root@vitalpbx:/home/administrator# vitalpbx build-db
geo-firewall
ms-teams
ai_assistants
multi-tenant
branding
vpbx-connect
concierge
task-manager
dynamic-destinations
custom-contexts
voice_hub
queues-callback
Importing queue_callback_12.sql…
PHP Fatal error: Uncaught Exception: ERROR 1054 (42S22) at line 7: Unknown colu mn ‘dtmf_digit’ in ‘ombu_queues_callback’
in /usr/share/vitalpbx/scripts/apply_migrations:0
Stack trace:
#0 /usr/share/vitalpbx/scripts/apply_migrations(0): patcher->shellcmd()
#1 /usr/share/vitalpbx/scripts/apply_migrations(0): patcher->import_dbscript()
#2 /usr/share/vitalpbx/scripts/apply_migrations(0): patcher->apply()
#3 {main}
thrown in /usr/share/vitalpbx/scripts/apply_migrations on line 0
Done
error occured while getting maillog
Try to run the below then run vitalpbx build-db
again
mysql < /usr/share/vitalpbx/migrations/queues-callback/queue_callback_9.sql
root@pbx:/home/administrator# mysql < /usr/share/vitalpbx/migrations/queues-call back/queue_callback_9.sql
root@pbx:/home/administrator# vitalpbx build-db
multi-tenant
ai_assistants
whatsapp
vpbx-connect
ivr-stats
openvpn
ms-teams
task-manager
custom-contexts
voice_hub
crm
maintenance
sms
phone-books
branding
auth-destinations
geo-firewall
concierge
bulk-extensions
virtual-faxes
provisioning
queues-callback
Importing queue_callback_9.sql…
Done
Try to install rsyslog and then check is the email log is working
apt install rsyslog
everything worked
I have a problem with VitXi
Group, Phonebook, contacts do not load
Do not load call history…
Timeout waiting for Echo connection
After reinstall everything worked
