Vitxi custom https port
Hi VitalPBX Team,
Saw this new updates for VITXI. What do you mean by “Handle custom HTTPS Port”?
Is it possible to use different port for VITXI HTTPS access?
What I want to achieve is the VITALPBX administration will use 443 and VITXI will use different port like 5291?
Thank you,
https port works on 443, so now we can change https port.
One need to first update the port under HTTP server and then same port under webrtc PBX settings.
Check below screenshot examples
and
after doing this the PBX url will changed -
https://pbxdomain:customeport ( example https://mypbx.com:2443 )
Also, I think it’s not possible to have different ports for Admin and users or WebRTC
Hemant Joshi
This is great! Thanks for your help. @TELECOMIN
Hopefully soon VitalPBX team will consider to apply 2FA in VITXI login as additional security measure because nowadays most of our users are working from home.
Request it under Wish List
I really hope they will allow using a single set of credenza for all portals… (SSO?)
