Hello, I have Upgrade my PBX from 3.2.3-6 to 4.0.0-8, is not an upgrade but i have reinstall the pbx with lastest version with restoring the backup. my issue now the vitxi webrtc extension is unregistred. i’ve check all the the configuration and its ok it working with the old version but after i install the lastest version vitxi webrtc not working.
i have not setup any domain even with the old version working without any domain set
and i have configure cert with self signed method and the hostname is the ip address of the PBX.
Hola Miguel, en efecto hay un problema con vitxi en la version 4.0.0.8, la estoy instalando desde 0 con una licencia de carrier plus, poniendo todo en funcionamiento, conecte la troncal sobre pjsip y todo en orden, sin embargo, el hostname lo configure de acuerdo al FQDN, y la extension en cuestion no funciona, no se registra por alguna razon, revise que todo estuviera en orden pero igual sigue dando el mismo problema.
I had same issue, i was obliged to go back to V3 as i was not able to find clear solution on the forum.
When i went back to V3, all was again working fine.
