Yealink Provisioning module
Hi All,
I have a large number of Yealink T46Us, and the end user would like to have the extension number instead of the name on the screen. This can be accomplished if I log into the phone and change the label on the DSS key.
I have attached a screenshot of my current layout. Instead of the name, they would like to see their own extension
However, I do not want to do each phone one-by-one.
Is there a way to accomplish this through the provision module?
Thank you.
Hi I use the T46G so it maybe different. I edit the description in the templates and it displays on my phone Call A etc…
You could modify the template and set up the extension as the description.
I use the method that Miguel mentioned.
