I have both systems on 4.0.0 R7 on both I have install Sonata Suits. On both I try to sync agents in one i don’t have any trouble in the other one I’m getting.
Another think that I notice in the system that I’m having trouble when I login I get the loading message and remains there after waiting I have to do a refresh (F5) and the I can get into the stats suite. I also have installed switchboard suite on the same system that I having trouble but no issues.
Is there is any log that I can check to see what could be happening?
Could you please look for a log file with the most recent date on this location /usr/share/sonata/queues-stats/backend/storage/logs, if you see the file please share it for analysis
–Settings
– Technology Settings/PJSIP Settings
– Time Zone : (us) United States/North America
But same result, when I log in keep seeing the loading page, and I have to press F5 to refresh and get to the Stats Dashboard but keep getting the server error message.
When mention the timezone on the secondary tenant, where can I check that?
==> El distribuidor del paquete ha publicado una versión actualizada.
¿Qué quisiera hacer al respecto? Sus opciones son:
Y o I : instalar la versión del desarrollador del paquete
N o O : conservar la versión que tiene instalada actualmente
D : mostrar las diferencias entre versiones
Z : ejecutar un intérprete de órdenes para examinar la situación
La acción por omisión es conservar la versión actual.
*** .env (Y/I/N/O/D/Z) [por omisión=N] ? Y
Instalando una nueva versión del fichero de configuración /usr/share/queues-stats/backend/.env …
INFO Application cache cleared successfully.
INFO Caching the framework bootstrap files.
config … 34ms DONE
routes … 42ms DONE
In Connection.php line 759:
SQLSTATE[HY000] [1045] Access denied for user ‘stats’@‘localhost’ (using password: NO) (SQL: select * from information_schema.tables where table_schema = sonat
a_stats and table_name = migrations and table_type = ‘BASE TABLE’)
In Exception.php line 18:
In PDOConnection.php line 40:
dpkg: error al procesar el paquete sonata-stats (–configure):
el subproceso instalado paquete sonata-stats script post-installation devolvió el código de salida de error 1
Se encontraron errores al procesar:
sonata-stats
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@atic-acura-1:~#
When I open the sonata stats I had to cofigured again the db, user just that I did not let me. I uninstall the add-on installed again (4.0.0-2) but at the end same result.
