VitalPBX mobile app no audio outgoing call
I suddenly have an issue yet nothing has changed with our network to cause this.
Any person in the PBX can initiate a call to a mobile VitalPBX and that conversation can be normal.
However any user who initiates a call on the mobile app. Weather internal or External. Audio doesn’t come through in either direction.
I have restarted the router. I have restarted the PBX System. Nothing changes.
I did DMZ the PBX and found no change.
Try deactivating the firewall inside vitalpbx, but just for the test.
If that helps, then check the blocked ips.
You use geoblock?
