Dear Team,
After upgrading to PBX Version 4.5 everything is working.
However, facing issue with WebRTC VitXi getting error Timeout waiting for websocket to open.
Tried the following steps VitXi Extension not able to make or recieve calls - #19 by maynor
but getting error please check-
Thanks.
Anyone else facing similar issue after upgrading to Vitalpbx 4.5.
I have even tried reinstalling the Vitxi addon with freshly installed Webrtc certificate, but the issue still persists.
Kindly assist.
GaryC
November 24, 2024, 12:34am
3
My VitXi is working fine, I had an issue with the cert not set properly in the mini http settings, once corrected all seems to work fine.
maynor
November 25, 2024, 3:57pm
4
Hello Sir,
Have you checked the Mini HTTP Settings?
I was able to resolve the issue after setting the https to default port. In our previous installation we have changed the https port.
We tested and found that changing the https port is causing the issue which was not the case with Vitalpbx version 4. May be this is related to Webserver as its changed from Apache2 to NGINX.
Hemant Joshi
maynor
November 26, 2024, 9:40pm
6
Hello Sir,
The fix will be available in the next version, which we will release in a few days.
Could you also confirm if the tenants load properly when you access the user module in VitXi?
Yes, tenants and VitXi (webrtc) users under different tenants are working properly.
Hemant Joshi
maynor
November 26, 2024, 10:21pm
8
Perfect! We will release the new version in a few days,
VitXi extension not registered, unable to call
maynor
December 5, 2024, 3:58pm
10
Check if port 8089 is enabled, visit https://your-domain:8089/
If it is enabled you should see a “not found” message
The requested URL was not found on this server.
Asterisk/20.10.0
maynor
December 6, 2024, 3:15pm
12
Please send us screenshots of your default webrtc settings and mini HTTP settings
Please enter Port 8089 under PBX setting when you login as WebRTC admin.
Reference screenshot-
Once you save changes, logout and login. WebRTC extension should register.
Hemant Joshi
