WSS Issue VPBX 4 Fresh Install
After fresh install Vitalpbx v4 several times , and installing Vitxi ,
The error occured
The connection to your server could not be established.
Please, contact the administrator.
and after tracing the problem :
  • Port 6001 , 8089 ,3500-3501 443 is open on the firewall and reachable
  • when accessing https://FQDN:8089/ws opens and get upgrade required
  • SSL Certificate issued from letsencrypt and vaild
  • PJSIP Profile is correct and configured
But no luck the vitix don’t load
we also open the browser console . and get this message
Waterfox can’t establish a connection to the server at wss://FQDN:6001/app/vitxi4561aq/console.
When tried to run the command thats correct ssl
root@vitalpbx:~# /usr/share/vitxi/backend/artisan websockets:ssl-config
/usr/bin/env: ‘php\r’: No such file or directory
also we checked /usr/share/vitxi/backend/.env we found thats the section of the
LARAVEL_WEBSOCKETS_SSL_LOCAL_CERT=
LARAVEL_WEBSOCKETS_SSL_LOCAL_PK=
LARAVEL_WEBSOCKETS_SSL_PASSPHRASE=
is Empty
This is fatal issue , kindly support asap ,
Regards Mohamed Soliman
Try the below to fix the newline (from stackoverflow)
cd /usr/share/vitxi/backend
tr -d '\015' <artisan >artisan.new
mv artisan artisan.old
mv artisan.new artisan
chmod +x artisan
chown www-data:www-data artisan
Then run /usr/share/vitxi/backend/artisan websockets:ssl-config again.
You can also install dos2unix apt install dos2unix and run
dos2unix /usr/share/vitxi/backend/artisan
