Does VitalPBX 4 support High Availability?
I was told they are working on a HA solution for V4. Using PROXMOX for HA is being recommended as you would not need 2 licenses for VitalPBX. I’ve never used PROXMOX but here is some information VitalPBX High Availability For Your Business With Proxmox VE
OK… Thanks for the info.
In case for the add-ons in case we need to install one, let’s say “bulk extensions”, do we need to install it on both servers?
What if the customer wants to records phone calls? Do we need to add a volumen that would control it depending who is the master?
