VitXi WebRTC 4.6.0-1 – Merge Calls, Canned Responses, Better DND Control, and More!
This release adds faster workflows for calls and contact management, improves SMS/contact identification consistency, and delivers multiple reliability fixes across telephony features and UI.
New Features
  • Merge calls to bring active calls together into one audio conference.
  • Call Controls from Notifications: Answer or reject calls directly from system and call notifications.
  • Canned Responses:
    Improve agent productivity and response consistency with reusable message templates.
  • Bulk Delete Contacts: Select multiple contacts and remove them in a single action.
  • Direct SIP URI Dialing: Dial full SIP URIs directly from the numeric dialpad.
  • Quick Do Not Disturb (DND) Toggle: Toggle DND directly from the status chip with a clear visual indicator.
  • DND Status Indicator: View DND status at a glance in the Device Status component.
  • Brand Name in Feature Gate: Display the configured branding name where feature access is controlled.
  • App Version in Footer: Quickly identify the running app version for easier troubleshooting and support.
Improvements to existing features
  • Call Transfer Search Upgrade:
    Faster and smarter search across Users, Contacts, and PBX Phonebooks (directories assigned by the admin), with default suggestions and on-demand search.
  • SMS Threading & Contact Names:
    Incoming and outgoing messages now stay in a single unified thread through number normalization, with consistent contact name display using all available phonebooks.
  • Caller ID Name Lookup:
    Incoming calls now display caller names using the tenant phonebook when available.
  • DND Call Behavior:
    Calls to users in DND are now treated as “busy” for clearer signaling.
  • WebRTC SMS Contact Matching & Threading: Improved accuracy and consistency.
  • Directories in Call Transfer Dialog: Added directory selection to improve call routing.
  • Optional User Creation Email Notification: Admins can now disable email notifications when creating users.
  • UI Polish: Refreshed header, footer, and theme styling for better light/dark mode consistency.
Fixes
  • VitXi Conference Audio Issues: Fixed one-way audio and echo issues related to hold/resume.
  • BLF Hints: Presence and BLF indicators now work correctly.
  • User Import Actions: “Replace existing users” and “Skip existing users” now behave reliably, preventing duplicates and unintended overwrites.
  • Password Reset URLs: Corrected protocol mismatch issues.
Thank you to our customers and community for the valuable feedback, ideas, and real-world use cases that helped shape this release. Your recommendations continue to guide our priorities and improvements, please keep sharing your suggestions as we move forward.
