VitalPBX Version: 4.5.3 R1 (Asterisk 20.18.2, Debian 12)
Summary:
The variables object in the POST /api/v2/core/click_to_call endpoint is documented as passing variables to the generated call channels, but custom variables never appear in the dialplan.
Steps to Reproduce:
Send the following API request (JSON format as required by docs):
curl --location 'https://callcenter.example.com/api/v2/core/click_to_call' \
--header 'app-key: YOUR_API_KEY' \
--header 'Content-Type: application/json' \
--data '{
"caller": "10013",
"callee": "0123456789",
"cos_id": 1,
"cid_name": "Test Call",
"cid_number": "0123456789",
"variables": {
"X-APP": "Postman",
"X-CAMPAIGN": "sales"
The API echoes the variables back in the response confirming they were received:
"status": "success",
"message": "Call queued",
"data": {
"caller": "10013",
"variables": {
"X-APP": "Postman",
Expected Behavior:
X-APP and X-CAMPAIGN should be available as channel variables in the dialplan, accessible via ${X-APP} and ${X-CAMPAIGN}.
Actual Behavior:
The variables are completely empty in the dialplan. Verified using NoOp debug statements inside [before-bridging-call-hook] which runs on the real PJSIP channel (not the Local/ wrapper):
-- Executing [s@before-bridging-call-hook:5] NoOp("PJSIP/10013-00000011", "X-APP=") in new stack
-- Executing [s@before-bridging-call-hook:6] NoOp("PJSIP/10013-00000011", "X-CAMPAIGN=") in new stack
Both empty. Tested across 5+ calls with multiple variable name formats (X-APP, X_APP, XAPP). None appear.
Variables confirmed available on the same channel for reference:
FROM_QUEUE_CALLBACK=yes
CTC_EXECUTED=yes
CALLID=1780570501.42
CALLER=0123456789
CALLEE=10013
These are VitalPBX-set variables, confirming the hook fires correctly and the channel is accessible.
Root Cause Analysis:
The click-to-call API generates an Asterisk .call file in /var/spool/asterisk/outgoing/. The variables block is presumably written as SetVar: lines in that file. However, because the call originates via a Local/ channel pair (Local/AGENT@click-to-call/n), the SetVar: variables from the call file are set on the originating spool wrapper — they do not propagate into the Local/ channel ;2 leg where the dialplan actually executes. This is a known Asterisk behavior with Local/ channels and call file variable propagation.
Workaround:
The reserved variable CONTEXT works correctly (it changes the Context: directive in the .call file, not a channel variable). VitalPBX-native variables like FROM_QUEUE_CALLBACK=yes are also available and can be used to identify click-to-call originated calls.
For integrations requiring call correlation without custom variables, the CALLID variable (set by VitalPBX itself) is available and reliable.
Request:
Please investigate why SetVar: lines from the click-to-call .call file are not propagating into the Local/ channel dialplan execution. A fix could involve either:
- Using AMI
OriginatewithVariable:instead of call fileSetVar:, which properly injects variables into originated channels. - Documenting clearly that the
variablesblock only supports the reservedCONTEXTvariable and that custom variables are not functional.
Happy to share full Asterisk verbose logs if needed.
References:
- VitalPBX Changelog: “API: The click-to-call endpoint now supports passing variables for the generated channels. Nonetheless, the request has to be in JSON format.” (VitalPBX 3.x changelog)
- VitalPBX 4 API Postman docs:
https://documenter.getpostman.com/view/5481262/2s935hQmgP
