Yealink Template Issues
Yealink Templates codec is not configured correctly
account.{{ $loop->iteration }}.codec.2.enable = 1
account.{{ $loop->iteration }}.codec.2.payload_type = PCMA
account.{{ $loop->iteration }}.codec.2.priority = 1
account.{{ $loop->iteration }}.codec.2.rtpmap = 0
PCMA should be 8
account.{{ $loop->iteration }}.codec.2.rtpmap = 8
And it should be 8 because…?
The default T31G template uses 0 for PCMU and PCMA.
0 should be PCMU and 8 PCMA. RFC 3551 section 6
account.{{ $loop->iteration }}.codec.1.enable = 1
account.{{ $loop->iteration }}.codec.1.payload_type = PCMU
account.{{ $loop->iteration }}.codec.1.priority = 1
account.{{ $loop->iteration }}.codec.1.rtpmap = 0
Other wise there is no audio
