VitXi Chat and SMS E164
When creating a New Conversation in VitXi and sending to SIP (External) phone number, it will allow you to send in E164 format or just 11 digit format. This in turn creates the conversation as such.
However, when a response to that chat is received, it may be in a different format per the messaging provider’s format (E164 or just 11 digits). If that format is different, VitXi will subsequently create a new conversation.
I suggest creating some sort of mechanism for handling the expected provider’s format for both sending and receiving, perhaps in the Messaging Providers configuration.
Additionally, if an SMS does come in, and that number is found in the list of contacts, display that Contact info instead of just the number in the conversations panel.
This also effects the ability to use the Call Button on a chat. If that Chat is in a format different from what the provider expects or different from the outbound profile for the extension, it will fail. Ex: Chat comes in with E164 format (+12125551212), but the provider only wants 11 digits on outbound calls.
I’m seeing the same issue with this. I just configured SMS with BulkVS and am receiving SMS with E164.
Maybe there could be an option in the Messaging Provider setup to convert it to the desired format (11 digit for me).
Eli_Hunter, are you able to send SMS via BulkVS?
You know actually I haven’t tried sending since I haven’t filled out a 10DLC form for the number I’m testing with. I’ll get everything setup this week and do a full test.
Yes SMS via BulkVS works perfectly.
Now has been over two years since this request, several iterations of VitXi. The Chat and Contact relationship in VitXi is aweful, or more accurately, nearly non-existent. In our world if a customer wants to use a collaboration suite, it ain’t with VitalPBX. We go through Grandstream and Wave.
So again…
  • Clean up the digit dialing requirements and what is required and received by the underlying carrier. E164, 11 or 10 digits. Same as what is capable in VitalPBX itself with CID Modifiers.
  • Ditch the whole selection process of App or SIP. NO ONE KNOWS THAT THAT IS! Make it seamless and do the applicable logic behind the scenes for what the end user is doing.
  • When a chat comes in or goes out, and that info is found in the user’s Contacts, display it as such so they know whom they’re dealing with. If they’re not in the Contacts, provide an option to quickly add them.
Holy cow this is pretty basic stuff that’s been around in these kinds of web-based collaboration applications for eons now. Get with it fellas. I’ll check back in on this in 2027 I suppose.
We’ve released a new version of VitXi that includes several improvements to chat functionality and SMS E.164 number normalization.
Please update VitXi by going to: VitalPBX > Addons > Check Online > Update VitXi
More details about this release: VitXi WebRTC 4.6.0-1 – Merge Calls, Canned Responses, Better DND Control, and More!
Thank you for the valuable feedback, ideas, and real-world use cases that helped shape this release.
Yes, better. More suggestions…
  1. Still have that App vs SIP thing going on, and it defaults to App, and that is killing us! It’s either a support ticket to us telling us our stuff is broke, or they simply don’t use it.
  2. When initiating a new external text/chat, and only using a 10-digit north American number, it will still go out with the E164 +, but not with the country code. When that response comes back in, it will come back in as a new chat fully formatted. Thus, two chats still.
  3. From the My Contacts, there should be a way to initiate a chat or text with that contact, not just a phone call.
  4. Chat messages sent from VitXi web don’t show in the mobile app, and vice versa. This is a problem where we have several folks or extensions all working from multiple devices or contacts. Even for a singular person or extension and the management of what was sent and where. The full thread.
We are working on this to unify VitXi with the Mobile app.
First, I am super grateful for all the work done to make the SMS and Apps working. I cant imagine the amount of work needed behind the hood to make this happend.
But I totally agree with the comments here. `
“APP” vs “SIP” means nothing to anyone. I was even confused as the system admin. Users should be able to “text” the extension number (Internal) of the phone number/DID(Either an “external” number, like a mobile cellphone (via the SMS provider like telnyx) or Internally if the number is associated with an extension).
And when I send a SMS from Vitxi, it comes back to the VitalPBX Connect App only. Why?
Another point:
A: If users text each others to their VitalPBX numbers, if should not go throught Telnyx for example. And this should also apply to communication between tenants in a multi-tenant setup.
B: Also, Vitxi, VitalPBX Connect, Sonata, why all the different names? So confusing for the users.
We have been and are still using the 3cx apps and PBX for customers that needs SMS. Thats sad. Some of our clients have their phone systems on VitalPBX but SMS only with the 3cx apps and Webapp. :frowning:
Thank you for you consideration.
Just a quick update, this has been improved/fixed in the latest release VitXi WebRTC v4.6.0-2 :tada:
We recommend updating to the latest version to benefit from these changes and overall improvements.
You can check the full release notes here:
:backhand_index_pointing_right: VitXi WebRTC v4.6.0-2 Release Notes
Let us know your feedback after updating!
