Use 4g Modem as a trunk
Hi there, I have Huawei E3372-607 4g Usb Modem, I would like to use as a trunk for outgoing call using SIM card. Is it possible? and if yes how can I do it. As far as I know this modem support voice. So please help me in this regards.
Can you connect the modem to the PBX as an IP trunk?
Hi sorry if I didn’t make it clear, so I have Vitalpbx installed on raspberry pi 4 and I was asking if I connect 4g voice modem to same pi. How can I setup as a trunk to make call. Apparently the usb modem that I mentioned supports voice call.
I don’t have the exact instructions, but you might need to enable certain modules on Asterisk to make it work.
However, VitalPBX doesn’t support this natively!
Thanks Miguel for the suggestion, I have a another question, if I have a 4g hat for raspberry pi with sim cards, is there anyway to use that as a trunk?
I think debian 11 will not be compatible with compiling chan_dongle.so module for asterisk
In v3 we already compiled and using it after upgrading to v4 not possible,
If any furter instructions keep me in track
