Voicemail Transcription not working after update
Has anyone else found that after the 4.1.0 R8 update that their Google voicemail transcript has stopped working? It looks like its stopped pulling the ‘sendmail’ script.
Do you still have your custom files?
root@pbx1:~# ls -l /etc/asterisk/vitalpbx/ | grep 'voicemail.*general'
-rw-r--r-- 1 www-data www-data   1064 Sep 25 05:12 voicemail__10-general.conf
-rw-r--r-- 1 www-data root        116 Sep 25 05:12 voicemail__60-general.conf
Confirm it overrides the mailcmd parameters
root@pbx1:~# cat /etc/asterisk/vitalpbx/voicemail__60-general.conf
[general](+)
You override the default program to send e-mail to use the script
mailcmd=/usr/sbin/sendmail-gcloud
Yep it all looks ok from a setup side. We do have a case logged with Support so hopefully they can help:
We have a similar issue where some voicemails will have transcription some other wont. Cant find a common cause. But we are using OpenAI instead of Google Cloud.
We also have a ticket open but no updates as of yet.
