VitalPBX v4.5 Missing Audio Folder
The silence audio folder is missing in v4.5
Is there a method to install this folder, I do not wish to update customer servers untill this is corrected.
Thanks,
You can copy the folder from any v3 or v4 system
So did you do it and it helped?
No it did not help, in fact the system crashed, not sure why.
I copied folder to /var/lib/asterisk/sounds/en then did a reboot of the system and everything stopped working, my only access was the vps console even ssh was not working, I removed folder and rebooted and all came back. maybe I did something wrong but at this point it maybe be better to wait for the new update comming soon.
Thanks,
