*”
sip digit timeout: 4
sip gruu: 0
sip instance id: 0
sip intercom line: 1
sip intercom prefix code: *80
sip intercom type: 2
sip line1 auth name: 6030
sip line1 display name: MalvinTestFOP2
sip line1 mode: 0
sip line1 password: kabBnMvs55qseT
sip line1 proxy ip: 172.16.250.20
sip line1 proxy port: 5060
sip line1 registrar ip: 172.16.250.20
sip line1 registrar port: 5060
sip line1 screen name: MalvinTestFOP2
sip line1 screen name 2: Ext.
sip line1 user name: 6030
sip line1 vmail: *97
sip line2 proxy port: 5060
sip line2 screen name 2: Ext.
sip line2 vmail: *97
sip line3 proxy port: 5060
sip line3 screen name 2: Ext.
sip line3 vmail: *97
sip line4 proxy port: 5060
sip line4 screen name 2: Ext.
sip line4 vmail: *97
sip line5 proxy port: 5060
sip line5 screen name 2: Ext.
sip line5 vmail: *97
sip line6 proxy port: 5060
sip line6 screen name 2: Ext.
sip line6 vmail: *97
sip line7 proxy port: 5060
sip line7 screen name 2: Ext.
sip line7 vmail: *97
sip line8 proxy port: 5060
sip line8 screen name 2: Ext.
sip line8 vmail: *97
sip line9 proxy port: 5060
sip line9 screen name 2: Ext.
sip line9 vmail: *97
sip transport protocol: 1
sip xml notify event: 1
time format: 0
time server disabled: 0
time zone code: CST
Time Zone Name: CR-Costa Rica
tone set: 0
xml application title: Applications
This a config file from template for a T23G yealink phone. This phone works without any problem in VITALPBX provisioning (version 3 and 4).
#!version:1.0.0.1
##File header “#!version:1.0.0.1” can not be edited or deleted, and must be placed in the first line.##
##account.X.*:(T5XW/T54S/T48G/T48S/T46G/T46S/T29G/T46U/T48U: X ranges from 1 to 16. T52S/T42G/T42S/T43U: X ranges from 1 to 12. T41P/T41S/T27P/T27G/T41U/T42U: X ranges from 1 to 6. T40P/T40G/T23P/T23G: X ranges from 1 to 3. T21(P) E2: X ranges from 1 to 2.)##
@continue(!$account[‘secret’])
account.{{ $loop->iteration }}.phone_setting.call_appearance.transfer_via_new_linekey =
account.{{ $loop->iteration }}.phone_setting.call_appearance.conference_via_new_linekey =
###V85##
account.{{ $loop->iteration }}.networkconf_type =
account.{{ $loop->iteration }}.anonymous_call.server_base_only =
account.{{ $loop->iteration }}.send_anonymous_rejection_code =
account.{{ $loop->iteration }}.anonymous_reject_offcode =
account.{{ $loop->iteration }}.anonymous_reject_oncode =
account.{{ $loop->iteration }}.reject_anonymous_call=
account.{{ $loop->iteration }}.anonymous_call_offcode =
account.{{ $loop->iteration }}.anonymous_call_oncode =
account.{{ $loop->iteration }}.anonymous_call =
account.{{ $loop->iteration }}.send_anonymous_code =
account.{{ $loop->iteration }}.music_server_uri =
account.{{ $loop->iteration }}.music_on_hold_type =
account.{{ $loop->iteration }}.auto_label.rule =
account.{{ $loop->iteration }}.auto_label.enable =
account.{{ $loop->iteration }}.number_of_linekey =
account.{{ $loop->iteration }}.phone_setting.call_appearance.calls_per_linekey =
account.{{ $loop->iteration }}.codec.ilbc_15_2kbps.priority =
account.{{ $loop->iteration }}.codec.ilbc_15_2kbps.enable =
account.{{ $loop->iteration }}.codec.ilbc_13_33kbps.priority =
account.{{ $loop->iteration }}.codec.ilbc_13_33kbps.enable =
account.{{ $loop->iteration }}.codec.pcma.enable =
account.{{ $loop->iteration }}.codec.pcma.priority =
account.{{ $loop->iteration }}.codec.pcmu.enable =
account.{{ $loop->iteration }}.codec.pcmu.priority =
account.{{ $loop->iteration }}.codec.opus.priority =
account.{{ $loop->iteration }}.codec.opus.enable =
account.{{ $loop->iteration }}.codec.opus.para =
account.{{ $loop->iteration }}.codec.g726_40.enable =
account.{{ $loop->iteration }}.codec.g726_40.priority =
account.{{ $loop->iteration }}.codec.g726_32.enable =
account.{{ $loop->iteration }}.codec.g726_32.priority =
account.{{ $loop->iteration }}.codec.g726_24.enable =
account.{{ $loop->iteration }}.codec.g726_24.priority =
account.{{ $loop->iteration }}.codec.g726_16.enable =
account.{{ $loop->iteration }}.codec.g726_16.priority =
account.{{ $loop->iteration }}.codec.g723_63.priority =
account.{{ $loop->iteration }}.codec.g723_63.enable =
account.{{ $loop->iteration }}.codec.g723_53.priority =
account.{{ $loop->iteration }}.codec.g723_53.enable =
account.{{ $loop->iteration }}.codec.g729.priority =
account.{{ $loop->iteration }}.codec.g729.enable =
account.{{ $loop->iteration }}.codec.g722.priority =
account.{{ $loop->iteration }}.codec.g722.enable =
account.{{ $loop->iteration }}.codec.G722_1_24kpbs.priority =
account.{{ $loop->iteration }}.codec.G722_1_24kpbs.enable =
account.{{ $loop->iteration }}.codec.G722_1c_24kpbs.priority =
account.{{ $loop->iteration }}.codec.G722_1c_24kpbs.enable =
account.{{ $loop->iteration }}.codec.G722_1c_32kpbs.priority =
account.{{ $loop->iteration }}.codec.G722_1c_32kpbs.enable =
account.{{ $loop->iteration }}.codec.G722_1c_48kpbs.priority =
account.{{ $loop->iteration }}.codec.G722_1c_48kpbs.enable =
account.{{ $loop->iteration }}.enable = {{ isset($account[‘secret’]) ? 1 : 0 }}
account.{{ $loop->iteration }}.label = {{ $account[‘description’] ?? null }}
account.{{ $loop->iteration }}.display_name = {{ $account[‘description’] ?? null }}
account.{{ $loop->iteration }}.auth_name = {{ $account[‘device_name’] ?? null }}
account.{{ $loop->iteration }}.user_name = {{ $account[‘device_name’] ?? null }}
account.{{ $loop->iteration }}.password = {{ $account[‘secret’] ?? null }}
account.{{ $loop->iteration }}.sip_server.1.address = {{ $account[‘sip_domain’] ?? null }}
account.{{ $loop->iteration }}.sip_server.1.port = {{ $account[‘sip_port’] ?? 5060 }}
account.{{ $loop->iteration }}.sip_server.1.transport_type = {{ $account[‘protocol’] ?? 0 }}
account.{{ $loop->iteration }}.sip_server.1.expires = 3600
account.{{ $loop->iteration }}.sip_server.1.retry_counts = 3
account.{{ $loop->iteration }}.sip_server.2.address =
account.{{ $loop->iteration }}.sip_server.2.port =
account.{{ $loop->iteration }}.sip_server.2.transport_type =
account.{{ $loop->iteration }}.sip_server.2.expires = 3600
account.{{ $loop->iteration }}.sip_server.2.retry_counts = 3
account.{{ $loop->iteration }}.outbound_proxy_enable = {{ isset($account[‘sip_proxy’]) ? 1 : 0 }}
account.{{ $loop->iteration }}.outbound_proxy.1.address = {{ $account[‘sip_proxy’] ?? null }}
account.{{ $loop->iteration }}.outbound_proxy.1.port = {{ $account[‘sip_proxy_port’] ?? 5060 }}
account.{{ $loop->iteration }}.outbound_proxy.2.address =
account.{{ $loop->iteration }}.outbound_proxy.2.port =
account.{{ $loop->iteration }}.outbound_proxy_fallback_interval = 3600
account.{{ $loop->iteration }}.nat.nat_traversal = 0
account.{{ $loop->iteration }}.auto_answer =
account.{{ $loop->iteration }}.nat.udp_update_enable = 1
account.{{ $loop->iteration }}.nat.udp_update_time = 30
account.{{ $loop->iteration }}.nat.rport = 0
account.{{ $loop->iteration }}.dtmf.type = 1
account.{{ $loop->iteration }}.dtmf.info_type = 1
account.{{ $loop->iteration }}.dtmf.dtmf_payload = 101
account.{{ $loop->iteration }}.100rel_enable= 0
account.{{ $loop->iteration }}.subscribe_register =
account.{{ $loop->iteration }}.cid_source =
account.{{ $loop->iteration }}.enable_user_equal_phone =
account.{{ $loop->iteration }}.srtp_encryption =
account.{{ $loop->iteration }}.ptime =
account.{{ $loop->iteration }}.register_line =
account.{{ $loop->iteration }}.register_mac =
account.{{ $loop->iteration }}.reg_fail_retry_interval =
account.{{ $loop->iteration }}.unregister_on_reboot =
account.{{ $loop->iteration }}.session_timer.refresher =
account.{{ $loop->iteration }}.session_timer.expires =
account.{{ $loop->iteration }}.session_timer.enable = 0
account.{{ $loop->iteration }}.conf_type =
account.{{ $loop->iteration }}.sip_server_type =
##V83 Add
account.{{ $loop->iteration }}.srtp.unencrypted_rtcp.enable = 0
account.{{ $loop->iteration }}.srtp.unencrypted_rtp.enable = 0
account.{{ $loop->iteration }}.sip_server_mode = 0
account.{{ $loop->iteration }}.outbound_proxy.1.register_on_enable = 0
account.{{ $loop->iteration }}.outbound_proxy.1.failback_timeout = 3600
account.{{ $loop->iteration }}.outbound_proxy.1.failback_mode = 0
account.{{ $loop->iteration }}.outbound_proxy.1.retry_counts = 3
account.{{ $loop->iteration }}.outbound_proxy.1.only_signal_with_registered = 0
account.{{ $loop->iteration }}.outbound_proxy.1.failback_subscribe.enable = 0
account.{{ $loop->iteration }}.outbound_proxy.1.invite_retry_counts = 3
account.{{ $loop->iteration }}.sip_server.1.register_on_enable = 0
account.{{ $loop->iteration }}.sip_server.1.failback_timeout = 3600
account.{{ $loop->iteration }}.sip_server.1.failback_mode = 0
account.{{ $loop->iteration }}.sip_server.1.failback_subscribe.enable = 0
account.{{ $loop->iteration }}.sip_server.1.only_signal_with_registered = 0
account.{{ $loop->iteration }}.sip_server.1.invite_retry_counts = 3
account.{{ $loop->iteration }}.outbound_proxy.2.register_on_enable = 0
account.{{ $loop->iteration }}.outbound_proxy.2.failback_timeout = 3600
account.{{ $loop->iteration }}.outbound_proxy.2.failback_mode = 0
account.{{ $loop->iteration }}.outbound_proxy.2.retry_counts = 3
account.{{ $loop->iteration }}.outbound_proxy.2.only_signal_with_registered = 0
account.{{ $loop->iteration }}.outbound_proxy.2.failback_subscribe.enable = 0
account.{{ $loop->iteration }}.outbound_proxy.2.invite_retry_counts = 3
account.{{ $loop->iteration }}.sip_server.2.register_on_enable = 0
account.{{ $loop->iteration }}.sip_server.2.failback_timeout = 3600
account.{{ $loop->iteration }}.sip_server.2.failback_mode = 0
account.{{ $loop->iteration }}.sip_server.2.failback_subscribe.enable = 0
account.{{ $loop->iteration }}.sip_server.2.only_signal_with_registered = 0
account.{{ $loop->iteration }}.sip_server.2.invite_retry_counts = 3
account.{{ $loop->iteration }}.static_cache_pri = 0
account.{{ $loop->iteration }}.dns_cache_type = 1
account.{{ $loop->iteration }}.naptr_build = 0
account.{{ $loop->iteration }}.fallback.timeout = 120
account.{{ $loop->iteration }}.fallback.redundancy_type = 0
account.{{ $loop->iteration }}.reg_failed_retry_max_time = 60
account.{{ $loop->iteration }}.reg_failed_retry_min_time = 0
account.{{ $loop->iteration }}.redundancy_with_reg_fail.enable = 0
##V83 Add
account.{{ $loop->iteration }}.sip_server.1.outbound_proxy_enable = 0
account.{{ $loop->iteration }}.sip_server.2.outbound_proxy_enable = 0
account.{{ $loop->iteration }}.contact_take_line_param = 0
account.{{ $loop->iteration }}.update_ack_while_dialing = 0
account.{{ $loop->iteration }}.srtp_lifetime = 0
account.{{ $loop->iteration }}.third_part_request_with_route.enable = 0
account.{{ $loop->iteration }}.insert_outbound_in_route.enable = 0
account.{{ $loop->iteration }}.path.enable = 0
account.{{ $loop->iteration }}.sub_fail_retry_interval = 30
account.{{ $loop->iteration }}.transfer_refer_to_contact_header.enable =
account.{{ $loop->iteration }}.hold_use_inactive = 0
account.{{ $loop->iteration }}.gruu.enable = 0
account.{{ $loop->iteration }}.dial_tone = 0
account.{{ $loop->iteration }}.call_id_mode = 0
account.{{ $loop->iteration }}.subscribe_expires_overlap = -1
account.{{ $loop->iteration }}.register_expires_overlap = -1
account.{{ $loop->iteration }}.call_info =
account.{{ $loop->iteration }}.custom_ua =
account.{{ $loop->iteration }}.mwi_parse_terminated = 0
account.{{ $loop->iteration }}.check_cseq.enable = 1
account.{{ $loop->iteration }}.check_to_tag.enable = 0
account.{{ $loop->iteration }}.vq_rtcpxr.collector_server_port = 5060
account.{{ $loop->iteration }}.vq_rtcpxr.collector_server_host =
account.{{ $loop->iteration }}.vq_rtcpxr.collector_name =
account.{{ $loop->iteration }}.compact_header_enable = 0
account.{{ $loop->iteration }}.cp_source = 0
account.{{ $loop->iteration }}.cid_source_ppi = 0
account.{{ $loop->iteration }}.cid_source_privacy = 1
account.{{ $loop->iteration }}.reg_with_pani_header.enable = 0
account.{{ $loop->iteration }}.alert_info =
account.{{ $loop->iteration }}.picture_info_enable= 0
##V83 Add
account.{{ $loop->iteration }}.invite_with_pani_header.enable = 0
##V84 Add
account.{{ $loop->iteration }}.invite_with_rpid_header.enable =
account.{{ $loop->iteration }}.auto_answer_mute_enable =
##V84 SP4 Add
account.{{ $loop->iteration }}.share_line.enable_private_code =
account.{{ $loop->iteration }}.share_line.cancel_private_code =
account.{{ $loop->iteration }}.missed_calllog = 1
account.{{ $loop->iteration }}.timeout_fwd.off_code =
account.{{ $loop->iteration }}.timeout_fwd.on_code =
account.{{ $loop->iteration }}.timeout_fwd.timeout = 2
account.{{ $loop->iteration }}.timeout_fwd.target =
account.{{ $loop->iteration }}.timeout_fwd.enable = 0
account.{{ $loop->iteration }}.busy_fwd.off_code =
account.{{ $loop->iteration }}.busy_fwd.on_code =
account.{{ $loop->iteration }}.busy_fwd.target =
account.{{ $loop->iteration }}.busy_fwd.enable = 0
account.{{ $loop->iteration }}.always_fwd.off_code =
account.{{ $loop->iteration }}.always_fwd.on_code =
account.{{ $loop->iteration }}.always_fwd.target =
account.{{ $loop->iteration }}.always_fwd.enable = 0
account.{{ $loop->iteration }}.dnd.enable = 0
account.{{ $loop->iteration }}.dnd.off_code =
account.{{ $loop->iteration }}.dnd.on_code =
voice_mail.number.{{ $loop->iteration }} =
account.{{ $loop->iteration }}.subscribe_mwi = 0
account.{{ $loop->iteration }}.subscribe_mwi_to_vm = 0
account.{{ $loop->iteration }}.subscribe_mwi_expires = 3600
account.{{ $loop->iteration }}.display_mwi.enable = 1
account.{{ $loop->iteration }}.auto_dial_enable = 0
account.{{ $loop->iteration }}.auto_dial_num =
account.{{ $loop->iteration }}.ringtone.ring_type = Common
account.{{ $loop->iteration }}.dialplan.digitmap.enable =
account.{{ $loop->iteration }}.dialplan.digitmap.string =
account.{{ $loop->iteration }}.dialplan.digitmap.no_match_action =
account.{{ $loop->iteration }}.dialplan.digitmap.interdigit_short_timer =
account.{{ $loop->iteration }}.dialplan.digitmap.interdigit_long_timer = 3
account.{{ $loop->iteration }}.dialplan.digitmap.apply_to.press_send =
account.{{ $loop->iteration }}.dialplan.digitmap.apply_to.forward =
account.{{ $loop->iteration }}.dialplan.digitmap.apply_to.history_dial =
account.{{ $loop->iteration }}.dialplan.digitmap.apply_to.directory_dial =
account.{{ $loop->iteration }}.dialplan.digitmap.apply_to.on_hook_dial =
account.{{ $loop->iteration }}.dialplan.digitmap.active.on_hook_dialing =
account.{{ $loop->iteration }}.alert_info_url_enable = 1
account.{{ $loop->iteration }}.blf.blf_list_uri =
account.{{ $loop->iteration }}.blf_list_barge_in_code =
account.{{ $loop->iteration }}.blf_list_code =
account.{{ $loop->iteration }}.blf_list_retrieve_call_parked_code =
account.{{ $loop->iteration }}.blf.subscribe_period = 1800
account.{{ $loop->iteration }}.blf.match_host.enable = 0
account.{{ $loop->iteration }}.out_dialog_blf_enable = 0
account.{{ $loop->iteration }}.blf.subscribe_event = 0
##V84 Add
account.{{ $loop->iteration }}.blf_list_call_parked_code =
account.{{ $loop->iteration }}.blf_list_call_parked_list =
##V84 SP4 ADD
account.{{ $loop->iteration }}.blf_list_whisper_code =
account.{{ $loop->iteration }}.blf_list_listen_in_code =
account.{{ $loop->iteration }}.shared_line = 0
account.{{ $loop->iteration }}.line_seize.expires = 15
account.{{ $loop->iteration }}.shared_line_one_touch_bargein.enable =
account.{{ $loop->iteration }}.shared_line_one_touch_retrieve.enable =
account.{{ $loop->iteration }}.sca_manage_interface_display_time = 10
account.{{ $loop->iteration }}.shared_line_callpull_code =
##V83 Add
account.{{ $loop->iteration }}.share_line.barge_in.enable =
###V85 add
account.{{ $loop->iteration }}.shared_line.idle_details =
account.{{ $loop->iteration }}.bla_number =
account.{{ $loop->iteration }}.bla_subscribe_period = 300
account.{{ $loop->iteration }}.bla.notify_with_expire.enable = 1
account.{{ $loop->iteration }}.bla.subscribe_uri_build_type = 0
account.{{ $loop->iteration }}.callpark_enable = 1
account.{{ $loop->iteration }}.acd.enable = 0
account.{{ $loop->iteration }}.acd.available = 0
account.{{ $loop->iteration }}.acd.unavailable_reason_enable = 0
account.{{ $loop->iteration }}.acd.initial_state = 1
account.{{ $loop->iteration }}.subscribe_acd_expires = 3600
##account.X.reason_code.Y=
##account.X.reason_code_name.Y=
##account.X.bw_disp_code.Y=
##account.X.bw_disp_code_name.Y=
##account.X.supervisor_info_code.Y=
##account.X.supervisor_info_code_name.Y=
##The value Y must be continuous.
account.{{ $loop->iteration }}.reason_code.1 =
account.{{ $loop->iteration }}.reason_code_name.1 =
account.{{ $loop->iteration }}.bw_disp_code.1 =
account.{{ $loop->iteration }}.bw_disp_code_name.1 =
account.{{ $loop->iteration }}.supervisor_info_code.1 =
account.{{ $loop->iteration }}.supervisor_info_code_name.1 =
account.{{ $loop->iteration }}.call_center.call_info_enable = 0
account.{{ $loop->iteration }}.call_center.show_call_info_time = 30
account.{{ $loop->iteration }}.call_center.disp_code_enable = 0
account.{{ $loop->iteration }}.call_center.trace_enable = 0
account.{{ $loop->iteration }}.call_center.emergency_enable = 0
account.{{ $loop->iteration }}.call_center.queue_status_enable = 0
account.{{ $loop->iteration }}.call_center.queue_status_light_enable = 0
account.{{ $loop->iteration }}.hoteling.enable = 0
account.{{ $loop->iteration }}.hoteling.user_name =
account.{{ $loop->iteration }}.hoteling.password =
account.{{ $loop->iteration }}.hoteling.expires = 3600
account.{{ $loop->iteration }}.hoteling.auto_login_enable = 0
account.{{ $loop->iteration }}.xsi.user =
account.{{ $loop->iteration }}.xsi.password =
account.{{ $loop->iteration }}.xsi.host =
account.{{ $loop->iteration }}.xsi.server_type =
account.{{ $loop->iteration }}.xsi.port =
account.{{ $loop->iteration }}.direct_pickup_code =
account.{{ $loop->iteration }}.group_pickup_code =
account.{{ $loop->iteration }}.dialoginfo_callpickup = 0
account.{{ $loop->iteration }}.refresh_remote_id.enable = 1
account.{{ $loop->iteration }}.call_recording.enable = 0
account.{{ $loop->iteration }}.conf_uri =
account.{{ $loop->iteration }}.features.call_decline.enable =
account.{{ $loop->iteration }}.security_classification.enable = 0
account.{{ $loop->iteration }}.flexible_seating.enable = 0
account.{{ $loop->iteration }}.hoteling.pin =
account.{{ $loop->iteration }}.hoteling.mode = 0
account.{{ $loop->iteration }}.features.forward.feature_key_sync.local_processing.enable =
account.{{ $loop->iteration }}.features.dnd.feature_key_sync.local_processing.enable =
##V84 Add
account.{{ $loop->iteration }}.dnd.feature_key_sync.enable =
account.{{ $loop->iteration }}.feature_key_sync.enable =
account.{{ $loop->iteration }}.forward.feature_key_sync.enable = 1
account.{{ $loop->iteration }}.acd.available_url =
account.{{ $loop->iteration }}.acd.away_url =
account.{{ $loop->iteration }}.acd.refresh_url =
account.{{ $loop->iteration }}.acd.call_information =
@endforeach
##V84 Add
bw.virtual_user.1.enable =
bw.virtual_user.1.label =
bw.virtual_user.1.xsi.dnd.enable =
bw.virtual_user.1.xsi.host =
bw.virtual_user.1.xsi.password =
bw.virtual_user.1.xsi.port =
bw.virtual_user.1.xsi.server_type =
bw.virtual_user.1.xsi.user =
#!version:1.0.0.1
static.network.cdp.enable =
static.network.cdp.packet_interval =
static.network.ipv6_static_dns_enable =
static.network.ipv6_icmp_v6.enable =
static.network.ipv6_secondary_dns =
static.network.ipv6_primary_dns =
static.network.ipv6_internet_port.gateway =
static.network.ipv6_internet_port.ip =
static.network.ipv6_internet_port.type =
static.network.ipv6_prefix =
##static.wifi.X.ssid=
##static.wifi.X.priority=
##static.wifi.X.security_mode=
##static.wifi.X.password=
##static.wifi.X.eap_type=
##static.wifi.X.eap_user_name=
##static.wifi.x.eap_password=
##(X ranges from 1 to 5)
##Only T5XW/T54S/T52S/T48G/T48S/T46G/T46S/T42S/T41S/T29G/T27G/T4XU Models support these parameters.
static.wifi.enable =
static.wifi.1.label =
static.wifi.1.ssid =
static.wifi.1.priority =
static.wifi.1.security_mode =
static.wifi.1.cipher_type =
static.wifi.1.password =
static.wifi.1.eap_type =
static.wifi.1.eap_user_name =
static.wifi.1.eap_password =
static.wifi.show_scan_prompt =
##V83 Add
static.wifi.function.enable =
##V84 SP4 ADD
static.network.wifi.ip_address_mode=
static.network.wifi.preference =
static.network.wifi.internet_port.type =
static.network.wifi.internet_port.ip=
static.network.wifi.internet_port.mask=
static.network.wifi.internet_port.gateway=
static.network.wifi.static_dns_enable=
static.network.wifi.primary_dns=
static.network.wifi.secondary_dns=
static.network.wifi.ipv6_internet_port.type=
static.network.wifi.ipv6_internet_port.ip=
static.network.wifi.ipv6_prefix=
static.network.wifi.ipv6_internet_port.gateway=
static.network.wifi.ipv6_static_dns_enable=
static.network.wifi.ipv6_primary_dns=
static.network.wifi.ipv6_secondary_dns=
static.network.wifi.ipv6_icmp_v6.enable=
static.network.ip_address_mode =
static.network.span_to_pc_port =
static.network.vlan.pc_port_mode =
static.network.static_dns_enable =
static.network.pc_port.enable =
static.network.primary_dns =
static.network.secondary_dns =
static.network.internet_port.gateway =
static.network.internet_port.mask =
static.network.internet_port.ip =
static.network.internet_port.type =
##V83 Add
static.network.preference =
static.network.dhcp_host_name =
static.network.dhcp.option60type =
static.network.mtu_value =
static.network.qos.audiotos =
static.network.port.min_rtpport =
static.network.port.max_rtpport =
static.network.qos.signaltos =
static.wui.http_enable =
static.wui.https_enable =
static.network.port.https =
static.network.port.http =
static.network.pc_port.speed_duplex =
static.network.internet_port.speed_duplex =
##V83 Add
static.network.redundancy.mode =
static.network.redundancy.failback.timeout =
static.network.lldp.enable =
static.network.lldp.packet_interval =
static.network.vlan.dhcp_enable =
static.network.vlan.dhcp_option =
static.network.vlan.vlan_change.enable =
static.network.vlan.pc_port_priority =
static.network.vlan.pc_port_vid =
static.network.vlan.pc_port_enable =
static.network.vlan.internet_port_priority =
static.network.vlan.internet_port_vid =
static.network.vlan.internet_port_enable =
static.network.vpn_enable = {{ $openvpn[‘enabled’] ?? 0 }}
static.openvpn.url = {{ $openvpn[‘server_address’] ?? null }}
static.network.802_1x.mode =
static.network.802_1x.identity =
static.network.802_1x.md5_password =
static.network.802_1x.client_cert_url =
static.network.802_1x.root_cert_url =
static.network.802_1x.eap_fast_provision_mode =
static.network.802_1x.anonymous_identity =
static.network.802_1x.proxy_eap_logoff.enable =
static.auto_provision.custom.protect =
static.auto_provision.custom.sync =
static.auto_provision.custom.sync.path =
static.auto_provision.custom.upload_method =
static.zero_touch.enable =
static.zero_touch.wait_time =
static.features.hide_zero_touch_url.enable =
static.zero_touch.network_fail_delay_times =
static.zero_touch.network_fail_wait_times =
static.auto_provision.server.url = {{ $settings[‘provisioning_path’] ?? null }}
static.auto_provision.server.username = {{ $connectionSettings[‘auth_user’] ?? null }}
static.auto_provision.server.password = {{ $connectionSettings[‘auth_password’] ?? null }}
static.auto_provision.weekly.enable =
static.auto_provision.weekly.dayofweek =
static.auto_provision.weekly.end_time =
static.auto_provision.weekly.begin_time =
static.auto_provision.weekly_upgrade_interval =
static.auto_provision.repeat.enable =
static.auto_provision.repeat.minutes =
static.auto_provision.dhcp_option.list_user_options =
static.auto_provision.dhcp_option.enable =
##V83 Add
static.auto_provision.dhcp_option.list_user6_options =
static.auto_provision.power_on =
static.auto_provision.flexible.end_time =
static.auto_provision.flexible.begin_time =
static.auto_provision.flexible.interval =
static.auto_provision.flexible.enable =
static.auto_provision.prompt.enable =
static.auto_provision.attempt_expired_time =
static.auto_provision.attempt_before_failed =
static.network.attempt_expired_time =
static.auto_provision.update_file_mode =
static.auto_provision.retry_delay_after_file_transfer_failed=
static.auto_provision.inactivity_time_expire =
static.auto_provision.dns_resolv_timeout =
static.auto_provision.dns_resolv_nretry =
static.auto_provision.dns_resolv_nosys =
static.auto_provision.user_agent_mac.enable =
static.auto_provision.server.type =
features.action_uri_force_autop =
static.auto_provision.url_wildcard.pn =
static.auto_provision.reboot_force.enable =
static.auto_provision.dhcp_option.option60_value =
static.custom_mac_cfg.url =
static.auto_provision.aes_key_in_file =
features.custom_version_info =
##V83 Add
static.auto_provision.authentication.expired_time =
static.auto_provision.connect.keep_alive =
##V84 Add
static.auto_provision.config_version.mac =
static.auto_provision.config_version.com =
static.auto_provision.pnp_enable =
##static.autoprovision.X.name
##static.autoprovision.X.code
##static.autoprovision.X.url
##static.autoprovision.X.user
##static.autoprovision.X.password
##static.autoprovision.X.com_aes
##static.autoprovision.X.mac_aes
##Autop Code(X ranges from 1 to 50)
static.autoprovision.1.name =
static.autoprovision.1.code =
static.autoprovision.1.url =
static.autoprovision.1.user =
static.autoprovision.1.password =
static.autoprovision.1.com_aes =
static.autoprovision.1.mac_aes =
static.managementserver.enable =
static.managementserver.username =
static.managementserver.password =
static.managementserver.url =
static.managementserver.periodic_inform_enable =
static.managementserver.periodic_inform_interval =
static.managementserver.connection_request_password =
static.managementserver.connection_request_username =
static.firmware.url = {{ $connectionSettings[‘firmware_path’] ?? null }}
features.reset_by_long_press_enable =
features.factory_pwd_enable =
static.configuration.url =
static.features.custom_factory_config.enable =
static.custom_factory_configuration.url =
static.syslog.enable =
static.syslog.server =
static.syslog.level =
static.syslog.server_port =
static.syslog.transport_type =
static.syslog.facility =
static.syslog.prepend_mac_address.enable =
static.local_log.enable =
static.local_log.level =
static.local_log.max_file_size =
static.auto_provision.local_log.backup.enable =
static.auto_provision.local_log.backup.path =
static.auto_provision.local_log.backup.upload_period =
static.auto_provision.local_log.backup.append =
static.auto_provision.local_log.backup.bootlog.upload_wait_time=
static.auto_provision.local_log.backup.append.max_file_size =
static.auto_provision.local_log.backup.append.limit_mode =
static.security.var_enable =
static.web_item_level.url =
wui.quick_login =
static.phone_setting.reserve_certs_enable =
features.relog_offtime =
static.security.default_ssl_method =
static.security.cn_validation = 0
static.security.dev_cert =
static.security.ca_cert = 2
static.security.trust_certificates = 0
static.security.user_password = {{ $adminPassword }}
static.security.user_name.var =
static.security.user_name.admin =
static.security.user_name.user =
##V83 Add
static.security.default_access_level =
phone_setting.reserve_certs_config.enable =
static.watch_dog.enable =
static.server_certificates.url =
static.server_certificates.delete =
static.trusted_certificates.url =
static.trusted_certificates.delete =
wui.secure_domain_list =
static.auto_provision.encryption.directory =
static.auto_provision.encryption.call_log =
static.auto_provision.encryption.config =
dialplan.transfer.mode =
transfer.on_hook_trans_enable =
transfer.tran_others_after_conf_enable =
transfer.blind_tran_on_hook_enable =
transfer.semi_attend_tran_enable =
features.conference.with_previous_call.enable =
features.local_conf.combine_with_one_press.enable =
features.anonymous_response_code =
phone_setting.incoming_call_when_dialing.priority =
phone_setting.hold_or_swap.mode =
features.play_held_tone.interval =
features.play_held_tone.delay =
features.play_held_tone.enable =
features.play_hold_tone.interval =
features.ignore_incoming_call.enable =
force.voice.ring_vol =
features.mute.autoanswer_mute.enable =
features.play_hold_tone.delay =
phone_setting.end_call_net_disconnect.enable =
features.custom_auto_answer_tone.enable =
default_input_method.dialing =
features.speaker_mode.enable =
features.headset_mode.enable =
features.handset_mode.enable =
features.conference.local.enable =
features.off_hook_answer.enable =
features.caller_name_type_on_dialing =
phone_setting.show_code403 =
phone_setting.ring_for_tranfailed =
features.password_dial.length =
features.password_dial.prefix =
features.password_dial.enable =
features.group_listen_in_talking_enable =
phone_setting.call_info_display_method =
phone_setting.called_party_info_display.enable =
features.headset_training =
features.headset_prior =
features.dtmf.replace_tran =
features.dtmf.transfer =
phone_setting.ringing_timeout =
phone_setting.ringback_timeout =
features.keep_mute.enable =
linekey.1.shortlabel =
features.config_dsskey_length.shorten =
transfer.dsskey_deal_type =
features.auto_linekeys.enable =
features.linekey_call_with_default_account =
##V83 Add
features.station_name.value =
features.station_name.scrolling_display =
voice.headset.autoreset_spk_vol =
voice.handset.autoreset_spk_vol =
voice.handfree.autoreset_spk_vol =
features.headset.ctrl_call.enable =
phone_setting.incoming_call.reject.enable =
features.play_mute_tone.enable =
features.play_mute_tone.interval =
features.call_out_directory_by_off_hook.enable =
features.congestion_tone.codelist =
##V84 Add
phone_setting.icon.delete =
phone_setting.icon.url =
##V84 SP4 Add
voice.handset.tia4965.enable =
voice.headset.tia4965.enable =
phone_setting.custom_softkey_enable =
custom_softkey_talking.url =
custom_softkey_ring_back.url =
custom_softkey_dialing.url =
custom_softkey_connecting.url =
custom_softkey_call_in.url =
custom_softkey_call_failed.url =
##V83 Add
features.homescreen_softkey.acd.enable =
features.homescreen_softkey.hoteling.enable =
phone_setting.custom_softkey.apply_to_states =
features.custom_softkey_dynamic.enable =
##Only T5XW/T54S/T52S/T48G/T48S/T46G/T46S/T42S/T41S/T29G/T27G/T4XU Models support the parameter.
features.bluetooth_enable =
features.bluetooth_adapter_name =
##V83 Add
static.bluetooth.function.enable =
##V84 Add
bluetooth.a2dp_sink =
bluetooth.connect_confirm.enable =
features.usb_call_recording.enable =
features.auto_recording.enable =
features.idle_recording.enable=
##V83 Add
static.usb.power.enable =
##V84 Add
static.usbdisk.function.enable =
voice.g726.aal2.enable =
features.dtmf.min_interval =
features.dtmf.volume =
features.dtmf.duration =
voice.tone.autoanswer =
voice.tone.message =
voice.tone.stutter =
voice.tone.info =
voice.tone.dialrecall =
voice.tone.callwaiting =
voice.tone.congestion =
voice.tone.busy =
voice.tone.ring =
voice.tone.dial =
voice.tone.country =
voice.side_tone =
features.partition_tone =
voice.tone.secondary_dial=
voice.tone.stutterdial =
voice.tone.stutter_dial_tone.apply_to_dnd.enable =
voice.tone.stutter_dial_tone.apply_to_fwd.enable =
voice.jib.normal=
voice.jib.max =
voice.jib.min =
voice.jib.adaptive =
voice.jib.wifi.normal =
voice.jib.wifi.max =
voice.jib.wifi.min =
voice.jib.wifi.adaptive =
voice.echo_cancellation =
voice.cng =
voice.vad =
##V84 Add
voice.ans_nb.enable =
voice.tns.enable =
static.network.dns.ttl_enable =
static.network.dns.last_cache_expired.enable =
static.network.dns.query_timeout =
static.network.dns.retry_times =
sip.dns_transport_type =
sip.skip_redundant_failover_addr =
sip.use_out_bound_in_dialog =
sip.unreg_with_socket_close =
phone_setting.disable_account_without_username.enable =
features.auto_answer.first_call_only =
##V84 Add
phone_setting.call_display_name.mode =
sip.request_validation.event =
sip.sdp_early_answer_or_offer =
sip.cid_source.preference =
sip.request_validation.digest.realm =
sip.request_validation.digest.list =
sip.request_validation.source.list =
sip.send_keepalive_by_socket =
sip.reliable_protocol.timerae.enable =
sip.requesturi.e164.addglobalprefix =
sip.trust_ctrl =
sip.mac_in_ua =
sip.timer_t1 =
sip.timer_t2 =
sip.timer_t4 =
sip.listen_mode =
sip.listen_port =
sip.tls_listen_port =
sip.tcp_port_random_mode =
sip.escape_characters.enable =
sip.notify_reboot_enable =
sip.send_response_by_request =
sip.disp_incall_to_info =
features.call_invite_format =
phone_setting.early_media.rtp_sniffer.timeout =
sip.reg_surge_prevention =
sip.reserve_characters =
##V83 Add
sip.dhcp.option120.mode =
static.sip.nat_turn.enable =
static.sip.nat_turn.username =
static.sip.nat_turn.password =
static.sip.nat_turn.server =
static.sip.nat_turn.port =
static.sip.nat_stun.enable =
static.sip.nat_stun.server =
static.sip.nat_stun.port =
static.ice.enable =
static.network.static_nat.enable =
static.network.static_nat.addr =
dns_cache_a.1.name =
dns_cache_a.1.ip =
dns_cache_a.1.ttl =
dns_cache_srv.1.name =
dns_cache_srv.1.port =
dns_cache_srv.1.priority =
dns_cache_srv.1.target =
dns_cache_srv.1.weight =
dns_cache_srv.1.ttl =
dns_cache_naptr.1.name =
dns_cache_naptr.1.order =
dns_cache_naptr.1.preference =
dns_cache_naptr.1.replace =
dns_cache_naptr.1.service =
dns_cache_naptr.1.ttl =
features.rtp_symmetric.enable=
voice.rtcp.enable =
voice.rtcp_cname =
voice.rtcp_xr.enable =
phone_setting.vq_rtcpxr_display_symm_oneway_delay.enable =
phone_setting.vq_rtcpxr_display_round_trip_delay.enable =
phone_setting.vq_rtcpxr_display_moscq.enable =
phone_setting.vq_rtcpxr_display_moslq.enable =
phone_setting.vq_rtcpxr_display_packets_lost.enable =
phone_setting.vq_rtcpxr_display_jitter_buffer_max.enable =
phone_setting.vq_rtcpxr_display_jitter.enable =
phone_setting.vq_rtcpxr_display_remote_codec.enable =
phone_setting.vq_rtcpxr_display_local_codec.enable =
phone_setting.vq_rtcpxr_display_remote_call_id.enable =
phone_setting.vq_rtcpxr_display_local_call_id.enable =
phone_setting.vq_rtcpxr_display_stop_time.enable =
phone_setting.vq_rtcpxr_display_start_time.enable =
phone_setting.vq_rtcpxr_interval_period =
phone_setting.vq_rtcpxr_delay_threshold_critical =
phone_setting.vq_rtcpxr_delay_threshold_warning =
phone_setting.vq_rtcpxr_moslq_threshold_critical =
phone_setting.vq_rtcpxr_moslq_threshold_warning =
phone_setting.vq_rtcpxr.interval_report.enable =
phone_setting.vq_rtcpxr.states_show_on_gui.enable =
phone_setting.vq_rtcpxr.states_show_on_web.enable =
phone_setting.vq_rtcpxr.session_report.enable =
static.directory_setting.url =
super_search.url =
local_contact.data.url =
local_contact.data.delete =
##Only T5XW/T54S/T52S/T48G/T48S/T46G/T46S/T29G/T46U/T48U Models support the parameter
phone_setting.contact_photo_display.enable =
phone_setting.incoming_call.horizontal_roll_interval =
##Only T5XW/T54S/T52S/T48G/T48S/T46G/T46S/T29G/T5XW Models support the parameter
local_contact.data_photo_tar.url =
local_contact.photo.url =
local_contact.image.url =
##Only T48G/S Models support the parameter
local_contact.icon_image.url =
local_contact.icon.url =
search_in_dialing.local_directory.enable =
search_in_dialing.local_directory.priority =
##remote_phonebook.data.X.url
##remote_phonebook.data.X.name
#remote_phonebook.data.X.username=
#remote_phonebook.data.X.password=
@foreach ($phonebook ?? [] as $key)
remote_phonebook.data.{{ $loop->iteration }}.url = {{ $key[‘url’] ?? null }}
remote_phonebook.data.{{ $loop->iteration }}.name = {{ $key[‘name’] ?? null }}
@endforeach
features.remote_phonebook.enter_update_enable =
features.remote_phonebook.flash_time =
features.remote_phonebook.enable =
remote_phonebook.display_name =
directory_setting.remote_phone_book.enable =
directory_setting.remote_phone_book.priority =
search_in_dialing.remote_phone_book.enable =
search_in_dialing.remote_phone_book.priority =
##V84 ADD
remote_phonebook.data.1.username =
remote_phonebook.data.1.password =
ldap.enable =
ldap.user =
ldap.password =
ldap.base =
ldap.port =
ldap.host =
ldap.customize_label =
ldap.incoming_call_special_search.enable =
ldap.tls_mode =
ldap.search_type =
ldap.numb_display_mode =
ldap.ldap_sort =
ldap.call_in_lookup =
ldap.version =
ldap.display_name =
ldap.numb_attr =
ldap.name_attr =
ldap.max_hits =
ldap.number_filter =
ldap.name_filter =
ldap.call_out_lookup =
directory_setting.ldap.enable =
directory_setting.ldap.priority =
search_in_dialing.ldap.enable =
search_in_dialing.ldap.priority =
##V84 SP4 ADD
ldap.custom_extra_attr_name =
ldap.display_extra_attr =
ldap.extra_attr =
static.auto_provision.local_calllog.write_delay.terminated =
static.auto_provision.local_calllog.backup.path =
static.auto_provision.local_calllog.backup.enable =
super_search.recent_call =
features.call_out_history_by_off_hook.enable =
features.save_call_history =
features.call_log_show_num =
search_in_dialing.history.enable =
search_in_dialing.history.priority =
directory_setting.history.enable =
directory_setting.history.priority =
features.save_init_num_to_history.enable =
features.redial_via_local_sip_server.enable =
##V83 Add
features.calllog_detailed_information =
##V84 Add
features.call_log_merge.enable =
static.auto_provision.local_contact.backup.path =
static.auto_provision.local_contact.backup.enable =
directory.search_type =
directory_setting.local_directory.enable =
directory_setting.local_directory.priority =
##V83 Add
phone_setting.search.highlight_keywords.enable =
##V83 Add
local_contact.favorite.enable =
phone_setting.favorite_sequence_type =
#programablekey.X.type
#programablekey.X.line
#programablekey.X.value
#programablekey.X.xml_phonebook
#programablekey.X.history_type
#programablekey.X.label(X ranges from 1 to 4)
#programablekey.X.extension
##Programablekey X ranges(T48G/T48S/T46G/T46S: X=1-10, 12-14;T42G/T42S/T41P/T41S/T40P/T40G: X=1-10, 13;T29G/T27P/T27G: X=1-14;T23P/T23G/T21(P) E2: 1-10, 14;T19(P) E2: X=1-9, 13, 14;)##
programablekey.1.type =
programablekey.1.label =
programablekey.1.value =
programablekey.1.line =
programablekey.1.history_type =
programablekey.1.xml_phonebook =
programablekey.1.extension =
##V83 Add
programablekey.type_range.custom =
##linekey.X.line
##linekey.X.value
##linekey.X.extension
##linekey.X.type
##linekey.X.xml_phonebook
##linekey.X.shortlabel
##linekey.X.label
##LineKeyX ranges(T48U/T57W/T48G/S: X ranges from 1 to 29. T53W/T54W/T54S/T46G/T46S/T29G/T46U: X ranges from 1 to 27. T42G/T42S/T41P/T41S/T41U/T42U: X ranges from 1 to 15. T40P/T40G/T23P/T23G: X ranges from 1 to 3. T52S/T27P/T27G/T43U: X ranges from 1 to 21. T21(P) E2: X ranges from 1 to 2.)##
linekey.{{ $loop->iteration }}.label = {{ $key[‘description’] ?? null }}
linekey.{{ $loop->iteration }}.line = {{ $key[‘line’] ?? 1 }}
linekey.{{ $loop->iteration }}.value = {{ $key[‘value’] ?? null }}
linekey.{{ $loop->iteration }}.extension = {{ $key[‘extension’] ?? null }}
linekey.{{ $loop->iteration }}.type = {{ $key[‘type’] ?? null }}
linekey.{{ $loop->iteration }}.xml_phonebook =
@endforeach
##V83 Add
linekey.type_range.custom =
features.block_linekey_in_menu.enable =
features.shorten_linekey_label.enable =
features.flash_url_dsskey_led.enable =
features.config_dsskey_length =
phone_setting.page_tip =
features.keep_switch_page_key.enable =
##phone_setting.idle_dsskey_and_title.transparency(Only support T5XW/T54S/T52S/T48G/T48S/T48U)
phone_setting.idle_dsskey_and_title.transparency =
##V83 Add
phone_setting.keytype_sequence =
phone_setting.dsskey_label.display_method =
local.dsskey_type_config.mode =
##expansion_module.X.key.Y.type
##expansion_module.X.key.Y.line
##expansion_module.X.key.Y.value
##expansion_module.X.key.Y.extension
##expansion_module.X.key.Y.label
##expansion_module.X.key.Y.xml_phonebook
expansion_module.1.key.1.type =
expansion_module.1.key.1.label =
expansion_module.1.key.1.value =
expansion_module.1.key.1.line =
expansion_module.1.key.1.extension =
expansion_module.1.key.1.xml_phonebook =
expansion_module.page_tip.blf_call_in.led =
expansion_module.page_tip.blf_call_in.enable =
##V83 Add
expkey.type_range.custom =
##EDK Soft Keys(X ranges from 1 to 10)
features.enhanced_dss_keys.enable =
edk.id_mode.enable =
softkey.1.position =
softkey.1.use.dialing =
softkey.1.softkey_id =
softkey.1.use.dialtone =
softkey.1.use.conferenced =
softkey.1.use.held =
softkey.1.use.hold =
softkey.1.use.transfer_ring_back =
softkey.1.use.ring_back =
softkey.1.use.call_failed =
softkey.1.use.on_talk =
softkey.1.use.transfer_connecting =
softkey.1.use.connecting =
softkey.1.use.incoming_call =
softkey.1.use.idle =
softkey.1.action =
softkey.1.label =
softkey.1.enable =
edk.edklist.1.action =
edk.edklist.1.mname =
edk.edklist.1.enable =
edk.edkprompt.1.enable =
edk.edkprompt.1.label =
edk.edkprompt.1.type =
edk.edkprompt.1.userfeedback =
##V84 Add
##edk.edkprompt.X.title=
(X ranges from 1 to 9)
edk.edkprompt.1.title =
push_xml.server =
push_xml.sip_notify =
push_xml.block_in_calling =
default_input_method.xml_browser_input_screen =
##V83 Add
hoteling.authentication_mode =
push_xml.phonebook.search.delay =
features.xml_browser.loading_tip.delay =
features.xml_browser.pwd =
features.xml_browser.user_name =
push_xml.password =
push_xml.username =
features.fwd.allow =
features.fwd_mode =
forward.no_answer.enable =
forward.busy.enable =
forward.always.enable =
forward.no_answer.timeout =
forward.no_answer.on_code =
forward.no_answer.off_code =
forward.busy.off_code =
forward.busy.on_code =
forward.always.off_code =
forward.always.on_code =
forward.no_answer.target =
forward.busy.target =
forward.always.target =
features.forward.emergency.authorized_number =
features.forward.emergency.enable =
forward.idle_access_always_fwd.enable =
features.forward_call_popup.enable =
##V83 Add
features.forward.no_answer.show_ring_times =
##V84 Add
features.no_answer_code =
features.dnd.allow =
features.dnd_mode =
features.dnd.enable =
features.dnd.off_code =
features.dnd.on_code =
features.dnd.emergency_authorized_number =
features.dnd.emergency_enable =
features.dnd.large_icon.enable =
##V83 Add
features.keep_dnd.enable =
phone_setting.phone_lock.enable =
phone_setting.phone_lock.lock_key_type =
phone_setting.phone_lock.unlock_pin =
phone_setting.emergency.number =
phone_setting.phone_lock.lock_time_out =
phone_setting.logon_wizard =
phone_setting.logon_wizard_forever_wait =
hotdesking.startup_register_name_enable =
hotdesking.startup_username_enable =
hotdesking.startup_password_enable =
hotdesking.startup_sip_server_enable =
hotdesking.startup_outbound_enable =
hotdesking.dsskey_register_name_enable =
hotdesking.dsskey_username_enable =
hotdesking.dsskey_password_enable =
hotdesking.dsskey_sip_server_enable =
hotdesking.dsskey_outbound_enable =
features.voice_mail_alert.enable =
features.voice_mail_popup.enable =
features.voice_mail_tone_enable =
features.hide_feature_access_codes.enable =
features.text_message.enable =
features.text_message_popup.enable =
features.intercom.mode =
features.intercom.subscribe.enable =
features.intercom.led.enable =
features.intercom.feature_access_code =
features.blf.intercom_mode.enable =
features.intercom.ptt_mode.enable =
features.redial_tone =
features.key_tone =
features.send_key_tone =
features.intercom.allow =
features.intercom.barge =
features.intercom.tone =
features.intercom.mute =
voice.handset_send =
voice.handfree_send =
voice.headset_send =
features.intercom.headset_prior.enable =
features.ringer_device.is_use_headset =
features.intercom.barge_in_dialing.enable =
features.ip_call.auto_answer.enable=
features.show_default_account=
features.call.dialtone_time_out=
features.missed_call_popup.enable=
features.auto_answer_tone.enable=
features.play_hold_tone.enable=
features.key_as_send=
features.send_pound_key=
features.busy_tone_delay=
features.hotline_delay=
features.hotline_number=
features.direct_ip_call_enable=
features.call_num_filter=
features.call_completion_enable=
features.allow_mute=
features.auto_answer_delay=
features.normal_refuse_code=
features.dnd_refuse_code=
features.upload_server=
features.dtmf.repetition=
features.dtmf.hide_delay=
features.dtmf.hide=
features.play_local_dtmf_tone_enable =
features.reboot_in_talk_enable =
features.fwd_diversion_enable=
call_waiting.enable=
call_waiting.tone=
call_waiting.off_code=
call_waiting.on_code=
auto_redial.times=
auto_redial.interval=
auto_redial.enable=
sip.rfc2543_hold=
sip.use_23_as_pound=
forward.international.enable=
phone_setting.headsetkey_mode=
phone_setting.is_deal180=
phone_setting.change_183_to_180=
##V84 Add
features.touch_tone=
features.csta_control.enable=
features.action_uri.enable=
features.action_uri_limit_ip=
features.show_action_uri_option=
action_url.call_remote_canceled=
action_url.remote_busy=
action_url.cancel_callout=
action_url.handfree=
action_url.headset=
action_url.unheld=
action_url.held=
action_url.transfer_failed=
action_url.transfer_finished=
action_url.answer_new_incoming_call=
action_url.reject_incoming_call=
action_url.forward_incoming_call=
action_url.ip_change=
action_url.idle_to_busy=
action_url.busy_to_idle=
action_url.call_terminated=
action_url.missed_call=
action_url.unmute=
action_url.mute=
action_url.unhold=
action_url.hold=
action_url.always_fwd_off =
action_url.always_fwd_on =
action_url.attended_transfer_call =
action_url.blind_transfer_call =
action_url.busy_fwd_off =
action_url.busy_fwd_on =
action_url.call_established =
action_url.call_waiting_off =
action_url.call_waiting_on =
action_url.dnd_off =
action_url.dnd_on =
action_url.incoming_call =
action_url.no_answer_fwd_off =
action_url.no_answer_fwd_on =
action_url.off_hook =
action_url.on_hook =
action_url.outgoing_call =
action_url.register_failed =
action_url.registered =
action_url.setup_autop_finish =
action_url.setup_completed =
action_url.transfer_call =
action_url.unregistered =
##V84 Add
action_url.peripheral_information=
phone_setting.hold_and_held_power_led_flash_enable=
phone_setting.mute_power_led_flash_enable=
phone_setting.talk_and_dial_power_led_enable=
phone_setting.mail_power_led_flash_enable=
phone_setting.ring_power_led_flash_enable=
phone_setting.common_power_led_enable=
phone_setting.missed_call_power_led_flash.enable=
lcl.datetime.date.format =
auto_dst.url =
local_time.manual_time_enable =
local_time.manual_ntp_srv_prior =
local_time.time_format = {{ $timeFormat ?? 0 }}
local_time.date_format = {{ $dateFormat ?? 0 }}
local_time.dhcp_time =
local_time.summer_time =
local_time.dst_time_type =
local_time.start_time =
local_time.end_time =
local_time.offset_time =
local_time.interval =
local_time.ntp_server1 =
local_time.ntp_server2 =
local_time.time_zone = {{ explode(‘|’, $timezone)[0] ?? ‘+8’ }}
local_time.time_zone_name = {{ explode(‘|’, $timezone)[1] ?? ‘China(Beijing)’ }}
##multicast.listen_address.X.label
##multicast.paging_address.X.channel
##multicast.listen_address.X.ip_address
##multicast.paging_address.X.ip_address
##multicast.paging_address.X.label
##multicast.listen_address.X.channel
##multicast.listen_address.X.volume
##Multicast(X ranges from 1 to 31.)
multicast.codec =
multicast.paging_address.1.channel =
multicast.paging_address.1.label =
multicast.paging_address.1.ip_address =
multicast.receive_priority.enable =
multicast.receive_priority.priority =
multicast.receive.use_speaker =
multicast.receive.enhance_volume =
multicast.receive.ignore_dnd.priority =
multicast.listen_address.1.channel =
multicast.listen_address.1.label =
multicast.listen_address.1.ip_address =
multicast.listen_address.1.volume =
##Not support T19P_E2
static.features.default_account =
##Logo File Format: .dob
##Resolution: SIP-T42G/T42S/T41P/T41S/T41U/T42U: <=19264 2 gray scale;SIP-T43U/SIP-T27P/G: <=240120 2 gray scale;SIP-T40P/T40G/T23P/T23G/T21(P) E2/T19(P) E2: <=132*64 2 gray scale##
phone_setting.lcd_logo.mode =
lcd_logo.delete =
lcd_logo.url =
phone_setting.contrast =
phone_setting.backlight_time =
phone_setting.inactive_backlight_level =
phone_setting.active_backlight_level =
phone_setting.predial_autodial =
ringtone.url =
ringtone.delete =
phone_setting.ring_type =
phone_setting.inter_digit_time =
##Only T54S Model supports the parameter
phone_setting.idle_clock_display.enable =
##V83 Add
dialplan.digitmap.apply_to.prefix_key =
##V84 ADD
features.local_calllog.received.replace_rule =
dialplan.emergency.enable =
dialplan.emergency.1.value =
dialplan.emergency.server.1.address =
dialplan.emergency.server.1.transport_type =
dialplan.emergency.server.1.port =
dialplan.emergency.1.server_priority =
dialplan.emergency.custom_asserted_id =
dialplan.emergency.asserted_id_source =
dialplan.emergency.asserted_id.sip_account =
dialplan.emergency.held.request_element.1.name =
dialplan.emergency.held.request_element.1.value =
dialplan.emergency.held.request_type =
dialplan.emergency.held.server_url =
dialplan_replace_rule.url =
dialplan.replace.line_id.1 =
dialplan.replace.replace.1 =
dialplan.replace.prefix.1 =
phone_setting.dialnow_delay =
dialplan_dialnow.url =
dialplan.dialnow.line_id.1 =
dialplan.dialnow.rule.1 =
dialplan.block_out.line_id.1 =
dialplan.block_out.number.1 =
dialplan.area_code.line_id =
dialplan.area_code.max_len =
dialplan.area_code.min_len =
dialplan.area_code.code =
distinctive_ring_tones.alert_info.1.ringer =
distinctive_ring_tones.alert_info.1.text =
directory.search_default_input_method =
directory.edit_default_input_method =
gui_input_method.url =
##V83 Add
##Only T48G/T48S Models support the parameter
phone_setting.virtual_keyboard.enable =
wui_lang.url =
wui_lang_note.url =
wui_lang.delete =
gui_input_method.delete =
gui_lang.url =
gui_lang.delete =
lang.gui = {{ $language ?? ‘English’ }}
lang.wui = {{ $language ?? ‘English’ }}
screensaver.type =
screensaver.delete =
screensaver.upload_url =
features.blf_active_backlight.enable =
screensaver.display_clock.enable =
screensaver.clock_move_interval =
screensaver.picture_change_interval =
screensaver.wait_time =
screensaver.xml_browser.url =
features.power_saving.enable =
features.power_saving.power_led_flash.on_time =
features.power_saving.power_led_flash.off_time =
features.power_saving.office_hour.monday =
features.power_saving.office_hour.tuesday =
features.power_saving.office_hour.wednesday =
features.power_saving.office_hour.thursday =
features.power_saving.office_hour.friday =
features.power_saving.office_hour.saturday =
features.power_saving.office_hour.sunday =
features.power_saving.user_input_ext.idle_timeout =
features.power_saving.off_hour.idle_timeout =
features.power_saving.office_hour.idle_timeout =
features.power_saving.intelligent_mode =
##File Formate:
##SIP-T57W/T54W/T54S/T52S/T48S/T48G/T46G/T46S/T29G/T46U/T48U: .jpg/.png/.bmp/.jpeg;
##Resolution:
##SIP-T57W/T48S/T48G/T48U/T46U:<=2.0 megapixels;
##for SIP-T54W/T46G/T46S/T29G: <=1.8 megapixels;SIP-T54S/T52S:<=4.2 megapixels;
##Single File Size: <=5MB
##2MB of space should bereserved for the phone
wallpaper_upload.url =
phone_setting.backgrounds = {{ $wallpaper ? ‘Config:’.$wallpaperName : null }}
phone_setting.backgrounds_with_dsskey_unfold =
##expansion_module.backgrounds(Only support T5XW/T54S/T52S/T43U/T46U/T48U)
expansion_module.backgrounds =
bw.enable =
phone_setting.auto_blf_list_enable =
phone_setting.blf_list_sequence_type =
blf.enhanced.parked.enable =
blf.enhanced.parked.led =
blf.enhanced.parked.talking.action =
blf.enhanced.parked.callin.action =
blf.enhanced.parked.idle.action =
blf.enhanced.talking.enable =
blf.enhanced.talking.led =
blf.enhanced.talking.talking.action =
blf.enhanced.talking.callin.action =
blf.enhanced.talking.idle.action =
blf.enhanced.callout.enable =
blf.enhanced.callout.led =
blf.enhanced.callout.talking.action =
blf.enhanced.callout.callin.action =
blf.enhanced.callout.idle.action =
blf.enhanced.callin.enable =
blf.enhanced.callin.led =
blf.enhanced.callin.talking.action =
blf.enhanced.callin.callin.action =
blf.enhanced.callin.idle.action =
blf.enhanced.idle.enable =
blf.enhanced.idle.led =
blf.enhanced.idle.talking.action =
blf.enhanced.idle.callin.action =
blf.enhanced.idle.idle.action =
features.blf_list_version =
sip.sub_refresh_random =
sip.terminate_notify_sub_delay_time =
features.blf_led_mode =
features.blf_pickup_only_send_code =
##V84 Add
blf.enhanced.dnd.enable =
blf.enhanced.dnd.led =
blf.enhanced.hold.enable =
blf.enhanced.hold.led =
features.blf.show_callinfo.enable =
##V84 SP4 ADD
blf.normal_barge_in_code =
blf.whisper_barge_in_code =
blf.listen_barge_in_code =
features.auto_release_bla_line =
features.barge_in_via_username.enable =
features.call_park.enable =
features.call_park.park_mode =
features.call_park.park_code =
features.call_park.park_retrieve_code =
features.call_park.direct_send.enable =
features.call_park.park_visual_notify_enable =
features.call_park.park_ring =
features.call_park.group_enable =
features.call_park.group_park_code =
sip.call_park_without_blf =
features.call_park.line_restriction.enable =
acd.enable =
acd.auto_available_timer =
bw.xsi.enable =
sip.authentication_for_xsi =
default_input_method.xsi_password =
bw.xsi.directory.enable =
bw.calllog_and_dir =
bw.xsi.call_log.enable =
bw_phonebook.custom =
bw_phonebook.enterprise_common_enable =
bw_phonebook.enterprise_common_displayname =
bw_phonebook.enterprise_enable =
bw_phonebook.enterprise_displayname =
bw_phonebook.group_common_enable =
bw_phonebook.group_common_displayname =
bw_phonebook.personal_enable =
bw_phonebook.personal_displayname =
bw_phonebook.group_enable =
bw_phonebook.group_displayname =
directory.update_time_interval =
bw.xsi.directory.alphabetized_by_lastname.enable =
directory_setting.bw_directory.enable =
directory_setting.bw_directory.priority =
search_in_dialing.bw_directory.enable =
search_in_dialing.bw_directory.priority =
##V83 Add
bw.xsi.directory.update.enable =
##V83 Add
bw.xsi.call_log.delete.enable =
bw.xsi.call_log.multiple_accounts.enable =
phone_setting.ring_duration =
features.pickup.direct_pickup_enable =
features.pickup.group_pickup_enable =
features.pickup.direct_pickup_code =
features.pickup.group_pickup_code =
features.pickup.blf_audio_enable =
features.pickup.blf_visual_enable =
features.pickup_display.method =
##V84 Add
features.pickup.blf_audio.list =
features.pickup.blf_visual.list =
features.alert_info_tone =
bw.voice_mail.visual.enable =
voice_mail.message_key.mode =
bw.voice_mail.visual.display_videomail.enable =
bw.call_recording.mode =
features.blf.ring_type =
features.feature_key_sync.enable =
features.forward.feature_key_sync.enable =
features.dnd.feature_key_sync.enable =
call_waiting.mode =
bw.xmpp.enable =
features.uc_password =
features.uc_username =
bw.xmpp.presence_icon.mode =
bw.xmpp.change_presence.force_manual.enable =
bw.xmpp.change_presence.enable =
phone_setting.dsskey_directory_auto.enable =
features.uc_dir.match_tail_number=
directory_setting.bw_uc_buddies.enable =
directory_setting.bw_uc_buddies.priority =
search_in_dialing.bw_uc_buddies.enable =
search_in_dialing.bw_uc_buddies.priority =
##V83 Add
phone_setting.uc_favorite_sequence_type =
##V83 Add
bw.emergency_calling.enable =
meta.enable =
meta.login_mode =
meta.comm_portal.server.username =
meta.comm_portal.server.password =
meta.comm_portal.server.url =
meta.comm_portal.enable =
meta.comm_portal.contacts.update_interval =
meta.comm_portal.acd.enable =
meta.comm_portal.replace_local_call_list.enable =
meta.comm_portal.contacts.group.mlhgs.label =
meta.comm_portal.contacts.group.extensions.label =
meta.comm_portal.contacts.group.contacts.label =
meta.comm_portal.contacts.group.mlhgs.enable =
meta.comm_portal.contacts.group.extensions.enable =
meta.comm_portal.contacts.group.contacts.enable =
meta.comm_portal.call_list.enable =
meta.comm_portal.contacts.enable =
meta.comm_portal.message.enable =
meta.comm_portal.logout.enable =
meta.comm_portal.keep_alive_interval_time =
##V83 Add
directory_setting.meta_directory.enable =
directory_setting.meta_directory.priority =
directory_setting.meta_call_log.enable =
directory_setting.meta_call_log.priority =
search_in_dialing.meta_call_log.priority =
search_in_dialing.meta_call_log.enable =
search_in_dialing.meta_directory.priority =
search_in_dialing.meta_directory.enable =
gb.sopi.enable =
gb.sopi.gab.enable =
gb.sopi.pab.enable =
features.pab.soupuser =
features.pab.enable =
gb.sopi.pab.match_in_calling.enable =
gb.sopi.gab.retain_search_filter =
gb.sopi.service_url =
gb.sopi.password =
gb.sopi.username =
directory_setting.gb_gab_directory.priority =
directory_setting.gb_gab_directory.enable =
directory_setting.gb_pab_directory.enable =
directory_setting.gb_pab_directory.priority =
search_in_dialing.gb_pab_directory.priority =
search_in_dialing.gb_pab_directory.enable =
##V83 Add
sip.loopback.enable =
sip.loopback_type =
sip.pkt_loopback_mode
sip.loopback.auto_answer.mode =
sip.pkt_loopback_encapsulated_payload =
sip.pkt_loopback_directed_payload =
google_contact_server.enable =
static.features.network_test.check_policy =
static.features.network_test.enable =
static.features.network_test.host =
static.features.network_test.period =
static.features.network_unavailable_test.period =
phone_setting.warnings_display.mode =
bw.flexible_seating.remember_password.ldap.enable =
vcaccount.enable =
features.acoustic_shield.level =
features.acoustic_shield.mode =
phone_setting.search_t9.enable =
phone_setting.mail_power_led_flash_enable =
ldap.anonymous_bind_operation.enable =
google_contact_server.display_mode =
gb.presence.line =
gb.presence.enable =
gb.emergency_instant_messages.enable =
gb.emergency_instant_messages.displaytimeout =
features.transfer_keep_session2_after_failed.enable=
features.emergency_instant_messages.ring_type =
features.call_park.performby_holdhardkey.enable =
features.blf_extension.mode =
features.auto_answer.ring_type =
directory_setting.presence_list.priority =
directory_setting.presence_list.enable =
dialplan.emergency.held.secondary.server_url =
custom.features.dsskey_lock_type =
auto_provision.pnp_check_url.enable =
acd.logout_fixed_display.enable=
acd.available_fixed_display.enable =
acd.disp_code_fixed_display.enable =
acd.trace_fixed_display.enable =
features.parked_call_monitor.blf_visual_enable =
features.parked_call_monitor.blf_audio_enable =
features.parked_call_monitor.blf.ring_type =
auto_provision.allsettings.sync.path =
auto_provision.allsettings.sync =
bw.features.flash_time =
bw.features_status.display_mode =
bw.xsi.directory.server_search_type =
features.dsskey_page_reset.call_established.enable =
features.dsskey_page_reset.call_established.page =
features.dsskey_page_reset.enable =
features.dsskey_page_reset.page =
features.headset.group_listen_in_talking_enable =
features.noise_filtering_rev.enable =
features.out_of_service_alert.enable =
features.out_of_service_alert_time =
features.paging_auto_resume.enable =
features.voice_mail_key_lamp_field.enable =
over_the_air.url.cp930w =
phone_setting.autop_led_flash_enable =
phone_setting.call_remote_end_when_hold.busy_tone.enable =
phone_setting.retain_pin.enable =
phone_setting.voice.ring_vol_min =
static.auto_provision.rsa_pri_key.delete =
static.auto_provision.rsa_pri_key.enable =
static.auto_provision.rsa_pri_key.url =
static.network.l2tp_server.address =
static.network.l2tp_server.password =
static.network.l2tp_server.username =
static.network.openvpn_file.url =
static.network.pc_port.mode =
static.network.set_fragment.enable =
static.network.vpn.mode = 1
static.wifi.x.802_1x.anonymous_identity =
static.auto_provision.aes_key.com =
static.auto_provision.aes_key.mac =
unify.enable =
features.transfer_complete.prompt.enable =
Could you please share the file on this location /etc/httpd/logs/access_log, we’ll check which file the phone is requesting
