When enabling web portal access for tenant extension, username gets trimmed by the tenant number.
For example if Tenant number is 11 and you want to create Portal User: 11 311, the result is: 11 3.
So extension number gets trimmed (11).
What version of VitalPBX are you running?
VitalPBX Carrier Plus 3.2.3-2
Asterisk 18.12.1-1
Also happens on latest:
VitalPBX 3.2.3-6
Asterisk 18.12.1-1
DAHDI 2.11.1-7
It seems that this only happens of you use a number as the tenant prefix.
I can put in any number in, but if there’s 11 sequence, that would be cut off.
Eg:
11 12345116789
would produce: 11 12356789
Same bug goes with version 4:
tenant: 22
extension: 422
Hence testing the login (11311) and it actually works.
So it’s only a bug in a web management console View.
Any news on this one? ![]()
This got addressed in the latest versions of VitalPBX 4 and will be fixed in the next VitalPBX 3 update!
