VitalPBX Mobile - Call Center Controls
Is there any plans to bring call center controls to the VitalPBX Mobile applications? Log In/Out. multiple reason pause codes, etc.
You can use the feature codes for that at anytime.
But if you are asking if there will be a status visible in the app then the answer will be “No” i guess.
Since this app is not made by the vitalPBX Team and it is totally free.
Do you know who the developer is for that application?
Yes, see here:
