Using Click To Call API; Where do we find Tenant ID?
Hello dear team
We are trying to test Click To Call feature on API from Postman but we are having bellow error:
    "status": "declined",
    "message": "Access Denied"
So maybe we are using wrong values for APi Key and Tenant.
Is (as on screenshot bellow) how we find these infos?
Value used for Tenant :
Value used for Api Key
Please help
Best regards
GET http://{{host}}/api/v2/tenants
Thanks dear,
i was able to find the value
Then i have bellow when i want to process the Click To Call API:
Any help?
The issue is exactly what the error says.
dear @PitzKey
This have been fixed, we removed the COS (or else we found the right value to add to it), tested and worked.
Thanks a lot
