I’m trying to set up a phone system for my small agency, won’t be more than 25 ext in the next 2 years! I think VitalPBX one 25 ext - 1 year is a good fit. But I don’t know the overall cost:
Cloud base
Sip trunks (outbound + inbound)
I’m not very savvy in PBX, but I hope I can set it up myself.
VitalPBX One-25 is for up to 25 extensions and is paid annually…no monthly for this subscription. Should be very easy to setup, even cloud based. Sip trunking can be setup with VoIP.MS, Skyetel, Twilio, VoIP Innovations, Telnyx, etc… or even your own that you use. I’m not sure what country you’re in, but there are literally thousands of sip providers. Cloud VPS providers I would suggest is ColoCrossing and use at least 4GB of RAM.
If you are very familiar with setting up a PBX, SIP Trunking, VoIP routing, etc…I would suggest finding a hosting provider for your needs. We are one of VitalPBX’s Partners and we offer clients cloud-hosting PBX services on a per seat cost. Send me your email address and I’ll be happy to go over everything with you.
