What is "expert mode"?
Hi.
Some feature codes instructions refer an “expert mode”.
Example:
*59 - Set CF Immediately Number - Sets the number to which calls should be sent when immediate call forwarding is activated. You can either follow the prompts, or (in expert mode) enter the feature code immediately followed by * (asterisk) and the number to which calls should be forwarded. Feature must be enabled in the Feature Category associated with the extension.
I want to use it but I don’t know how.
Can somebody help me, please?
You are expert when you do it like in the tool tip. There is no extra expert mode.
You are no expert if you only listen to the sounds but an expert if you use the codes.
