I have tried to configure the Direct media functionality to be used when making internal calls between extensions.
The steps that I have followed:
- In VitalPBX, under Device Profiles, I have enabled the Direct Media setting.
- The previously configured Device profile is used on all extensions.
- All extensions are using the same codec, ALAW.
- IP phones in use are Fanvil and are also using only ALAW codec.
According to the articles and guides, that I found online, these steps should enable direct media, can someone please help me regarding this configuration?
Thank and Best regards, Klemen
