Just upgraded to VitalPBX 4.5 and I have DailyAutoBackup configured, but it is not generating the backup each night.
Mine also fails mostly.. It only actually works every 3rd day ish..
Thank you for the reply.
Helps to know I am not the only one. I turned in a ticket with support, waiting to hear back from them.
Try opening in a different browser/incognito.
Hmm. The 'ol change browser trick. I have fought myself on that problem many times before. It works perfect in another. Thanks for the suggestion.
Just to help anyone else.
I updated to VitalPBX 4.5.1-3 and then resaved the autobackup configuration in the GUI and it started working again.
Resaved the config in the GUI under PBX>Tools>Cronfiles and under
Admin>Tools>Backup&Restore
