VitalPBX - Extension Login and Outbound Calls Work, But Inbound Calls Fail and Proxy Errors Appear
I’m experiencing an issue with my VitalPBX setup and seeking some assistance. Here’s the situation:
  • The extension successfully logs in and can make outbound calls without any problems.
  • Despite the above, I’m noticing some proxy-related errors in the logs, which is puzzling because I haven’t configured any proxy settings explicitly. Here are the errors I’m encountering:
[2024-04-10 12:55:36] WARNING[200806]: pbx.c:8797 ast_context_verify_includes: Context 'T5_cos-all-post' tries to include nonexistent context 'T5_ARS-all'
[2024-04-10 12:55:36] WARNING[200806]: pbx.c:8797 ast_context_verify_includes: Context 'T4_cos-all-post' tries to include nonexistent context 'T4_ARS-all'
[2024-04-10 12:55:36] WARNING[200806]: pbx.c:8797 ast_context_verify_includes: Context 'T3_cos-all-post' tries to include nonexistent context 'T3_ARS-all'
[2024-04-10 12:55:46] ERROR[190831]: res_pjsip.c:1419 create_out_of_dialog_request: Unable to apply outbound proxy on request OPTIONS to endpoint 101 as outbound proxy URI 'xxxxx.xxx.xx' is not valid
[2024-04-10 12:55:46] ERROR[190831]: res_pjsip/pjsip_options.c:880 sip_options_qualify_contact: Unable to create request to qualify contact sip:[email protected]:3765;ob on AOR 101
  • The extension isn’t receiving any inbound calls.
  • In the PJSIP Endpoints Status, all extensions are showing up as “Nonqualified” with a yellow label.
I’ve checked the PJSIP settings, including Endpoints and Transports, and I don’t see any outbound proxy settings that might be causing this issue.
Has anyone else faced a similar issue or can offer any advice on where these proxy errors might be coming from and why my extensions aren’t receiving inbound calls despite being registered and able to place outbound calls?
Any help or pointers would be greatly appreciated.
Thank you!
Solved in the meantime, i found where the proxy was entered…
