I have found an issue regarding the VitalPBX provisioning module.
A device (Fanvil X4) is already provisioned and the PJSIP extension is registered.
When the name on the PJSIP extension is modified, the device does not update the name of the PJSIP extension.
This can only be done manually by opening the provisioned device and clicking on Update and then Reprovision.
Can someone please help with this issue?
Also, would it be possible to update all provisioned devices $mac.cfg devices on an hourly schedule with a cronjob using a script or a command?
If you change the name on an extension then just a provisioning request by the phone will not work.
Changes in the extension name don’t seem to be saved into the config file right away.
So your suggesting will fix part 2 of his question but not part 1. But it’s a 50% fix which is better then 0%. So thanks.
Think this issue was mentioned before in the forums.
Just checked it again with latest 3.2.3-4
ConfigurationFile is NOT updated when name is changed in extension-menu.
Going to Provisioning in the VitalPBX Gui and then hitting “update” is needed to update the ConfigurationFile.
The provisioning on all phones is done by the hour so this is not an issue.
To clarify the issue, the mac.cfg files which are created upon adding or updating the provisioned device are not updated by making changes in the extensions module.
My temporary fix is to export all provisioned devices and then import the generated .csv file, which seems to recreate all the mac.cfg files. But I believe that the mac.cfg files should be update automatically by the PBX.
Also, does anyone have knowledge regarding this: Would it be possible to update all provisioned devices $mac.cfg devices on an hourly schedule with a cronjob using a script or a command?
