Sure, here they are.
access_log-20221106.txt (1.3 MB)
access_log.txt (1.4 MB)
try adding this file on this location /var/lib/vitalpbx/provisioning/provisioning_templates/ec389154e803a2d5/aastra.cfg
inside the file you can add this content
#aastra provision file
and then try again to provision
Almost !!
Adding the screenshot of the config of the phone
With that config if I add Phone Number → 102 and Proxy Server → 172.16.250.24
Extension 102 gets register into the pbx.
Template Custom:
#Date / Time Settings
time zone name: {{ $timezone }}
date format: {{ $timeFormat ?? 0 }}
time format: {{ $dateFormat ?? 0 }}
#Language
language 1: lang_{{ $language }}.txt
language: {{ $language == ‘en’ ? 0 : 1 }}
#SIP Settings
sip transport protocol: {{ $settings[‘sip_transport’] ?? ‘1’ }}
#Accounts
@foreach ($accounts as $account)
sip line{{ $loop->iteration }} screen name: {{ $account[‘description’] ?? null }}
sip line{{ $loop->iteration }} display name: {{ $account[‘description’] ?? null }}
sip line{{ $loop->iteration }} auth name: {{ $account[‘device_name’] ?? null }}
sip line{{ $loop->iteration }} password: {{ $account[‘secret’] ?? null }}
sip line{{ $loop->iteration }} mode: 0
sip line{{ $loop->iteration }} registrar ip: {{ $account[‘sip_domain’] ?? ‘0.0.0.0’ }}
sip line{{ $loop->iteration }} registrar port: {{ $account[‘sip_port’] ?? ‘0’ }}
sip line{{ $loop->iteration }} proxy ip: {{ $account[‘sip_proxy’] ?? ‘0.0.0.0’ }}
sip line{{ $loop->iteration }} proxy port: {{ $account[‘sip_proxy_port’] ?? ‘0’ }}
@endforeach
#Programmable keys
@foreach ($dssKeys as $key)
prgkey{{ $loop->iteration }} label: {{ $key[‘label’] ?? null }}
prgkey{{ $loop->iteration }} line: {{ $key[‘line’] ?? null }}
prgkey{{ $loop->iteration }} type: {{ $key[‘type’] ?? null }}
prgkey{{ $loop->iteration }} value: {{ $key[‘value’] ?? null }}
topsoftkey{{ $loop->iteration }} label: {{ $key['label'] ?? null }}
topsoftkey{{ $loop->iteration }} line: {{ $key['line'] ?? null }}
topsoftkey{{ $loop->iteration }} type: {{ $key['type'] ?? null }}
topsoftkey{{ $loop->iteration }} value: {{ $key['value'] ?? null }}
@endforeach
#Firmware
firmware_server: {{ $connectionSettings[‘firmware_path’] ?? null }}
download protocol: HTTP
#Admin password
admin password: {{ $adminPassword }}
try with this
#Language
#SIP Global Settings
sip mode: 0
sip proxy ip: {{ $settings[‘sip_proxy’] ?? null }}
sip proxy port: {{ $settings[‘sip_proxy_port’] ?? null }}
sip registrar ip: {{ $settings[‘sip_domain’] ?? null }}
sip registrar port: {{ $settings[‘sip_port’] ?? null }}
sip registration period: 600
sip blf subscription period: 600
sip explicit mwi subscription: 1
sip digit timeout: 4
sip send mac: 1
sip send line: 0
sip silence suppression: 0
sip xml notify event: 1
sip dial plan: “x+#|xx+*|70x”
#Accounts
@endforeach
#Programmable keys
@endforeach
#Firmware
#Admin password
Thanks, I also made a couple of modifications
Under #Accounts :
add:
sip line{{ $loop->iteration }} phone number: {{ $account[‘device_name’] ?? null }} → Phone Number Field
sip line{{ $loop->iteration }} display name: {{ $account[‘description’] ?? null }} → Caller ID Field
modified proxy ip and proxy port:
sip line{{ $loop->iteration }} proxy ip: {{ $account[‘sip_domain’] ?? ‘0.0.0.0’ }}
sip line{{ $loop->iteration }} proxy port: {{ $account[‘sip_port’] ?? ‘0’ }}
With that the phone 6755i I got register. I will test with the other 2 models and make some test calls.
I also have test if I can change the language to spanish
Ok we’ll proceed to update the templates thanks
