Today the development department released the first apk internally, we will proceed to test it and if everything goes well we will publish it in the Google Play store very soon.
Hi All
I have it working as a charm using Brave, it saves it as an “app”
Hi Sir,
When you release vitxi+ mobile?
Thanks.
More than a year ago we launched VitalPBX Connect, it is our Mobility solution for VitalPBX 4.
Hi Sir,
I have some question about VitalPBX Connect?
- How many devices We can add on VitalPBX Connect?
- Does VitalPBX support push notification?
- When I kill app or run app back ground on mobile. Does VitalPBX connect push notification of ringing incoming call? Because I saw some app don’t support this.
Thanks.
Here is the information for Connect: VitalPBX Connect - PBX App For IOS And Android
- You buy licenses in packs of 10
- Yes, connect uses push notifications
- Same answer as number 2.
VitalPBX Connect is based on Acrobits CloudSoftphone, which one of the best to handle push notifications.
Hi Hlev,
Thanks for your information.
Best Regards.
Tien
