VitalPBX 4 - import devices on the provisioning module is not working
When I try to import devices on the provisioning module is not working.
I download the template file add a couple of records but when try to import it give a error. I have a few ext configured so I download de export devices to compare both files.
Import
Are you running the latest version?
4.0.0 R6 I will try on 4.0.0 R7
Same result on 4.0.0 R7
Make sure of updating the provisioning add-on. I recommend doing a full update of your system.
apt clean all
apt update
apt upgrade
Looks like it’s working now!
