VitalPBX Call Recordings and Backups in Amazon S3
I hope that I am correct with my conclusions, but anyone please feel free to correct me.
I wanted to follow the original guide here Seamlessly Store VitalPBX Call Recordings In Amazon S3 and while looking for it I found a forum post that ran into issues with playing the call recordings back after following the steps, Using Amazon Bucket for Call Recordings. After some research there seems to be a potential issue with the s3 mounting commands in the original guide that may cause issues with how the permissions are being set on new recordings made after migrating the call recordings to the s3 Bucket.
Before:
sudo s3fs YOUR_BUCKET_NAME /mnt/s3bucket -opasswd_file=/root/.passwd-s3fs -ourl=https://s3.YOUR_REGION.amazonaws.com -o allow_other -ouse_cache=/tmp
After:
sudo s3fs YOUR_BUCKET_NAME /mnt/s3bucket -opasswd_file=/root/.passwd-s3fs -ourl=https://s3.YOUR_REGION.amazonaws.com -o allow_other -ouse_cache=/tmp -o umask=0002
Before:
s3fs#YOUR_BUCKET_NAME /mnt/s3bucket fuse _netdev,allow_other,passwd_file=/root/.passwd-s3fs,url=https://s3.YOUR_REGION.amazonaws.com,use_cache=/tmp 0 0
After:
s3fs#YOUR_BUCKET_NAME /mnt/s3bucket fuse _netdev,allow_other,passwd_file=/root/.passwd-s3fs,url=https://s3.YOUR_REGION.amazonaws.com,use_cache=/tmp,umask=0002 0 0
I have also plagiarised the original post :grimacing: and added steps to the original instructions for also sending your VitalPBX Backups to the s3 Bucket :grin:
Seamlessly Store VitalPBX Call Recordings and Backups in Amazon S3
Efficient management of call recordings has become a cornerstone for businesses leveraging VoIP systems.
This comprehensive guide unveils a game-changing solution for VitalPBX users: configuring s3fs to seamlessly store Asterisk call recordings directly in Amazon S3.
By harnessing the power of cloud storage, this integration offers unparalleled scalability, robust reliability, and optimized cost-effectiveness.
Whether you’re a small business looking to streamline operations or a large enterprise aiming to enhance data management, this step-by-step tutorial will empower you to elevate your VitalPBX system to new heights of efficiency and accessibility.
Why Use Amazon S3 for Call Recordings?
  • Scalability: S3 provides virtually unlimited storage capacity.
  • Durability: Amazon S3 is designed for 99.999999999% durability.
  • Cost-effective: Pay only for the storage you use.
  • Accessibility: Access your recordings from anywhere with an internet connection.
Step-by-Step Configuration Guide
1. Install s3fs-fuse
First, we need to install the s3fs-fuse package, which allows us to mount an S3 bucket as a local filesystem:
sudo apt update
sudo apt install s3fs
2. Set Up AWS Credentials
Create a credentials file with your AWS Access Key and Secret Key:
  1. Create a password file to store AWS credentials (only accessible to root):
sudo echo ‘ACCESS_KEY:SECRET_KEY’ > /root/.passwd-s3fs
sudo chmod 600 /root/.passwd-s3fs
Replace ACCESS_KEY and SECRET_KEY with your AWS credentials.
3. Create the Mount Point
Create a directory where the S3 bucket will be mounted.
sudo mkdir -p /mnt/s3bucket/
4. Mount the S3 Bucket
Use s3fs to mount your S3 bucket:
Replace YOUR_BUCKET_NAME and YOUR_REGION with your S3 bucket name and AWS region.
5. Set Up Symlink for Asterisk Recordings
Create a symbolic link for Asterisk to access recordings from the S3-mounted directory:
  1. Create the monitor folder in your bucket
mkdir -p /mnt/s3bucket/monitor/
  1. Backup existing recordings
mv /var/spool/asterisk/monitor/* /mnt/s3bucket/monitor/
  1. Remove any existing directory at the target location after backing up the recordings:
sudo rm -rf /var/spool/asterisk/monitor
  1. Create the symbolic link to the S3 bucket:
sudo ln -s /mnt/s3bucket/monitor /var/spool/asterisk/monitor
6. Set Proper Permissions
Ensure asterisk has the necessary permissions to read and write to the S3-mounted directory.
sudo chown -R asterisk:asterisk /mnt/s3bucket/monitor
sudo chmod -R 770 /mnt/s3bucket/monitor
7. Set Up Symlink for VitalPBX Backups
mkdir -p /mnt/s3bucket/backup/
  1. Backup existing backups
mv /var/lib/vitalpbx/backup/* /mnt/s3bucket/backup/
sudo rm -rf /var/lib/vitalpbx/backup
sudo ln -s /mnt/s3bucket/backup /var/lib/vitalpbx/backup
8. Set Proper Permissions
sudo chown -R www-root: www-root /mnt/s3bucket/backup
sudo chmod -R 770 /mnt/s3bucket/backup
9. Configure Auto-mounting (Optional)
For automatic mounting on system boot, add this line to /etc/fstab:
  1. Open /etc/fstab:
sudo nano /etc/fstab
  1. Add the following line (replacing placeholders with your values):
10. Verify the Setup
To verify the Backup to s3 changes:
Create a new Backup Plan with the smallest possible options, I chose to not include and Add-os, CDR Records, Call Recordings or Voicemail, I only included Faxes
Save the backup plan and run it
To verify the call recordings to s3 changes:
Restart Asterisk and test recording functionality to confirm files are stored in /mnt/s3bucket/monitor.
sudo systemctl restart asterisk
Conclusion
By following this guide, you’ve successfully configured your VitalPBX system to store call recordings in Amazon S3. This setup offers improved scalability, reliability, and accessibility for your call recordings, allowing your business to manage its communication data more effectively.
Remember to regularly check your S3 bucket usage and implement appropriate lifecycle policies to manage your storage costs efficiently. Happy recording!
