root@pbx:/var/lib/vitalpbx# /usr/share/vitalpbx/scripts/*maintenance.php --debug
Starting Maintenance for Tenant HarkadirPBX…
Setting up timezone: Asia/Yerevan
Processing Recordings…
/var/spool/asterisk/monitor/2023/02/22/111258-LOCAL-NONE-04101-04106-1677049978.13185.wav is 0 days old, it doesn’t overcome the 30 days
/var/spool/asterisk/monitor/2023/02/22/111218-LOCAL-NONE-00191-00568-1677049938.13068.wav is 0 days old, it doesn’t overcome the 30 days
/var/spool/asterisk/monitor/2023/02/22/111314-LOCAL-NONE-07110-07109-1677049994.13205.wav is 0 days old, it doesn’t overcome the 30 days
/var/spool/asterisk/monitor/2023/02/22/111258-IN-NONE-37494977739-05102-1677049972.13164.wav is 0 days old, it doesn’t overcome the 30 days
/var/spool/asterisk/monitor/2023/02/22/111306-LOCAL-NONE-00272-00276-1677049986.13193.wav is 0 days old, it doesn’t overcome the 30 days
PHP Fatal error: Uncaught TypeError: Unsupported operand types: string * int in /usr/share/vitalpbx/www/includes/utils.php:0
Stack trace:
#0 /usr/share/vitalpbx/www/modules/maintenance/ACP.php(0): vitalpbx\utils::getRecordingDuration()
#1 /usr/share/vitalpbx/www/modules/maintenance/ACP.php(0): modules\maintenance\ACP->_cleanShortRecordings()
#2 /usr/share/vitalpbx/www/modules/maintenance/ACP.php(0): modules\maintenance\ACP->_cleanRecordings()
#3 /usr/share/vitalpbx/scripts/maintenance.php(0): modules\maintenance\ACP->run()
#4 [internal function]: {closure}()
#5 /usr/share/vitalpbx/scripts/maintenance.php(0): array_map()
#6 {main}
thrown in /usr/share/vitalpbx/www/includes/utils.php on line 0
Stack trace:
#6 {main}
Hi @gagikharutyunyan please don’t create duplicate posts.
Hi
Sorry,…
I thing the problem is the Delete Short Recordings.
I try set 0 at Delete Short Recordings, it’s work, when I try set 2 or 1, it’s not work.
We will look into it!
