Hi. I’m new to VPBX. I’ve used Asterisk, but a while ago in a previous life.
The issue I have is that when I dial a UK number e.g. 01980 777777, the number needs to be translated to +441980777777
I have tried Prepend = +44, Prefix = 0, Pattern = 0NXXXXXXXXX, but it just wont pick it up.
If I leave out the Prefix part, it does try and dial, but the number sent to the trunk is +4401980777777 (The first “0” needs stipping.
Try to remove the 0 and leave only NXXXXXXXXX
Keep in mind this:
Anything in the prefix field will be removed before sending the call, and anything in the prepend section will be added.
It was the pattern that it didn’t like.
