When importing in other VitXi account the csv file, the avatar don’t appear.
My question is can I point a png file in the avatar columm to a file that exists in the same folder in order to be able to import also the avatar picture?
Yes, in the avatar column, the name of the file should be placed, which should be located in the directory vitxi/backend/storage/avatars. This way, the images can be loaded correctly.
My mistake.
That informaton is store in the VitalPbx server, right?
So if i copy the folder avatars from one user to other user (in the server) and then in the vitxi client import the csv file with the same avatars names it should work.
Thanks in advance.
