Please check why DTMF not woking on vitxi webrtc 1.0.6-6?
Test Lab
agent webrtc A call to agent Webrtc B, agent A press DTMF, in console it never show DTMF event.
agent webrtc A call to IVR → press DTMF → never get response.
Please solve this issue, because it working on previoust version
PitzKey
2
Hi @MASTERING_VOIP,
Please try not to tag people who are not engaged in the conversation. It is up to them if they choose to respond.
PitzKey
3
What happens when they call an external number. Does it work then?
Not woking Sir DTMF internal & external.
If i change wephone using pjssip or dubanggo is working, so this issue on vitxi app.
maynor
6
Hello Sir,
Try setting the “DTMF Mode” to auto in the extensions settings.
Also, verify that the keyboard you are using to send DTMF is as follows:
I am looking forward to your comments,
Hi
Dtmf doesn’t work because I’m using the wrong dial pad (the one I circled in red). Nothing to do with DTMF mode
